yes guys. Sorry for that. the new events are more OH style so we changed them.
also the battery channels are different now. showing values from 0-100%
please have a look in the readme and check your settings and rules.
its also recommended to remove all things and readd everything again.
then all the channels and settings are right.
I would like to purchase some XIAOMI products and add them to OpenHAB2.
Could you confirm me that I need at least a Xiaomi Gateway that comunicates to openhab via WiFi. Is that correct?
Which gateway do I need?
Thanks!
Simon
Today i made an update to the latest snapshot version of OH 2.2. I had installed snapshot 2.1 (or 2.2) on june 29th the last time.
Now i don´t get any values from xiaomi any more.
On Paper UI Configuration-Things i can see âuninitializedâ and inside the thing i see âuninitialized - handler_initializing_errorâ.
Anybody knows something about? What can i do? I configured my xiaomi thing new when i installed the latest snapshot a week ago and i changed to manuyl config of the things. It worked until the update of the snapshot i made today.
I have similar problem. Initially I installed market:binding and configured everything. After each OH2 snapshot update I have to reinstall this binding and after several reinstallations I stopped to receive battery level from sensors (didnât have time to investigate this problem) . After binding-mihome announcement I migrated to it and everything is OK but after last OH2 snapshot update I got the same status âuninitialized - handler_initializing_errorâ reinstallations and reboots didnât help. Iâve rolled back to market:binding and it started to work again (except battery level and wireless switch also stopped to work). Hope will have time to investigate these problems during weekend
Similar issue. Openhab 2.2 lattest snapshot upgraded. Removed the mihome JAR file. Restarted Openhab2. Installed the binding from the Addon --> Binding. The things moved to uninitialized status. Removed the Gatway thing. But it can not be rediscover it again. From log:
2017-07-05 16:13:56.731 [DEBUG] [nternal.DiscoveryServiceRegistryImpl] - Triggering scan for thing types '[mihome:bridge]' on 'XiaomiBridgeDiscoveryService'...
2017-07-05 16:13:56.732 [DEBUG] [scovery.XiaomiBridgeDiscoveryService] - Stop scan
2017-07-05 16:13:56.744 [ERROR] [nternal.DiscoveryServiceRegistryImpl] - Cannot trigger scan for thing types '[mihome:bridge]' on 'XiaomiBridgeDiscoveryService'!
java.lang.NullPointerException
at org.openhab.binding.mihome.internal.socket.XiaomiDiscoverySocket.setupSocket(XiaomiDiscoverySocket.java:45)
at org.openhab.binding.mihome.internal.socket.XiaomiSocket.<init>(XiaomiSocket.java:68)
at org.openhab.binding.mihome.internal.socket.XiaomiDiscoverySocket.<init>(XiaomiDiscoverySocket.java:32)
at org.openhab.binding.mihome.internal.discovery.XiaomiBridgeDiscoveryService.startScan(XiaomiBridgeDiscoveryService.java:60)
at org.eclipse.smarthome.config.discovery.AbstractDiscoveryService.startScan(AbstractDiscoveryService.java:199)
at org.eclipse.smarthome.config.discovery.internal.DiscoveryServiceRegistryImpl.startScan(DiscoveryServiceRegistryImpl.java:392)
at org.eclipse.smarthome.config.discovery.internal.DiscoveryServiceRegistryImpl.startScans(DiscoveryServiceRegistryImpl.java:377)
at org.eclipse.smarthome.config.discovery.internal.DiscoveryServiceRegistryImpl.startScan(DiscoveryServiceRegistryImpl.java:221)
at org.eclipse.smarthome.io.rest.core.discovery.DiscoveryResource.scan(DiscoveryResource.java:86)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)[:1.8.0_65]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)[:1.8.0_65]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)[:1.8.0_65]
at java.lang.reflect.Method.invoke(Method.java:497)[:1.8.0_65]
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81)[162:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144)[162:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161)[162:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160)[162:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99)[162:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389)[162:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347)[162:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102)[162:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326)[162:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271)[161:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267)[161:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315)[161:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297)[161:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267)[161:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317)[161:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305)[162:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154)[162:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473)[159:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427)[159:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388)[159:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341)[159:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228)[159:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76)[13:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:812)[85:org.eclipse.jetty.servlet:9.2.19.v20160908]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:587)[85:org.eclipse.jetty.servlet:9.2.19.v20160908]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71)[176:org.ops4j.pax.web.pax-web-jetty:4.3.0]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)[84:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)[83:org.eclipse.jetty.security:9.2.19.v20160908]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)[84:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127)[84:org.eclipse.jetty.server:9.2.19.v20160908]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:287)[176:org.ops4j.pax.web.pax-web-jetty:4.3.0]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)[85:org.eclipse.jetty.servlet:9.2.19.v20160908]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)[84:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061)[84:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)[84:org.eclipse.jetty.server:9.2.19.v20160908]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80)[176:org.ops4j.pax.web.pax-web-jetty:4.3.0]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)[84:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.Server.handle(Server.java:499)[84:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:311)[84:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257)[84:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:544)[75:org.eclipse.jetty.io:9.2.19.v20160908]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)[87:org.eclipse.jetty.util:9.2.19.v20160908]
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)[87:org.eclipse.jetty.util:9.2.19.v20160908]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_65]
Uninstalled from the gui, moved back the JAR version, and now the discovery working, and everything get back.
