Hi all, I had this setup running just fine and then literally it just stopped updating. I’ll explain…
I have two pi’s running. One is the main pi and then one in a greenhouse (right next door) that is a pi zero. The pi zero just has the mqtt and miflora setup. It connects to the sensors and sends the data through mqtt just fine. it publishes to the same ip/broker as the main pi,
[2021-10-13 11:52:10] Connecting to MQTT broker ...
[2021-10-13 11:52:10] MQTT connection established
Adding sensor to device list and testing connection ...
Internal name: "Sensor1"
Device name: "Flower care"
MAC address: C4:7C:8D:67:59:ED
Firmware: 3.3.1
[2021-10-13 11:52:13] Initial connection to Mi Flora sensor "Sensor1" (C4:7C:8D:67:59:ED) successful
Internal name: "Sensor4"
MAC address: C4:7C:8D:67:5B:1F
Firmware: 3.3.1
[2021-10-13 11:52:16] Initial connection to Mi Flora sensor "Sensor4" (C4:7C:8D:67:5B:1F) successful
[2021-10-13 11:52:16] Announcing Mi Flora devices to MQTT broker for auto-discovery ...
[2021-10-13 11:52:16] Retrieving data from sensor "Sensor1" ...
[2021-10-13 11:52:25] Result: {"light": 95, "temperature": 14.6, "moisture": 7, "conductivity": 0, "battery": 100}
[2021-10-13 11:52:25] Publishing to MQTT topic "miflora/Sensor1"
[2021-10-13 11:52:26] Retrieving data from sensor "Sensor4" ...
[2021-10-13 11:52:30] Result: {"light": 3, "temperature": 14.6, "moisture": 14, "conductivity": 47, "battery": 45}
[2021-10-13 11:52:30] Publishing to MQTT topic "miflora/Sensor4"
Nothing is showing in the log for the pi zero. Earlier I would get the confirmation that the message had come across like this:
2021-10-12 14:53:02.208 [INFO ] [openhab.event.ChannelTriggeredEvent ] - mqtt:broker:b57b164b67:sensor_4 triggered {"light": 902, "temperature": 17.9, "moisture": 0, "conductivity": 0, "battery": 100}
2021-10-12 14:53:02.231 [INFO ] [openhab.event.ChannelTriggeredEvent ] - mqtt:broker:b57b164b67:sensor_1 triggered {"light": 902, "temperature": 17.9, "moisture": 0, "conductivity": 0, "battery": 100}
Those numbers look the same because I had the same topic setup. Now fixed.
On the pi zero the mqtt broker is online and i have two channels, Sensor 1 and Sensor 2. They are both setup as “Triggers” and publish to a topic like this:
miflora/Sensor4
when that publishes of course it is on the same mqtt broker as the main pi and I have all my channels and things setup there to publish to a sitemap. again, all that worked fine. yesterday afternoon it just stopped publishing the updates to the pi zero log. I rebooted no joy. i test whether the miflora is running it is as you see in the log above but it does not publish in the openhab log and nothing is updating in the sitemap. Its like its running on the pi just publishing but not transitioning to openhab for lack of better description.
thoughts?
thanks!
