Did you attempt my proposals?
Things to try other than those:
- move to snapshot
- identify the component to probably cause the memleak by deactivating some of the bindings
Do you have the miio binding enabled?
@mstormi I didn’t enable ZRAM because all the warnings from openhabian-config, but I’ll do it right away.
the swapon shows that /var/swap file size is 100M used 0.
I listed the processes (ps -ef) but I didn’t find informations about java:
UID PID PPID C STIME TTY TIME CMD
root 1 0 0 06:19 ? 00:00:06 /sbin/init
root 2 0 0 06:19 ? 00:00:00 [kthreadd]
root 3 2 0 06:19 ? 00:00:00 [rcu_gp]
root 4 2 0 06:19 ? 00:00:00 [rcu_par_gp]
root 8 2 0 06:19 ? 00:00:00 [mm_percpu_wq]
root 9 2 0 06:19 ? 00:00:02 [ksoftirqd/0]
root 10 2 0 06:19 ? 00:00:16 [rcu_sched]
root 11 2 0 06:19 ? 00:00:00 [rcu_bh]
root 12 2 0 06:19 ? 00:00:00 [migration/0]
root 13 2 0 06:19 ? 00:00:00 [cpuhp/0]
root 14 2 0 06:19 ? 00:00:00 [cpuhp/1]
root 15 2 0 06:19 ? 00:00:00 [migration/1]
root 16 2 0 06:19 ? 00:00:00 [ksoftirqd/1]
root 19 2 0 06:19 ? 00:00:00 [cpuhp/2]
root 20 2 0 06:19 ? 00:00:00 [migration/2]
root 21 2 0 06:19 ? 00:00:00 [ksoftirqd/2]
root 24 2 0 06:19 ? 00:00:00 [cpuhp/3]
root 25 2 0 06:19 ? 00:00:00 [migration/3]
root 26 2 0 06:19 ? 00:00:01 [ksoftirqd/3]
root 29 2 0 06:19 ? 00:00:00 [kdevtmpfs]
root 30 2 0 06:19 ? 00:00:00 [netns]
root 32 2 0 06:19 ? 00:00:03 [kworker/1:1-events]
root 34 2 0 06:19 ? 00:00:00 [khungtaskd]
root 35 2 0 06:19 ? 00:00:00 [oom_reaper]
root 36 2 0 06:19 ? 00:00:00 [writeback]
root 37 2 0 06:19 ? 00:00:00 [kcompactd0]
root 38 2 0 06:19 ? 00:00:00 [crypto]
root 39 2 0 06:19 ? 00:00:00 [kblockd]
root 40 2 0 06:19 ? 00:00:00 [watchdogd]
root 42 2 0 06:19 ? 00:00:00 [rpciod]
root 43 2 0 06:19 ? 00:00:00 [kworker/u9:0-hci0]
root 44 2 0 06:19 ? 00:00:00 [xprtiod]
root 47 2 0 06:19 ? 00:00:00 [kswapd0]
root 48 2 0 06:19 ? 00:00:00 [nfsiod]
root 59 2 0 06:19 ? 00:00:00 [kthrotld]
root 60 2 0 06:19 ? 00:00:00 [iscsi_eh]
root 61 2 0 06:19 ? 00:00:00 [dwc_otg]
root 62 2 0 06:19 ? 00:00:00 [DWC Notificatio]
root 63 2 0 06:19 ? 00:00:00 [vchiq-slot/0]
root 64 2 0 06:19 ? 00:00:00 [vchiq-recy/0]
root 65 2 0 06:19 ? 00:00:00 [vchiq-sync/0]
root 66 2 0 06:19 ? 00:00:00 [vchiq-keep/0]
root 68 2 0 06:19 ? 00:00:00 [irq/86-mmc1]
root 71 2 0 06:19 ? 00:00:00 [mmc_complete]
root 75 2 0 06:19 ? 00:00:01 [jbd2/mmcblk0p2-]
root 76 2 0 06:19 ? 00:00:00 [ext4-rsv-conver]
root 77 2 0 06:19 ? 00:00:00 [kworker/1:2H-kblockd]
root 78 2 0 06:19 ? 00:00:01 [kworker/2:1H-kblockd]
root 80 2 0 06:19 ? 00:00:00 [ipv6_addrconf]
root 96 2 0 06:19 ? 00:00:00 [kworker/3:2H-kblockd]
root 97 2 0 06:19 ? 00:00:01 [kworker/0:2H+kblockd]
root 102 1 0 06:19 ? 00:00:01 /lib/systemd/systemd-journald
root 146 1 0 06:19 ? 00:00:01 /lib/systemd/systemd-udevd
root 209 2 0 06:19 ? 00:00:00 [cfg80211]
root 211 2 0 06:19 ? 00:00:00 [brcmf_wq/mmc1:0]
root 213 2 0 06:19 ? 00:00:00 [brcmf_wdog/mmc1]
