I don’t know this binding but I would guess there is some sort of unexpected delay in messages passing back and forth to whatever the binding is communicating with or the network is disconnecting.
From the OH machine see if you can ping this device (assuming it’s on your network) or some other device/computer on your network. Are you getting a fairly consistent time? Is the time pretty large?
On your OH server, are you running out of memory or CPU?
If you restart OH do those log statements go away for awhile?
These are generic trouble shooting steps. If they don’t help I won’t be of any further help. But I’ve tagged this with milight so hopefully it is more likely to get the attention of the right users.
The times for the ping look good. But you want to continue running the ping so that you get some pings around the same time that you get the timeout log. On Windows use ping <address> -t and it will continue to ping <address> until you hit <crtl>-c instead of only running 20 times or so.
How much memory is the openHAB process specifically using?
I’m afraid to say that this is looking like something we will need a binding maintainer to look at to move forward. You machine looks powerful and the network appears solid (pending the rerun of the ping test).
I still see this problem in Openhab 3.2. As I setup all my things with files, because I have a better control of the things and items, I would like to now if I can set the keepAliveInterval by using a parameter, too?
