- Platform information:
- Hardware: Raspbery PI 3 B
- OS: Openhabian v1.4
- Java Runtime Environment:
- openHAB version: openHAB 2.2.0-1
- Issue of the topic: Memory leaks. after 1-2 day openhab process OutOfMemory error
- Please post configurations (if applicable):
- Items configuration related to the issue
String ToSerial “To Serial [%s]” {serial="/dev/ttyAMA0@115200"}
String PowModeIn “Mode” (PowerGroup)
String PowNghtIn “PowNghtIn” (PowerGroup)
String PowOnOfIn “PowOnOfIn” (PowerGroup)
Number PowLitNIn “PowLitNIn” (PowerGroup)
Number PowLitDIn “PowLitDIn” (PowerGroup)
Number PowFulNIn “PowFulNIn” (PowerGroup)
Number PowFulDIn “PowFulDIn” (PowerGroup)
Number PowTMaxIn “PowTMaxIn” (PowerGroup,Grafana)
Number PowTmp1In “PowTmp1In” (PowerGroup,Grafana)
Number PowTmp2In “PowTmp2In” (PowerGroup,Grafana)
Number PowTmpPIn “PowTmpPIn” (PowerGroup,Grafana)
Number PowTmpOIn “PowTmpOIn” (PowerGroup,Grafana)
String PowOnOfDb “PowOnOfDb” (Grafana)
String WatLevlIn “WatLevlIn” (PowerGroup)
String WatTempIn “WatTempIn” (PowerGroup)
String WatModeIn “WatModeIn” (PowerGroup)
String WatPumpIn “WatPumpIn” (PowerGroup)
- Sitemap configuration related to the issue
sitemap serial label=“Home” {
Frame label=“Frame1”{
Text item=PowTmp1In label=“Temp1 [%.1f °C]” {
Frame label=“Mode” {
Switch item=PowModeIn label=“Mode” mappings=[0=“Mode 0”, 1=“Mode 1”, 2=“Vjde 2”,3=“Mode 3”]
Frame label=“Set” {
Setpoint item= PowLitDIn label=“Mode 0 [%.1f °C]” visibility=[PowModeIn==1, PowModeIn==0 ] minValue=5 maxValue=30 step=1
Setpoint item= PowLitNIn label=“Mode 1 [%.1f °C]” visibility=[PowModeIn==0] minValue=5 maxValue=30 step=1
Setpoint item= PowFulDIn label=“Mode 2 [%.1f °C]” visibility=[PowModeIn==3, PowModeIn==2 ] minValue=5 maxValue=30 step=1
Setpoint item= PowFulNIn label=“Mode 3 [%.1f °C]” visibility=[PowModeIn==2] minValue=5 maxValue=30 step=1
Setpoint item= PowTMaxIn label=“TMax [%.1f °C]” minValue=10 maxValue=60 step=1
Frame label=“Tepms”{
Text item=PowNghtIn label="M1[%s]"
Text item=PowOnOfIn label="M2[%s]"
Text item=PowTmp1In label="T1[%.1f °C]"
Text item=PowTmp2In label="T2[%.1f °C]"
Text item=PowTmpPIn label="T3[%.1f °C]"
Text item=PowTmpOIn label=“T4[%.1f °C]”
Frame label=“Water”{
Text item= WatLevlIn label=“Level[%s m]”
Frame label=“Temp0”{
Text item= WatTempIn label=“Temp0[%s °C]”
Frame label=“Pumps”{
Text item= WatModeIn label=“Pump Mode[%s]” //mappings=[0=“Off”, 1=“On”]
Text item= WatPumpIn label=“Activity[%s]”
- Rules code related to the issue
var statePowModeIn
var statePowLitNIn
var statePowLitDIn
var statePowFulDIn
var statePowFulNIn
var statePowTMaxIn
rule "startup"
System started
statePowModeIn=PowModeIn.state.toString()
statePowLitNIn=PowLitNIn.state.toString()
statePowLitDIn=PowLitDIn.state.toString()
statePowFulDIn=PowFulDIn.state.toString()
statePowFulNIn=PowFulNIn.state.toString()
statePowTMaxIn=PowTMaxIn.state.toString()
rule "Serial_control"
Item ToSerial received update
var String _inp
var String Comand
var String Param
var int i
var int j
var int y
var int _len
try {
_inp=ToSerial.state.toString()
_len=_inp.length()
y=0;
while (y<_len-1) {
j=_inp.indexOf(";",y)
if (j!=-1) {
i=_inp.indexOf("=",y)
if (i!=-1) {
Comand = _inp.substring(y,i)
Param = _inp.substring(i+1,j)
y=j+1
if(Comand ==“PT1I”) sendCommand(PowTmp1In, Param)
else if(Comand ==“PT2I”) sendCommand(PowTmp2In, Param)
else if(Comand ==“PTPI”) sendCommand(PowTmpPIn, Param)
else if(Comand ==“PTOI”) sendCommand(PowTmpOIn, Param)
else if(Comand ==“PMdI”) sendCommand(PowModeIn, Param)
else if(Comand ==“PNgI”) {
if (Param==“1”) sendCommand(PowNghtIn, “N”)
if (Param==“0”) sendCommand(PowNghtIn, “D”)
else if(Comand ==“POOI”) {
if (Param==“1”) {
sendCommand(PowOnOfIn, “On”);
sendCommand(PowOnOfDb, “50”);
if (Param==“0”) {
sendCommand(PowOnOfIn, “Off”);
sendCommand(PowOnOfDb, “0”);
else if(Comand ==“PLNI”) sendCommand(PowLitNIn, Param)
else if(Comand ==“PLDI”) sendCommand(PowLitDIn, Param)
else if(Comand ==“PFNI”) sendCommand(PowFulNIn, Param)
else if(Comand ==“PFDI”) sendCommand(PowFulDIn, Param)
else if(Comand ==“PTMI”) sendCommand(PowTMaxIn, Param)
else if(Comand ==“WLvI”) sendCommand(WatLevlIn, Param)
else if(Comand ==“WTmI”) sendCommand(WatTempIn, Param)
else if(Comand ==“WMdI”) sendCommand(WatModeIn, Param)
else if(Comand ==“WPmI”) sendCommand(WatPumpIn, Param)
else logInfo(“SerialRules”, "Wrong command to parse: " + Comand)
else {
y=_len-1
else {
y=_len-1
catch (Exception e) {
logInfo(“Exception.Ex1”, e.toString())
try{
logInfo("_inp=", _inp)
logInfo("While", _inp + " ->" + y.toString () + " " + i.toString () + " " + j.toString() )
logInfo("Comand", Comand.toString () + "->" + Param.toString () )
catch (Exception e1){
logInfo("Exception.Ex2", e1.toString())
_inp=null
Comand=null
Param=null
i=null
j=null
y=null
_len=null
rule "PowModeIn"
Item PowModeIn changed
if (statePowModeIn!=“NULL”) ToSerial.sendCommand(“Set PMdO=”+ PowModeIn.state.toString()+ ‘;’)
rule "PowLitNIn"
Item PowLitNIn changed
if (statePowLitNIn!=“NULL”) ToSerial.sendCommand(“Set PLNO=”+ PowLitNIn.state.toString()+ ‘;’)
rule "PowLitDIn"
Item PowLitDIn changed
if (statePowLitDIn!=“NULL”) ToSerial.sendCommand(“Set PLDO=”+ PowLitDIn.state.toString()+ ‘;’)
rule "PowFulNIn"
Item PowFulNIn changed
if (statePowFulNIn!=“NULL”) ToSerial.sendCommand(“Set PFNO=”+ PowFulNIn.state.toString()+ ‘;’)
rule "PowFulDIn"
Item PowFulDIn changed
if (statePowFulDIn!=“NULL”) ToSerial.sendCommand(“Set PFDO=”+ PowFulDIn.state.toString()+ “;”)
rule "PowTMaxIn"
Item PowTMaxIn changed
if (statePowTMaxIn!=“NULL”) ToSerial.sendCommand(“Set PTMO=”+ PowTMaxIn.state.toString()+ ‘;’)
Services configuration related to the issue
If logs where generated please post these here using code fences:
2018-02-12 23:00:56.652 [INFO ] [e.smarthome.model.script.SerialRules] - Wrong command to parse: Set PLNO
2018-02-12 23:01:00.039 [INFO ] [e.smarthome.model.script.SerialRules] - Wrong command to parse: Set PLNO
2018-02-12 23:01:13.391 [INFO ] [e.smarthome.model.script.SerialRules] - Wrong command to parse: Set PLNO
2018-02-13 03:12:10.558 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.internal.items.ItemUpdater@1854553’ takes more than 5000ms.
2018-02-13 03:35:20.949 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.openhab.core.events.internal.EventBridge@faa03’ takes more than 5000ms.
2018-02-13 03:41:27.186 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.internal.items.ItemUpdater@1854553’ takes more than 5000ms.
2018-02-13 03:45:26.499 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.internal.items.ItemUpdater@1854553’ takes more than 5000ms.
2018-02-13 03:55:30.102 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.openhab.core.events.internal.EventBridge@faa03’ takes more than 5000ms.
