MDAR
(Stuart Hanlon, UK importer of Velbus hardware)
1
Hi
This community helped me to create this wonderful rule in openHAB2 that ring fences the minutes & hours value of alarm group members.
It also nudges the hour value up or down as required.
import org.eclipse.smarthome.model.script.ScriptServiceUtil
rule "Confine Minute"
Member of gMinute changed
logInfo("Minute Limiting", "Minute Value of "+triggeringItem.name+" Currently "+triggeringItem.state)
if (triggeringItem.state > 59) {
sendCommand(triggeringItem.name,"0")
// logInfo("Alarm Times",triggeringItem.name.split('Min').get(0)+"Hour")
var HourName = ""
HourName = triggeringItem.name.split('Min').get(0)+"Hour"
logInfo("Alarm Times",HourName)
var Number HourValue = 0
HourValue = ScriptServiceUtil.getItemRegistry.getItem(HourName).state
logInfo("Alarm Times","Hour is currently " + HourValue)
var Number NewHour = 0
NewHour=1 + HourValue
logInfo("Alarm Times","New Hour value is " + NewHour)
sendCommand(HourName, NewHour.toString)
if (triggeringItem.state < 0) {
sendCommand(triggeringItem.name,"45")
var HourName = ""
NewHour=HourValue -1
rule "Confine Hour"
Member of gHour changed
logInfo("Hour Limiting", "Hour Value of "+triggeringItem.name+" Currently "+triggeringItem.state)
if (triggeringItem.state > 23) {
// logInfo("Alarm Times",triggeringItem.name.split('Hou').get(0))
sendCommand(triggeringItem.name,"23")
When I try to use this rule in openHAB3, the section that polls the hour value fails.
It’s some kind of DSL magic that I just don’t understand.
Currently, I have deleted it, but it would be nice to have it back.
My thanks in advance.
This is an example of members of the groups in question.
// Ensure these groups are active in at least 1 Items file and add the Minute and Hour limiting rule
// Group gMinute "Limit Alarm Minute"
// Group ghour "Limit Alarm Hour"
Switch BackBedroom_ClockAlarm_ClockAlarm1Enabled "BackBedroom Alarm 1 Enabled" {channel="velbus:vmbgp2:VelbusNetworkBridge:1C:clockAlarm#clockAlarm1Enabled"}
String BackBedroom_ClockAlarm_ClockAlarm1Type "BackBedroom Alarm 1 Type" {channel="velbus:vmbgp2:VelbusNetworkBridge:1C:clockAlarm#clockAlarm1Type"}
Number BackBedroom_ClockAlarm_ClockAlarm1WakeupHour "BackBedroom Alarm 1 Wake Hour" (gHour) {channel="velbus:vmbgp2:VelbusNetworkBridge:1C:clockAlarm#clockAlarm1WakeupHour"}
Number BackBedroom_ClockAlarm_ClockAlarm1WakeupMinute "BackBedroom Alarm 1 Wake Minute" (gMinute) {channel="velbus:vmbgp2:VelbusNetworkBridge:1C:clockAlarm#clockAlarm1WakeupMinute"}
Number BackBedroom_ClockAlarm_ClockAlarm1BedtimeHour "BackBedroom Alarm 1 Bed Hour" (gHour) {channel="velbus:vmbgp2:VelbusNetworkBridge:1C:clockAlarm#clockAlarm1BedtimeHour"}
Number BackBedroom_ClockAlarm_ClockAlarm1BedtimeMinute "BackBedroom Alarm 1 Bed Minute" (gMinute) {channel="velbus:vmbgp2:VelbusNetworkBridge:1C:clockAlarm#clockAlarm1BedtimeMinute"}
Switch BackBedroom_ClockAlarm_ClockAlarm2Enabled "BackBedroom Alarm 2 Enabled" {channel="velbus:vmbgp2:VelbusNetworkBridge:1C:clockAlarm#clockAlarm2Enabled"}
String BackBedroom_ClockAlarm_ClockAlarm2Type "BackBedroom Alarm 2 Type" {channel="velbus:vmbgp2:VelbusNetworkBridge:1C:clockAlarm#clockAlarm2Type"}
Number BackBedroom_ClockAlarm_ClockAlarm2WakeupHour "BackBedroom Alarm 2 Wake Hour" (gHour) {channel="velbus:vmbgp2:VelbusNetworkBridge:1C:clockAlarm#clockAlarm2WakeupHour"}
Number BackBedroom_ClockAlarm_ClockAlarm2WakeupMinute "BackBedroom Alarm 2 Wake Minute" (gMinute) {channel="velbus:vmbgp2:VelbusNetworkBridge:1C:clockAlarm#clockAlarm2WakeupMinute"}
Number BackBedroom_ClockAlarm_ClockAlarm2BedtimeHour "BackBedroom Alarm 2 Bed Hour" (gHour) {channel="velbus:vmbgp2:VelbusNetworkBridge:1C:clockAlarm#clockAlarm2BedtimeHour"}
Number BackBedroom_ClockAlarm_ClockAlarm2BedtimeMinute "BackBedroom Alarm 2 Bed Minute" (gMinute) {channel="velbus:vmbgp2:VelbusNetworkBridge:1C:clockAlarm#clockAlarm2BedtimeMinute"}
It’s really going to help if you show the logs that your rules produce, and the error messages.
