Is it possible to use the audio sink of the gateway at the moment?
As I see, thereās no solution yet, lamp is not yeelight, so no gateway, what a bummer.
Sorry, I donāt understand. Im talking about he build ind speaker that normally speaks chinese to you. On the app you can play different sounds and radio.
Hi reinstalled the binding and now I have problems with my plug and the lights in the gateway not reponding. I get date from the units and can trigger rules with e.g. the magic cube, but sending commands to them does not work any more. No info in the log eighter.
Can anyone help?
Please did any one try this? and help? I made a new key for the item and tested it several times, once I plug turn off but then stopped repondingā¦ nothing to be found that is iregular in log files
Hello!
When you update the openhab2, the binding is deleted. Have to install again. Is this normal behavior?
Thank you!
Apologies if this has been asked but I am unable to find it. Do I need to purchase the Gateway / Bridge in order for this binding to work?
Essentially I would like to buy some of the wifi wall plug switches and a few of these Xiaomi wifi lights, will these work find using just Openhab2 and my wifi connection without any other hub?
Thank you kindly
@Moellegaard no AudioSink at the moment, since the documentation doesnāt specify the way to handle audio streams (i.e. radio). Hopefully itāll happen in the future.
@theo69 I bought the wired wall switch but didnāt test it yet. It is supported already by the binding so you may try it yourself
@Olymp yeah, itās the nature of ESH Marketplace Add-on - you need to install the marketplace bindings again after each update.
@Lewis yes, at the moment you need the Xiaomi Gateway. Just make sure you have at least Gateway v2 (with radio support), because the older one doesnāt support the developer mode.
Xiaomi sensors/devices are essentially ZigBee-based, but the only way to make them talk to the openHAB ecosystem is to connect them with (cloud based) Gateway.
@chris makes some great progress with the ZigBee binding, however I donāt think itās possible now to integrate Xiaomi devices with it.
Thanks it worked!!!
Hi to allā¦
someone can help me? Iām trying to add this binding to my OH but I donāt see it in the paper UI. At the console appear if a type bundle:list
ā185 | Active | 80 | 2.1.0.201704270648 | Xiaomi Mi Smart Home Bindingā
but nothing elseā¦
My OH is runing the beta 2.1.0 in a linux machine with Arch and I put the jar in ā/etc/openhab/addons/ā
Thanks to allā¦
You need to install the Misc>Eclipse IoT Market Add-On first, and then it will appear in the available bindings.
Itās also worth noting that every time you do an update to OH you will need to reinstall this binding again as you cannot set it in the addons.cfg file to automatically reinstall.
Done!!! Thanks a lot!!!
I have 18 Items and I can confirm that last Snapshot has an issue.
I try use it on fresh OH 2.1 but after some time most of devices are appear as OFFLINE.
218 | Active | 80 | 2.1.0.201704221211 | Xiaomi Mi Smart Home Binding - Works fine for me now only
I downloaded binding from here:
https://openhab.jfrog.io/openhab/libs-pullrequest-local/org/openhab/binding/org.openhab.binding.mihome/2.1.0-SNAPSHOT/
But I still have some issues:
- Window Switch
It does not update status until I Open/Close the windows. I leave it a couple of day without get it updated, as soon Iāll opened the windows. - Motion Sensor
It update last motion date/time, but only when movement is detected. If i restart openhab and no movement detected this value do not update. Motion Status is always to ON. I setup motionOffTimer to 5 (is this seconds?) - Temperature Sensor works fine, it update values sometime after OpenHab restarted
- Switch work fine and I can use click, double click and long click
Many thanks for help
Marco
please consider, that as there is still development going on things change a lot. so it can be, that your config for the older snapshot does not work with the new one anymore.
@marcolino7
please use a persistence service in OH to store values and restore them after restart.
- Window switches only update their state, when there is a state change (heartbeats still do not report correct states, perhaps will be fixed in future firmware updates from xiaomi)
- see above
- see above
- at least no problem here
Hi @dimalo,
thanks for explanation, Iāll setup persistence.
Only open poin, is second part of point 2:
āMotion Status is always to ON. I setup motionOffTimer to 5 (is this seconds?)ā
Can you help me to troubleshoot?
Hello All,
I have OH 2.1 (almost two months old snapshot) with market plugin) and just purchased and installed the binding through the market.
I added the devices through the app to the gateway, but i canāt find them through the discovery.
Only the gateway and bridge were discovered, but the temp sensor and the wireless switch werenāt.
I tried to add them manually but they appear always offline.
Any advices for a beginner with this binding?
Never mind guys, after three restarts of Openhab it worked
Many thanks for the great bindingā¦
on gearbest there is in promo this Temperature sensor called Aquara:
Is this compatible with gateway and binding? My other temperature sensor are round this are squared
Iām new to OpenHab but I have setup internal Hikvision webcams controlled using an iPhone app, batch scripts and a Amazon Dash button.
I am now looking to monitor the humidity of my house. I am looking at Xiaomi (other suggestions welcome!) as it is battery powered and well built.
however I am hoping to use OpenHab to get the humidity of my house and send me an alert if it goes over a certain value. I am looking to not need to buy the Mi Hub and control everything fro my server using scripts using HTTP commands or API. Is this possible?
thanks in advance!