systemd+ 252 1 0 06:19 ? 00:00:00 /lib/systemd/systemd-timesyncd
root 295 1 0 06:19 ? 00:00:00 /lib/systemd/systemd-logind
message+ 296 1 0 06:19 ? 00:00:00 /usr/bin/dbus-daemon --system -- address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
root 297 1 0 06:19 ? 00:00:00 /usr/sbin/alsactl -E HOME=/run/alsa -s -n 19 -c rdaemon
avahi 298 1 0 06:19 ? 00:00:07 avahi-daemon: running [openhabian.local]
root 304 1 0 06:19 ? 00:00:00 /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant
root 309 1 0 06:19 ? 00:00:00 /usr/sbin/cron -f
root 314 1 0 06:19 ? 00:00:09 /usr/sbin/rngd -r /dev/hwrng
avahi 315 298 0 06:19 ? 00:00:00 avahi-daemon: chroot helper
root 323 1 0 06:19 ? 00:00:00 /usr/sbin/rsyslogd -n -iNONE
root 386 1 0 06:19 ? 00:00:00 wpa_supplicant -B -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0 -Dnl80211,wext
root 407 1 0 06:20 ? 00:00:00 /usr/bin/hciattach /dev/serial1 bcm43xx 921600 noflow - b8:27:eb:81:e2:a7
root 411 2 0 06:20 ? 00:00:00 [kworker/u9:2-hci0]
root 412 1 0 06:20 ? 00:00:00 /usr/lib/bluetooth/bluetoothd
root 482 1 0 06:20 ? 00:00:06 /sbin/dhcpcd -q -w
root 485 1 0 06:20 ? 00:00:00 /usr/bin/python3 /usr/share/unattended-upgrades/unattended-upgrade-shutdown --wait-for-signal
openhab 486 1 27 06:20 ? 02:23:30 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runt
openhab 487 1 0 06:20 ? 00:00:11 node /usr/lib/node_modules/frontail/bin/frontail --ui-highlight --ui-highlight-preset /usr/lib/node_modules/frontail/pre
root 488 1 0 06:20 ? 00:00:09 /usr/sbin/nmbd --foreground --no-process-group
mosquit+ 489 1 0 06:20 ? 00:00:28 /usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf
root 497 1 0 06:20 tty1 00:00:00 /sbin/agetty -o -p -- \u --noclear tty1 linux
root 535 1 0 06:20 ? 00:00:00 /usr/sbin/sshd -D
root 628 1 0 06:20 ? 00:00:00 /usr/sbin/smbd --foreground --no-process-group
root 654 628 0 06:20 ? 00:00:00 /usr/sbin/smbd --foreground --no-process-group
root 655 628 0 06:20 ? 00:00:00 /usr/sbin/smbd --foreground --no-process-group
root 660 628 0 06:20 ? 00:00:00 /usr/sbin/smbd --foreground --no-process-group
openhab 724 487 0 06:20 ? 00:00:00 tail -n 200 -F /var/log/openhab2/openhab.log /var/log/openhab2/events.log
root 824 2 0 13:58 ? 00:00:00 [kworker/0:1H]
root 1332 2 0 14:05 ? 00:00:00 [kworker/1:1H]
root 1400 2 0 14:06 ? 00:00:00 [kworker/u8:1-events_unbound]
root 1803 2 0 14:12 ? 00:00:00 [kworker/2:0-mm_percpu_wq]
root 1818 2 0 14:12 ? 00:00:00 [kworker/1:2-cgroup_destroy]
root 1983 2 0 14:14 ? 00:00:01 [kworker/0:0-events]
root 2416 2 0 14:21 ? 00:00:00 [kworker/3:1H]
root 3177 2 0 14:33 ? 00:00:00 [kworker/0:2-events_power_efficient]
root 4554 2 0 14:54 ? 00:00:00 [kworker/3:0-mm_percpu_wq]
root 4615 2 0 14:55 ? 00:00:00 [kworker/2:0H]
root 4927 2 0 14:59 ? 00:00:00 [kworker/3:1-mm_percpu_wq]
root 5235 2 0 15:05 ? 00:00:00 [kworker/u8:0]
root 5273 2 0 15:05 ? 00:00:00 [kworker/2:2H]
