Does anyone know of a theme I can load on my HabPanel that essentially is a more white based theme? something like this:
R
R
I can’t answer your question, but I’ve changed the category so that you can hopefully get more visibility. The “Tutorials & Examples” categories are for people to share their work.
It’s important to be clear here. Do you really mean HABPanel? The answer is different if you are calling MainUI or Basic UI HABPanel, which is a common confusion.
Assuming you do mean HABPanel, open your panel, click the “hamburger” menu at the top left, then click the gear icon at the bottom right.
Under “Appearance” there is a a “Theme” option where you have seven themes to choose from. The “Material” theme looks similar to your screenshot above.
