Hi all,
OH 3.1.0 newbie here, trying to control my Z-Wave devices …
One 50x5xx Roller shutter push-button works, one doesn’t (same IDs: 4004:0001)
- works: zwave_version 2.3, zwave_class_specific SPECIFIC_TYPE_NOT_USED
https://drive.google.com/file/d/1cq3G3FhUaGoM4JZr2dUsG_GbVvacdnfW/view?usp=sharing - doesn’t work: zwave_version 1.5, zwave_class_specific SPECIFIC_TYPE_SIMPLE_WINDOW_COVERING
https://drive.google.com/file/d/116RnAWqHB-VyuwjpdLkZHU4Y1nN-ZANt/view?usp=sharing
Both shutters look the same in the UI, nothing happens when I press the up/down buttons of the shutter with Z-Wave version 1.5.
Is there anything I (or the community) can do to get the older shutter button working?
Edit:
additional information from the log:
00:22:19.073 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘ZWaveNode00950x5xxRollershutterpushbutton_BlindsControl’ received command UP
00:22:19.079 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘ZWaveNode00950x5xxRollershutterpushbutton_BlindsControl’ predicted to become UP
00:22:19.084 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘ZWaveNode00950x5xxRollershutterpushbutton_BlindsControl’ changed from 100 to 0
00:22:19.089 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 9: Command received zwave:device:b1ca481a57:node9:blinds_control → UP [UpDownType]
00:22:19.090 [DEBUG] [verter.ZWaveMultiLevelSwitchConverter] - NODE 9: Command class SWITCH_MULTILEVEL not found when processing command on endpoint 0
00:22:19.091 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 9: No messages returned from converter
00:22:22.480 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘ZWaveNode00950x5xxRollershutterpushbutton_BlindsControl’ received command DOWN
00:22:22.485 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘ZWaveNode00950x5xxRollershutterpushbutton_BlindsControl’ predicted to become DOWN
00:22:22.487 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 9: Command received zwave:device:b1ca481a57:node9:blinds_control → DOWN [UpDownType]
00:22:22.488 [DEBUG] [verter.ZWaveMultiLevelSwitchConverter] - NODE 9: Command class SWITCH_MULTILEVEL not found when processing command on endpoint 0
00:22:22.489 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 9: No messages returned from converter
00:22:22.490 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘ZWaveNode00950x5xxRollershutterpushbutton_BlindsControl’ changed from 0 to 100
00:22:26.049 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘ZWaveNode00950x5xxRollershutterpushbutton_BlindsControl’ received command STOP
00:22:26.054 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 9: Command received zwave:device:b1ca481a57:node9:blinds_control → STOP [StopMoveType]
00:22:26.055 [DEBUG] [verter.ZWaveMultiLevelSwitchConverter] - NODE 9: Command class SWITCH_MULTILEVEL not found when processing command on endpoint 0
00:22:26.055 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 9: No messages returned from converter
TIA,
Ap15e
