I have a UZB stick running Z-way. I would like to migrate to the Z-wave binding and stop using Z-way.
Will the UZB stick contain everything needed for the Z-wave binding? Or do I need to go around and unpair and pair again?
Everything should be on the controller so you should be good from that perspective. You might have some devices that are not yet in the zwave binding’s database though. If you can’t get a device to be recongized check to see if it is in the DB. If it is a battery powered device it will take waking the device up several times for the binding to figure out what it is.
http://www.cd-jackson.com/index.php/zwave/zwave-device-database
