I have a Water Fountain from Xiaomi Mi and I use the Xiaomi Wifi devices (Mi IO) Binding.
The binding has detected the device via the cloud login, but the channel “Power” does not work.
It shows in the log
2023-02-25 10:48:01.435 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'kitchen_fountain_xiaomi' changed from OFF to ON
, but the device does not stop or start.
Can anybody help?
I have also started the testing channel and here is the result:
2023-02-25 10:48:44.665 [INFO ] [ernal.handler.MiIoUnsupportedHandler] - Start experimental testing of supported properties for device 'Unknown Mi IO Device (unknown)'.
2023-02-25 10:48:44.675 [INFO ] [ernal.handler.MiIoUnsupportedHandler] - Info for mmgg.pet_waterer.wi11
Properties: battery -> 1499, pm25 -> 1500, co2e -> 1501, tvoc -> 1502, humidity -> 1503, temperature -> 1504, get_value["battery"] -> 1505, co2 -> 1506, bt_gateway_status -> 1507, /device/get_bledevice_by_gateway -> 1508, power -> 1509, wifi_led -> 1510, usb_on -> 1511, on -> 1512, OnOff_State -> 1513, Humidifier_Gear -> 1514, Humidity_Value -> 1515, HumiSet_Value -> 1516, Led_State -> 1517, TipSound_State -> 1518, watertankstatus -> 1519, wet_and_protect -> 1520, mode -> 1521, ptc_on -> 1522, ptc_status -> 1523, display -> 1524, child_lock -> 1525, sound -> 1526, control_speed -> 1527, favourite_speed -> 1528, temperature_outside -> 1529, filter_rate -> 1530, filter_day -> 1531, ptc_level -> 1532, screen_direction -> 1533, filter_intermediate -> 1534, filter_inter_day -> 1535, filter_efficient -> 1536, filter_effi_day -> 1537, roll -> 1538, roll_angle -> 1539, timer_off -> 1540, beep_sound -> 1541, light -> 1542, speed -> 1543, dry -> 1544, led -> 1545, motor -> 1546, drytime -> 1547, airer_location -> 1548, disinfect -> 1549, distime -> 1550, on_off -> 1551, auto -> 1552, fan_speed -> 1553, buzzer -> 1554, temp -> 1555, tank_full -> 1556, compressor_status -> 1557, defrost_status -> 1558, fan_st -> 1559, alarm -> 1560, bright -> 1561, cct -> 1562, snm -> 1563, dv -> 1564, sw -> 1565, bl -> 1566, ms -> 1567, ac -> 1568, mb -> 1569, cid -> 1570, get_switch_en -> 1571, scene_num -> 1572, pow -> 1573, flm -> 1574, ambstatus -> 1575, ambvalue -> 1576, dvalue -> 1577, eyecare -> 1578, power_consume_rate -> 1579, power_price -> 1580, current -> 1581, lp_autooff -> 1582, lp_autooff_delay -> 1583, lp_threshold -> 1584, switch1 -> 1585, switchname1 -> 1586, switch2 -> 1587, switchname2 -> 1588, switch3 -> 1589, switchname3 -> 1590, true -> 1591, run_state -> 1592, err_state -> 1593, battary_life -> 1594, box_type -> 1595, mop_type -> 1596, mop_route -> 1597, s_time -> 1598, s_area -> 1599, suction_grade -> 1600, water_grade -> 1601, remember_map -> 1602, has_map -> 1603, is_mop -> 1604, has_newmap -> 1605, washStatus -> 1606, velocity -> 1607, waterTemp -> 1608, targetTemp -> 1609, errStatus -> 1610, hotWater -> 1611, needClean -> 1612, modeType -> 1613, appointStart -> 1614, appointEnd -> 1615, seat_temp -> 1616, status_seatheat -> 1617, water_temp_t -> 1618, fan_temp -> 1619, status_led -> 1620, bh_mode -> 1621, delayoff -> 1622, nl_br -> 1623, ct -> 1624, rgb -> 1625, color_mode -> 1626, flowing -> 1627, name -> 1628, bg_bright -> 1629, bg_power -> 1630, bg_rgb -> 1631, bg_ct -> 1632, bg_lmode -> 1633, run_status -> 1634, rinse -> 1635, tds_in -> 1636, tds_out -> 1637, f1_totalflow -> 1638, f1_totaltime -> 1639, f1_usedflow -> 1640, f1_usedtime -> 1641, f2_totalflow -> 1642, f2_totaltime -> 1643, f2_usedflow -> 1644, f2_usedtime -> 1645, f3_totalflow -> 1646, f3_totaltime -> 1647, f3_usedflow -> 1648, f3_usedtime -> 1649, f4_totalflow -> 1650, f4_totaltime -> 1651, f4_usedflow -> 1652, f4_usedtime -> 1653, maintenance_state -> 1654, maintenance_interval -> 1655, tds_warn_thd -> 1656, tds_out_avg -> 1657, lightMode -> 1658, ptc_state -> 1659, aqi -> 1660, average_aqi -> 1661, f1_hour_used -> 1662, use_time -> 1663, motor1_speed -> 1664, led_level -> 1665, temp_dec -> 1666, usb_state -> 1667, time_state -> 1668, night_state -> 1669, night_beg_time -> 1670, night_end_time -> 1671, f1_hour -> 1672, filter1_life -> 1673, favorite_level -> 1674, purify_volume -> 1675, act_det -> 1676, volume -> 1677, motor2_speed -> 1678, angle_enable -> 1679, angle -> 1680, poweroff_time -> 1681, led_b -> 1682, speed_level -> 1683, natural_level -> 1684, ac_power -> 1685, bat_charge -> 1686, target_temperature -> 1687, brightness -> 1688, relative_humidity -> 1689, theqmostat -> 1690, limit_hum -> 1691, trans_level -> 1692, depth -> 1693,
