TheChrissi1
(Christian Wolf)
September 18, 2018, 8:42am
1
Hey Guys,
it is possible to stream the microphone audio from a selected default input device in the Paper UI to a connected Speaker.
So what i want to do is, to stream the audio form the microphone to the webaudio source when i press a button in the sitemap. Is that even possible?
Is there already an existing variable that i can use like the following example?
playStream("webaudio","microphoneaudiostream")
Or do i need to stream the microphone audio to a specific URL in order to get an audiostream?
playStream("webaudio","http://examplemicrophoneaudiostream.com")
Thanks in advance for all your help!
vzorglub
(Vincent Regaud)
September 18, 2018, 1:44pm
2
I think that will be the solution.
KidSquid
(The Squid)
September 18, 2018, 2:56pm
3
Just be aware of the inherent delay in streaming…it might be a couple of seconds or longer
TheChrissi1
(Christian Wolf)
September 18, 2018, 6:14pm
4
Thank you for your help so far.
I found some posts about streaming the microphone audio to a HTTP URL.
https://ubuntuforums.org/showthread.php?t=1544946
I will test this and inform you if it worked .
So far I testet the playStream
option with a HTTP Radio Stream but i can’t get it to play through the webaudio
For example if I use
playStream("http://www.iloveradio.de/ilove2dance.m3u")
the sound plays through the speakers that are connectet with the soundcard audio jack (which I set as default in the Paper UI (System Speaker (with mp3 support))
), but when I use the following command:
playStream("webaudio","http://www.iloveradio.de/ilove2dance.m3u")
the sound does not play through the Web UI.
Even when i select the webaudio
as default in the Paper UI the first example won’t work.
So the audio URL works, but not over the Web UI?!
mic_test
(mic test)
June 26, 2023, 5:10pm
5
An Essential Tool for Checking Technical Issues on Your Microphone
https://www.mictest.co/