2018-02-13 03:57:00.431 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 03:57:14.073 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 03:57:20.422 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.internal.items.ItemUpdater@1854553’ takes more than 5000ms.
2018-02-13 03:57:34.013 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.internal.items.ItemUpdater@1854553’ takes more than 5000ms.
2018-02-13 03:57:46.591 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.internal.items.ItemUpdater@1854553’ takes more than 5000ms.
2018-02-13 03:58:00.128 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.openhab.core.events.internal.EventBridge@faa03’ takes more than 5000ms.
2018-02-13 03:58:26.405 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl@ba51cc’ takes more than 5000ms.
2018-02-13 03:58:32.732 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 03:58:45.283 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.openhab.core.events.internal.EventBridge@faa03’ takes more than 5000ms.
2018-02-13 03:58:52.626 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.internal.items.ItemUpdater@1854553’ takes more than 5000ms.
2018-02-13 03:58:58.923 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 03:59:11.553 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl@ba51cc’ takes more than 5000ms.
2018-02-13 04:00:54.212 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.internal.items.ItemUpdater@1854553’ takes more than 5000ms.
2018-02-13 04:01:40.122 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.internal.items.ItemUpdater@1854553’ takes more than 5000ms.
2018-02-13 04:02:06.142 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.openhab.core.events.internal.EventBridge@faa03’ takes more than 5000ms.
2018-02-13 04:02:32.351 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.openhab.core.events.internal.EventBridge@faa03’ takes more than 5000ms.
2018-02-13 04:02:52.212 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 04:03:43.913 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.openhab.core.events.internal.EventBridge@faa03’ takes more than 5000ms.
2018-02-13 04:04:42.181 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.internal.items.ItemUpdater@1854553’ takes more than 5000ms.
2018-02-13 04:05:14.713 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 04:05:28.311 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 04:05:54.561 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.internal.items.ItemUpdater@1854553’ takes more than 5000ms.
2018-02-13 04:07:36.155 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.openhab.core.events.internal.EventBridge@faa03’ takes more than 5000ms.
2018-02-13 04:08:46.845 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl@ba51cc’ takes more than 5000ms.
2018-02-13 04:09:05.572 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.thing.internal.CommunicationManager@1403428’ takes more than 5000ms.
2018-02-13 04:10:15.317 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 04:10:21.556 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.thing.internal.CommunicationManager@1403428’ takes more than 5000ms.
2018-02-13 04:10:28.879 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.openhab.core.events.internal.EventBridge@faa03’ takes more than 5000ms.
2018-02-13 04:10:41.427 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 04:10:55.002 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.thing.internal.CommunicationManager@1403428’ takes more than 5000ms.
2018-02-13 04:11:13.963 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.internal.items.ItemUpdater@1854553’ takes more than 5000ms.
2018-02-13 04:11:13.975 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.internal.items.ItemUpdater@1854553’ takes more than 5000ms.
2018-02-13 04:11:46.399 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.internal.items.ItemUpdater@1854553’ takes more than 5000ms.
2018-02-13 04:12:18.774 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.thing.internal.CommunicationManager@1403428’ takes more than 5000ms.
2018-02-13 04:12:38.685 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 04:12:57.604 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.internal.items.ItemUpdater@1854553’ takes more than 5000ms.
2018-02-13 04:13:42.729 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.internal.items.ItemUpdater@1854553’ takes more than 5000ms.
2018-02-13 04:14:08.913 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.internal.items.ItemUpdater@1854553’ takes more than 5000ms.
2018-02-13 04:14:28.822 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.thing.internal.CommunicationManager@1403428’ takes more than 5000ms.
2018-02-13 04:14:54.832 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.io.monitor.internal.EventLogger@ae9d23’ takes more than 5000ms.
2018-02-13 04:15:01.108 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.thing.internal.CommunicationManager@1403428’ takes more than 5000ms.
2018-02-13 04:15:14.750 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.internal.items.ItemUpdater@1854553’ takes more than 5000ms.
2018-02-13 04:15:53.433 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 04:16:07.059 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.openhab.core.events.internal.EventBridge@faa03’ takes more than 5000ms.
2018-02-13 04:16:58.355 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.internal.items.ItemUpdater@1854553’ takes more than 5000ms.
2018-02-13 04:17:43.228 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.internal.items.ItemUpdater@1854553’ takes more than 5000ms.
2018-02-13 04:18:21.734 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.internal.items.ItemUpdater@1854553’ takes more than 5000ms.
2018-02-13 04:18:54.062 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.internal.items.ItemUpdater@1854553’ takes more than 5000ms.