root 5277 535 1 15:05 ? 00:00:00 sshd: openhabian [priv]
root 5300 2 0 15:05 ? 00:00:00 [kworker/3:2-events]
root 5308 2 0 15:05 ? 00:00:00 [kworker/2:2-rcu_gp]
openhab+ 5309 1 2 15:05 ? 00:00:00 /lib/systemd/systemd --user
openhab+ 5312 5309 0 15:05 ? 00:00:00 (sd-pam)
openhab+ 5326 5277 0 15:05 ? 00:00:00 sshd: openhabian@pts/0
openhab+ 5329 5326 3 15:05 pts/0 00:00:00 -bash
root 5727 2 0 15:05 ? 00:00:00 [kworker/0:1]
root 5730 2 0 15:05 ? 00:00:00 [kworker/0:0H]
openhab+ 5731 5329 0 15:05 pts/0 00:00:00 ps -ef
root 12855 1 0 09:09 ? 00:00:00 /usr/lib/policykit-1/polkitd --no-debug
root 15152 2 0 09:24 ? 00:00:01 [kworker/2:1-rcu_gp]
root 32684 2 0 13:51 ? 00:00:00 [kworker/u8:2-events_unbound]
I’ll post the results as soon as get any updates.
Thanks in advance!
Paulo
Duh, so you’ve got 1.1G in total… that’s not enough. Increase swap if you can (you can add another swapfile). But ZRAM is even better.
Please read Marcel’s recommendations.
Another user tracked it to the new miio cloud connection and faulty configuration.
@mstormi just enabled ZRAM, I’ll be monitoring the RPI for the next hours to see if there will be any problem… if it doesn’t work, I’ll try to increase swap…
Well if your system outgrows your virtual mem you have a memleak. With more swap and ZRAM you’ll hit the limit later but you still will hit it, so go find the component that causes it.
I fixed a thread leaking in the miio binding this week. So please try a setup without the miio binding.
The fix will be in next version 2.5.5.
I think that more of less 30% of the lights at home uses this binding. However after I installed zram as @mstormi suggested, so far I didn’t have any problems… Before I had to reboot every 9 hours and now it is running for about 30 hours. But in order to give a final word I’ll see if there’s something happening within the next days… I’ll keep you posted…
Is this thread leaking available in openhab 2.5.0 (stable) ?
As I said, I fixed this issue this week, so of course it is not included in 2.5.0. It will be included in next version, 2.5.5.
My mistake… What I meant was…
Is the issue with the thead leaking in the 2.5.0 ?
It is probably since a long time, maybe since the first day ? Sorry, I don’t know exactly.
Okay… Will the jar be available?
I heard 2.5.5 will likely get released soon.
For the 2.5.5 snapshot : https://ci.openhab.org/job/openHAB2.5.x-Addons/ws/bundles/org.openhab.binding.miio/target/org.openhab.binding.miio-2.5.5-SNAPSHOT.jar
@mstormi after 8 more hours the system stalled because of the memory full. You were right because of zram, openhab could stay longer but at the end I had to reboot the rpi…
Just upgraded to 2.5.5, I’ll monitor the performance of the RPI. I hope this upgrade will solve the thread issue!!
Best regards,
Paulo
After 8 days running with no flaws, just wanted to report that the 2.5.5 version solved the thread problem!
Thanks everyone for the support!
Paulo
