Well, I had a few rounds with this protocol already and I failed every time So I agree it is extremely hard to manage. I think it is the time for me to check out the esp based custom bridge, meanwhile I am going to try simplify my rules and play with the configuration.
Additional info:
2018-12-31 15:20:05.222 [WARN ] [milight.internal.protocol.QueuedSend] - Failed to send Message to ā10.0.100.111ā: Socket is closed
(Obviously 10.0.100.111 is the ip address of my bridge)
Well another restart with an added clear cache and the socket closed message goes away but no joy getting any bulbs to turn on or off. Double checked the easy bulb app to ensure that theyāre still working which they are. Does anybody have the 2.3 jar by any chance?
@David_Graeff, I still think Iām seeing some odd behaviour with the 2.4 binding. When OH restarts I send the last known state to all the lights in case there has been a power cut and the house is lit up like a Christmas tree. This is no longer reliable with lights staying on even though they have been sent an OFF command.
Iām looking at the code and in particular the AbstractLedHandler.uidc method. Does this actually work when you have multiple bridges? It looks to me like the same bulb type in the same zone will produce the same id for each bridge. So two bridges trying to turn off the same zone at the same time is going to result in one of those commands being removed from the global send queue.
Hello, having problem with this bindingā¦ I added the milight bridge (old version) to the things although it was not found automatically but after manually entering IP and MAC it showed up under things with constant āonlineā indication.
added lamps but when I send the commands I get:
ā2019-11-04 20:18:48.104 [WARN ] [milight.internal.protocol.QueuedSend] - Failed to send Message to ā192.168.1.117ā: Socket is closedā
Iām running OH 2.4 under Synology diskstation. Itās a new install with first bindingsā¦ Am I missing some obvious fix here? I assume this fix was merged in to the binding/OH or do I need to somehow merge it in manually?
P.s. and just noticed that under things if I open the lamp under channels I see only
Nightmode
Brightness
Color temperature
Animation mode
and no ON/OFF channelā¦ which RTFM part have I skipped?..