2018-02-13 04:19:32.739 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.openhab.core.events.internal.EventBridge@faa03’ takes more than 5000ms.
2018-02-13 04:20:55.399 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 04:21:15.208 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.io.rest.sse.internal.listeners.SseEventSubscriber@126e6d0’ takes more than 5000ms.
2018-02-13 04:22:26.235 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 04:23:11.181 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 04:23:30.999 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 04:23:50.787 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 04:25:51.302 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.thing.internal.CommunicationManager@1403428’ takes more than 5000ms.
2018-02-13 04:27:39.901 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 04:31:14.547 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.internal.items.ItemUpdater@1854553’ takes more than 5000ms.
2018-02-13 04:31:20.785 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.openhab.core.events.internal.EventBridge@faa03’ takes more than 5000ms.
2018-02-13 04:32:06.793 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 04:34:00.671 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 04:34:45.669 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 04:35:56.792 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 04:36:48.092 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 04:38:24.310 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl@ba51cc’ takes more than 5000ms.
2018-02-13 04:39:16.370 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 04:39:48.660 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.thing.internal.CommunicationManager@1403428’ takes more than 5000ms.
2018-02-13 04:41:49.347 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.openhab.core.events.internal.EventBridge@faa03’ takes more than 5000ms.
2018-02-13 04:49:59.832 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘Serial_control’: An error occurred during the script execution: Java heap space
2018-02-13 04:50:50.931 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 04:52:39.310 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 04:55:36.181 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘Serial_control’: An error occurred during the script execution: Java heap space
2018-02-13 04:59:04.131 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘Serial_control’: An error occurred during the script execution: Java heap space
2018-02-13 05:09:03.026 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘Serial_control’: An error occurred during the script execution: Java heap space
2018-02-13 05:10:01.273 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.thing.internal.CommunicationManager@1403428’ takes more than 5000ms.
2018-02-13 05:09:21.721 [ERROR] [org.apache.felix.fileinstall ] - In main loop, we have serious trouble
java.lang.OutOfMemoryError: Java heap space
2018-02-13 05:11:49.868 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 05:12:41.183 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 05:13:07.204 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 05:13:45.762 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl@ba51cc’ takes more than 5000ms.
2018-02-13 05:14:18.157 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 05:15:59.473 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 05:17:10.484 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.internal.items.ItemUpdater@1854553’ takes more than 5000ms.
2018-02-13 05:17:22.959 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 05:18:07.696 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.thing.internal.CommunicationManager@1403428’ takes more than 5000ms.
2018-02-13 05:19:05.304 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 05:20:02.641 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 05:23:36.236 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@d8b9ab’ takes more than 5000ms.
2018-02-13 05:25:05.895 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.openhab.core.events.internal.EventBridge@faa03’ takes more than 5000ms.
2018-02-13 05:28:41.396 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.internal.items.ItemUpdater@1854553’ takes more than 5000ms.
2018-02-13 05:36:14.701 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘Serial_control’: An error occurred during the script execution: Java heap space
2018-02-13 05:37:24.600 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.thing.internal.CommunicationManager@1403428’ takes more than 5000ms.
2018-02-13 05:45:32.716 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘Serial_control’: An error occurred during the script execution: Java heap space
2018-02-13 05:46:11.438 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.internal.items.ItemUpdater@1854553’ takes more than 5000ms.
2018-02-13 05:51:50.352 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.internal.items.ItemUpdater@1854553’ takes more than 5000ms.
2018-02-13 05:58:37.431 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.internal.items.ItemUpdater@1854553’ takes more than 5000ms.
2018-02-13 06:02:10.700 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘Serial_control’: An error occurred during the script execution: Java heap space
2018-02-13 06:42:32.509 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘Serial_control’: An error occurred during the script execution: Java heap space
2018-02-13 06:50:41.323 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.openhab.core.events.internal.EventBridge@faa03’ takes more than 5000ms.
2018-02-13 06:53:31.787 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.internal.items.ItemUpdater@1854553’ takes more than 5000ms.
2018-02-13 06:55:12.741 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.internal.items.ItemUpdater@1854553’ takes more than 5000ms.
2018-02-13 07:17:27.350 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.openhab.core.events.internal.EventBridge@faa03’ takes more than 5000ms.
2018-02-13 07:23:01.006 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.internal.items.ItemUpdater@1854553’ takes more than 5000ms.
2018-02-13 07:43:10.801 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.internal.items.ItemUpdater@1854553’ takes more than 5000ms.
2018-02-13 07:47:54.338 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - java.lang.OutOfMemoryError: Java heap space