There are substantial changes to datetime handling in OH3 rules, but I think your rules just bump numbers around.
However, they don’t look very robust against trying to get values from uninitialized Items.
You might not even need this rule at all any more. I’m assuming you are setting a time for an alarm or the like. MainUI now how a Date Time entry widget and the Alarm Clock Rule template lets you schedule one of your rules to be run based on the state of a DateTime Item. No longer does one need to maintain a separate hours, minutes and seconds Item to enable a time to be changed from the UI.
And since it’s a rule templates and UI widgets from the Marketplace you only have to write the code that needs to run at the time specified by the DateTime Item. Everything else just gets installed and configured.
MDAR
7
Thanks Rich
This rule is specifically for managing the alarm times within www.velbus.eu modules.
(Which have all the events and offsets stored within the modules, which makes it very resilient)
That said, it’s great to know that OH3 can handle scheduling now, that will help greatly where people have requirements outside of the capabilities of a pure Velbus solution.
From an OH UI perspective, it might be worth using a DateTime Item and widget anyway then have a rule that splits it out to the separate Items needed by Velbus. That too would eliminate the need for this rule since the range checking would take place in the UI. The example I linked to shows a Date and Time Picker but you can also use just a Time Picker.
Here’s the YAML for a stand alone input widget that presents a Time selector.
uid: rlk_time_standalone
tags: []
props:
parameters:
- description: Label for the widget
label: Label
required: false
type: TEXT
- context: item
description: An item to control
label: Item
required: false
type: TEXT
parameterGroups: []
component: oh-input-card
clearButton: false
footer: '=(items[props.item].displayState === undefined) ? items[props.item].state : items[props.item].displayState'
inputmode: text
item: =props.item
outline: true
placeholder: '=(items[props.item].displayState === undefined) ? items[props.item].state : items[props.item].displayState'
sendButton: true
title: =props.label
type: time
Here is one for a List Item widget
uid: rlk_time_list
tags: []
props:
parameters:
- description: Label for the wiodget
label: Label
required: false
type: TEXT
- context: item
label: Item
required: false
type: TEXT
parameterGroups: []
component: ""
inputmode: time
label: =props.label
outline: true
placeholder: '--:-- --'
sendButton: true
subtitle: '=(items["props.item"].displayState === undefined) ? items["props.item"].state : items["Default_AFTERNOON"].displayState'
title: =props.label
type: text
In MainUI go to Developer Tools, select Custom Widgets. Click the + icon and paste the first widget above into the code. Save. Repeat for the second one.
Then in your Items add the first one “rlk_time_standalone” as the “Default Standalone Widget” metadata, setting the two parameters as desired. Add “rlk_time+list” as the “Default List Widget” again setting the two parameters.
That will make anywhere that this DateTime Item appears in MainUI use these widgets by default. If you go back and change the widget’s main code it will update all the Items that use that widget too.
These are really simple and straight forward but if it’s helpful I can publish them to the Marketplace like the Date Time selectors.
The rule is pretty simple too. As Rules DSL in .rules files it would be something like:
rule "Parse date time update"
Item MyDateTime changed
val asZDT = (MyDateTime.state as DateTimeType).getZonedDateTime()
val hour = asZDT.getHours()
val min = asZDT.getMinute()
val sec = as ZDT.getSecond()
MyHours.postUpdate(hour)
MyHours.postUpdate(min)
MyHours.postUpdate(sec)
