Hi i have some trouble with my iBox2 (bridgeV6) and an FUT036 (Dimmer).
If i used the Mi-Light Smartphone App, i can Controll the Dimmer. If I Use the Mi-light binding and the follwing Config, i cant use the Dimmer.
You have the light linked to a Switch. Switches only support ON and OFF. Use a Dimmer type instead of Switch and it will support dimmer commands (which include ON and OFF).
