Is it correct that only the last 30 days are being migrated?
I’m seeing the correct dates:
Command:
./rest2influxdb.sh fluksoElecB
Output:
### timestamps
item: fluksoElecB
10y: 2010-10-17T15:30:23
1y: 2019-09-19T15:30:23
1m: 2020-09-18T15:30:23
1w: 2020-10-10T15:31:23
1d: 2020-10-16T15:31:23
8h: 2020-10-17T07:31:23
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 202 100 202 0 0 22444 0 --:--:-- --:--:-- --:--:-- 25250
100 2704 100 2704 0 0 330k 0 --:--:-- --:--:-- --:--:-- 330k
100 26912 0 26912 0 0 2021k 0 --:--:-- --:--:-- --:--:-- 2021k
100 229 100 229 0 0 32714 0 --:--:-- --:--:-- --:--:-- 38166
100 12067 0 12067 0 0 1309k 0 --:--:-- --:--:-- --:--:-- 1309k
100 23390 0 23390 0 0 2076k 0 --:--:-- --:--:-- --:--:-- 2076k
### found values: 1298
### Line from 1 to 1000
HTTP/1.1 100 Continue
HTTP/1.1 204 No Content
Content-Type: application/json
Request-Id: e8f5c243-107c-11eb-b196-000000000000
X-Influxdb-Build: OSS
X-Influxdb-Version: 1.6.4
X-Request-Id: e8f5c243-107c-11eb-b196-000000000000
Date: Sat, 17 Oct 2020 13:30:23 GMT
Sleep for 10 seconds to let InfluxDB process the data...
### Line from 1001 to 2000
Request-Id: eef0bba3-107c-11eb-b1a7-000000000000
X-Request-Id: eef0bba3-107c-11eb-b1a7-000000000000
Date: Sat, 17 Oct 2020 13:30:33 GMT
### delete temporary files
Thank you very much.
When I followed your analyses, I noticed that my date had some extra 00’s at the end of the date. With removing everything, clone it again, it works !!!
Next step, checking if I can export/import ‘all’ exisitng data now. Guess it’ll be a bit much, but that’s why we’ve computers, no?
I’ve tried it and it seems the values were read from my MySQL database, but could not be written to InfluxDB 2.4.
./rest2influxdb.sh MQTT_Wetterstation_Temperature
### timestamps
item: MQTT_Wetterstation_Temperature
10y: 2012-09-23T14:23:41
1y: 2021-08-26T14:23:41
1m: 2022-08-25T14:23:41
1w: 2022-09-16T14:24:41
1d: 2022-09-22T14:24:41
8h: 2022-09-23T06:24:41
resturl: http://openhab.fritz.box:8080/rest/persistence/items/MQTT_Wetterstation_Temperature?serviceId=jdbc&api_key=MQTT_Wetterstation_Temperature
100 24.5M 0 24.5M 0 0 1221k 0 --:--:-- 0:00:20 --:--:-- 5745k
100 10.3M 0 10.3M 0 0 1242k 0 --:--:-- 0:00:08 --:--:-- 2463k
100 681k 0 681k 0 0 1414k 0 --:--:-- --:--:-- --:--:-- 1414k
100 173k 0 173k 0 0 1443k 0 --:--:-- --:--:-- --:--:-- 1431k
100 24268 0 24268 0 0 1077k 0 --:--:-- --:--:-- --:--:-- 1077k
100 11343 0 11343 0 0 615k 0 --:--:-- --:--:-- --:--:-- 615k
### found values: 988158
HTTP/1.1 401 Unauthorized
Content-Type: application/json; charset=utf-8
X-Influxdb-Version: v2.4.0
X-Platform-Error-Code: unauthorized
Date: Fri, 23 Sep 2022 12:24:13 GMT
Content-Length: 48
Connection: close
Hi, I’m running OH3.4 (latest version) and installalled InfluxDB via openHABian-config, which seems to be version 1.8.
When starting the script I get:
openhabian@openhabianpi:/etc/openhab/migrate_rrd4j $ sudo ./rest2influxdb.sh ShellyTVWohnzimmer_Watt
### timestamps
item: ShellyTVWohnzimmer_Watt
10y: 2012-09-26T21:36:17
1y: 2021-08-29T21:36:17
1m: 2022-08-28T21:36:17
1w: 2022-09-19T21:37:17
1d: 2022-09-25T21:37:17
8h: 2022-09-26T13:37:17
resturl: http://192.168.10.50:8080/rest/persistence/items/ShellyTVWohnzimmer_Watt?serviceId=rrd4j&api_key=ShellyTVWohnzimmer_Watt
100 61 0 61 0 0 5083 0 --:--:-- --:--:-- --:--:-- 5545
100 216k 0 216k 0 0 3604k 0 --:--:-- --:--:-- --:--:-- 3604k
100 78728 0 78728 0 0 3075k 0 --:--:-- --:--:-- --:--:-- 3075k
100 319k 0 319k 0 0 4697k 0 --:--:-- --:--:-- --:--:-- 4767k
100 35747 0 35747 0 0 1837k 0 --:--:-- --:--:-- --:--:-- 1837k
100 18126 0 18126 0 0 737k 0 --:--:-- --:--:-- --:--:-- 737k
### found values: 18105
curl: (7) Failed to connect to 192.168.10.50 port 8086: Connection refused
Sleep for 5 seconds to let InfluxDB process the data...
So, the script can read the RRD4J data - but can’t connect to the database.
The IP address, the port, the user, the password and the name of the database are correct.
What else could be the reason for the error message - and how can I find out what’s the real problem?
I’m now a step further - the reason was the binding address was “localhost” while I was using the real ipaddress in the script. However - how I get “no content”:
thanks for your awesome script. One question I have, is the categorization in those periods in the script following some best practice or rrd persistence configuration?
But since the script queries everything older than 1 year as a 10 year query only 10% or less of the values are returned. So i would chunk the data more detailed instead discarding all those values.
