When I try to debug some rule in openHAB, I often need the logs from events.log
and openhab.log
But it is often annoying to “synchronize” these logs afterwards.
events.log
2022-01-27 12:20:28.185 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'TestItem1' changed from OFF to ON
2022-01-27 12:21:01.016 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'TestItem1' changed from ON to OFF
openhab.log
2022-01-27 12:20:44.386 [INFO ] [penhab.core.model.script.Media_Scene] - TestRule executed
My goal is one file where all messages are listed chronologically.
You can achieve this with this little shell command:
sort -nbms -k1.1,1.4 -k1.6,1.7 -k1.9,1.10 -k1.12,1.13 -k1.15,1.16 -k1.18,1.19 -k1.21,1.23 events.log openhab.log
I created a simple script to generate a new file with the current timestamp.
_merged_logs.sh
#!/bin/bash
sort -nbms -k1.1,1.4 -k1.6,1.7 -k1.9,1.10 -k1.12,1.13 -k1.15,1.16 -k1.18,1.19 -k1.21,1.23 events.log openhab.log > _merged_logs_$(date "+%Y%m%d-%H%M").log
source:
real time synchronization
If you want to view the logs synchronized in real time you can use multitail.
# one top, one bottom
multitail events.log openhab.log
# synchronized
multitail events.log -I openhab.log
# synchronized, two colors
multitail -ci red events.log -ci yellow -I openhab.log
For cool syntax highlighting see:
