Hello everyone
i am migrating from OH 2.4 to OH3.2 i can’t understand
how to insert an Arilux module with Tasmota firmware.
In OH2.4 in the item file I have the following configuration:
Group gRGB "lights" <light> { ga="Light" [ useKelvin=true, colorTemperatureRange="2000,9000" ] }
Color cucina_Arilux_Color "cucina RGB" (gRGB)
String cucina_Arilux_RGB "colore RGB [%s]" <colorlight> (gRGB) {mqtt="<[mosquitto:stat/luce_cucina/RESULT:state:JSONPATH($.Color):REGEX((.*))]", ga="lightColorTemperature"}
Switch cucina_Arilux_Power "Luce Cucina RGB [%s]" <light> (gRGB,luci) {mqtt=">[mosquitto:cmnd/luce_cucina/POWER:command:*:default],<[mosquitto:stat/luce_cucina/RESULT:state:JSONPATH($.POWER):REGEX((.*))]", autoupdate="true", ga="Light"}
Dimmer cucina_Arilux_Dim "dimmer Cucina [%.0f %%]" <dimmablelight> (gRGB,luci) {mqtt=">[mosquitto:cmnd/luce_cucina/DIMMER:command:*:default],<[mosquitto:stat/luce_cucina/RESULT:state:JSONPATH($.Dimmer):REGEX((.*))]", ga="LightBrightness"}
Number cucina_Arilux_RSSI <network> (wifi) {mqtt="<[mosquitto:tele/luce_cucina/STATE:state:JSONPATH($.Wifi.RSSI)]"}```