I removed xiaomi binding in the paper ui (uninstalling) and copied back an old jar-file to the addon-directory. After restart of openhab, xiaomi-binding is âinstalledâ again in paper ui.
Do i have to remove xiaomi from addons.cfg too? Or can i simply uninstall only with paper ui and no additional manual work?
Hi, I just reinstalled Openhan 2.1 after playing around with an other automation system.
I have a setup of with the gateway 2, with buttoms, door sensors, cube, motion sensor, zigbee and wifi plug.
I take it wifi plug doesnât work with this binding but I have problems with my plug, everything else is working, also the sound and light from the gateway.
When I try to switch off the plug this happens (from karaf:)
21:59:20.000 [INFO ] [marthome.event.ItemStateChangedEvent] - XiaomiMiSmartSocketPlug_Power changed from ON to OFF
21:59:21.572 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âXiaomiPlugâ received command OFF
21:59:21.580 [INFO ] [marthome.event.ItemStateChangedEvent] - XiaomiPlug changed from ON to OFF
21:59:21.593 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occurred while calling handler: java.lang.NullPointerException
java.util.concurrent.ExecutionException: java.lang.NullPointerException
at org.eclipse.smarthome.core.common.SafeMethodCaller.executeDirectly(SafeMethodCaller.java:220)[98:org.eclipse.smarthome.core:0.9.0.b5]
at org.eclipse.smarthome.core.common.SafeMethodCaller.callAsynchronous(SafeMethodCaller.java:189)[98:org.eclipse.smarthome.core:0.9.0.b5]
at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:83)[98:org.eclipse.smarthome.core:0.9.0.b5]
at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:67)[98:org.eclipse.smarthome.core:0.9.0.b5]
at org.eclipse.smarthome.core.thing.internal.ThingManager.receiveCommand(ThingManager.java:374)[105:org.eclipse.smarthome.core.thing:0.9.0.b5]
at org.eclipse.smarthome.core.items.events.AbstractItemEventSubscriber.receive(AbstractItemEventSubscriber.java:47)[98:org.eclipse.smarthome.core:0.9.0.b5]
at org.eclipse.smarthome.core.internal.events.OSGiEventManager$1.call(OSGiEventManager.java:192)[98:org.eclipse.smarthome.core:0.9.0.b5]
at org.eclipse.smarthome.core.internal.events.OSGiEventManager$1.call(OSGiEventManager.java:1)[98:org.eclipse.smarthome.core:0.9.0.b5]
at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:181)[98:org.eclipse.smarthome.core:0.9.0.b5]
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_121]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_121]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_121]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_121]
Caused by: java.lang.NullPointerException
@Moellegaard, I had the same problem. I reinstalled using OpenHabian and the latest version 2.1. My workaround is to remove the Mi Home binding from Paper UI\Add-ons\Bindings and then manually added the binding from https://github.com/openhab/openhab2-addons/pull/2416 (the third entry down) into the openhab2-addons directory. That seems to work. It looks like the latest fix by @dimalo didnât get propagated to the official binding release.
Okay, I deleted the zip files and uninstalled the xiaomi binding in paper UI.
I did add anything to the addons.cfg. I was thinging I only needed to add it to the addons folder.
if I add something to the addons.cfg, I need to add all my bindings right? or else it will uninstall the ones that I donât use.
What do I need to add to the cfg?
the name of my downloaded binding is:
org.openhab.binding.mihome-2.2.0-SNAPSHOT.jar
Is it a problem that I run the 2.1 version of openhab?
(I had problems upgrading)
You only have to add bindings to the addons.cfg if you install them with paper ui. But i don´t know if it will be uninstalled if there is nothing isnide or if it will be installed, if you write something inâŚ
If you manually add a file to the addons-folder, you don´t have to add something to addons.cfg.
I think it should run with 2.1 too.
I don´t know if the version you downloaded is also corrupted like the version from the openhab-installation. I installed an old version from end of june manually and this is working.
