Meross: python library with mqtt
Hello, everybody. First of all, thank you very much for this nice tutorial. I was able to follow more or less everything and I think almost everything works, but since the Meross plug is only the second thing I implemented in Openhab, I have some basic problems with the connection between OH and the plug.
So I have an item in OH and I can switch the “plug” on and off and I also get the message in MQTT.fx “meross/device_name = OFF”, but the real plug does not switch off. I also used the examples from GitHub - albertogeniola/MerossIot: Async Python library for controlling Meross devices and was able to switch the plug off with putty and ssh. The meross2mqtt.service is also running.
Now I cannot get connections from OH to the ms310 plug. Do I need to add anything before which is basic and not mentioned here? How does OH know where the Python script is located? Is there something like in the exec-binding where I have to write the path or something like that?
Thanks for your help!
