I have installed a separate Mosquitto broker on another rpi
On the openhab rpi:
I have installed “binding-mqtt - 2.5.0.RC1”
I have configured a broker thing as bridge using my Mosquitto broker, all default no auth
Tasmota mqtt configured to sub/pub to Mosquitto server
I have configured a tasmota thing added as Generic MQTT using the Mosquitto bridge
I have configured a channel with state and command topic (stat/tasmota/power cmnd/tasmota power)
I am able to switch the tasmota via paper UI control, logs arrives to open hab log
Using miflora daemon to collect the data, and publish to Mosquitto.
I have configured a miflora thing added as Generic MQTT using the Mosquitto bridge
I have configured a channel with state topic
No info matched by openhab
No info in logs
I have configured a thing added as Generic MQTT using the Mosquitto bridge
I have configured a channel to sub all(#) topic
I am able to receive the tasmota mqtt messages, nothing from miflora
I have added Mosquitto client on same rpi as openhab subed to same topic, receives the messages both from tasmota and miflora topics
On RC1 there are problems with the MQTT binding, mostly that states are not visible. I would first try to downgrade to M6 or follow the instructions here to install a newer version of MQTT on RC1, which solves this issue:
