I am still in the transition from 2.5 to 3.x. The progresses are slow but constant, as I have many rules, items and scripts.
Up to now, especially one script is creating instantly a memory leak and crashing openhab:
rule "Smartmeter update"
Time cron "0 */5 * * * ?" or
Item System_Start received command ON
// Berechnungen Hausanschluss
var Number lastHourIn = (Smartmeter_Wh_In.deltaSince(now.minusHours(1),"jdbc").state as DecimalType).intValue
if (lastHourIn < 0) {
lastHourIn = lastHourIn + (Smartmeter_Wh_In.maximumSince(now.minusHours(1),"jdbc").state as DecimalType).intValue
Smartmeter_Wh_In_1h.postUpdate(lastHourIn)
var Number lastHourOut = Smartmeter_Wh_Out.deltaSince(now.minusHours(1),"jdbc").state as DecimalType).intValue
if (lastHourOut < 0) {
lastHourOut = lastHourOut + (Smartmeter_Wh_Out.maximumSince(now.minusHours(1),"jdbc").state as DecimalType).intValue
Smartmeter_Wh_Out_1h.postUpdate(lastHourOut)
var Number last24hIn = Smartmeter_Wh_In.deltaSince(now.minusHours(24),"jdbc").state as DecimalType).intValue
if (last24hIn < 0) {
last24hIn = last24hIn + (Smartmeter_Wh_In.maximumSince(now.minusHours(24),"jdbc").state as DecimalType).intValue
Smartmeter_Wh_In_24h.postUpdate(last24hIn)
var Number last24hOut = Smartmeter_Wh_Out.deltaSince(now.minusHours(24),"jdbc").state as DecimalType).intValue
if (last24hOut < 0) {
last24hOut = last24hOut + (Smartmeter_Wh_Out.maximumSince(now.minusHours(24),"jdbc").state as DecimalType).intValue
Smartmeter_Wh_Out_24h.postUpdate(last24hOut)
// Berechnungen Wärmepumpe
var Number lastHourIn = (SmartmeterWP_Wh_In.deltaSince(now.minusHours(1),"jdbc").state as DecimalType).intValue
lastHourIn = lastHourIn + (SmartmeterWP_Wh_In.maximumSince(now.minusHours(1),"jdbc").state as DecimalType).intValue
SmartmeterWP_Wh_In_1h.postUpdate(lastHourIn)
var Number lastHourOut = (SmartmeterWP_Wh_Out.deltaSince(now.minusHours(1),"jdbc").state as DecimalType).intValue
lastHourOut = lastHourOut + (SmartmeterWP_Wh_Out.maximumSince(now.minusHours(1),"jdbc").state as DecimalType).intValue
SmartmeterWP_Wh_Out_1h.postUpdate(lastHourOut)
var Number last24hIn = (SmartmeterWP_Wh_In.deltaSince(now.minusHours(24),"jdbc").state as DecimalType).intValue
last24hIn = last24hIn + (SmartmeterWP_Wh_In.maximumSince(now.minusHours(24),"jdbc").state as DecimalType).intValue
SmartmeterWP_Wh_In_24h.postUpdate(last24hIn)
var Number last24hOut = (SmartmeterWP_Wh_Out.deltaSince(now.minusHours(24),"jdbc").state as DecimalType).intValue
last24hOut = last24hOut + (SmartmeterWP_Wh_Out.maximumSince(now.minusHours(24),"jdbc").state as DecimalType).intValue
SmartmeterWP_Wh_Out_24h.postUpdate(last24hOut)
// Berechnungen Hausanschluss Total
if ((Smartmeter_Wh_In.state as DecimalType).intValue < (Smartmeter_Wh_In_Last.state as DecimalType).intValue) {
Smartmeter_Wh_In_Correct.postUpdate((Smartmeter_Wh_In.maximumSince(now.minusHours(24),"jdbc").state as DecimalType).intValue)
Smartmeter_Wh_In_Last.postUpdate((Smartmeter_Wh_In.state as DecimalType).intValue)
Smartmeter_Wh_In_All.postUpdate((Smartmeter_Wh_In.state as DecimalType).intValue + (Smartmeter_Wh_In_Correct.state as DecimalType).intValue)
if ((Smartmeter_Wh_Out.state as DecimalType).intValue < (Smartmeter_Wh_Out_Last.state as DecimalType).intValue) {
Smartmeter_Wh_Out_Correct.postUpdate((Smartmeter_Wh_Out.maximumSince(now.minusHours(24),"jdbc").state as DecimalType).intValue)
Smartmeter_Wh_Out_Last.postUpdate((Smartmeter_Wh_Out.state as DecimalType).intValue)
Smartmeter_Wh_Out_All.postUpdate((Smartmeter_Wh_Out.state as DecimalType).intValue + (Smartmeter_Wh_Out_Correct.state as DecimalType).intValue)
// Berechnungen Wärmepumpe Total
if ((SmartmeterWP_Wh_In.state as DecimalType).intValue < (SmartmeterWP_Wh_In_Last.state as DecimalType).intValue) {
SmartmeterWP_Wh_In_Correct.postUpdate((SmartmeterWP_Wh_In.maximumSince(now.minusHours(24),"jdbc").state as DecimalType).intValue)
SmartmeterWP_Wh_In_Last.postUpdate((SmartmeterWP_Wh_In.state as DecimalType).intValue)
SmartmeterWP_Wh_In_All.postUpdate((SmartmeterWP_Wh_In.state as DecimalType).intValue + (SmartmeterWP_Wh_In_Correct.state as DecimalType).intValue)
if ((SmartmeterWP_Wh_Out.state as DecimalType).intValue < (SmartmeterWP_Wh_Out_Last.state as DecimalType).intValue) {
SmartmeterWP_Wh_Out_Correct.postUpdate((SmartmeterWP_Wh_Out.maximumSince(now.minusHours(24),"jdbc").state as DecimalType).intValue)
SmartmeterWP_Wh_Out_Last.postUpdate((SmartmeterWP_Wh_Out.state as DecimalType).intValue)
SmartmeterWP_Wh_Out_All.postUpdate((SmartmeterWP_Wh_Out.state as DecimalType).intValue + (SmartmeterWP_Wh_Out_Correct.state as DecimalType).intValue)
I think it is the integration of ‘jdbc-mysql’ requests
Any help would be appreciated
