Just set up OpenHAB2 and connected my Milight Bulbs.
As first sitemap I created a sitemap with one general switch for all bulbs and one dedicated switch per bulb.
Because there is no on / off in the openhab2 binding, I created rules according to this post.
In order to maintain the state of the dedicated buttons I decided to create an additional rule for the general switch that doesn’t address the “all” channel. Instead it switches the dedicated switches one by one.
Unfortunately this doesn’t work reliably. The bulbs react kind of randomly - sometimes all bulbs react, sometimes only one or several.
This is my sitemap:
sitemap philli label="My Hood"
Frame label="Licht gesamt" {
Switch item=LIGHT_ALL mappings=[ON="An", OFF="Aus"]
Frame label="Licht einzeln" {
Switch item=LIGHT_TV mappings=[ON="An", OFF="Aus"]
Switch item=LIGHT_COUCH mappings=[ON="An", OFF="Aus"]
Switch item=LIGHT_FLUR mappings=[ON="An", OFF="Aus"]
Switch item=LIGHT_WINTERGARTEN mappings=[ON="An", OFF="Aus"]
These are the items:
Switch LIGHT_ALL "Alle Lampen"
Color LIGHT_ALL_COLOR "Label" {channel="milight:rgbLed:ACCF23468948:6:ledcolor"}
Switch LIGHT_WINTERGARTEN "Wintergarten"
Color LIGHT_WINTERGARTEN_COLOR "Label" {channel="milight:rgbLed:ACCF23468948:10:ledcolor"}
Switch LIGHT_TV "TV"
Color LIGHT_TV_COLOR "Label" {channel="milight:rgbLed:ACCF23468948:7:ledcolor"}
Switch LIGHT_COUCH "Couch"
Color LIGHT_COUCH_COLOR "Label" {channel="milight:rgbLed:ACCF23468948:8:ledcolor"}
Switch LIGHT_FLUR "Flur"
Color LIGHT_FLUR_COLOR "Label" {channel="milight:rgbLed:ACCF23468948:9:ledcolor"}
And here are the rules:
rule "all lights on"
Item LIGHT_ALL received command ON
//sendCommand(LIGHT_ALL_COLOR, new HSBType (new DecimalType(0),new PercentType(0),new PercentType(100)))
sendCommand(LIGHT_WINTERGARTEN, "ON")
sendCommand(LIGHT_TV, "ON")
sendCommand(LIGHT_COUCH, "ON")
sendCommand(LIGHT_FLUR, "ON")
rule "all lights off"
Item LIGHT_ALL received command OFF
sendCommand(LIGHT_WINTERGARTEN, "OFF")
sendCommand(LIGHT_TV, "OFF")
sendCommand(LIGHT_COUCH, "OFF")
sendCommand(LIGHT_FLUR, "OFF")
//sendCommand(LIGHT_ALL_COLOR, new HSBType (new DecimalType(0),new PercentType(0),new PercentType(0)))
rule "wintergarten ON"
Item LIGHT_WINTERGARTEN received command ON
logInfo("LIGHT", "Turn Wintergarten ON")
sendCommand(LIGHT_WINTERGARTEN_COLOR, new HSBType (new DecimalType(0),new PercentType(0),new PercentType(100)))
rule "wintergarten OFF"
Item LIGHT_WINTERGARTEN received command OFF
logInfo("LIGHT", "Turn Wintergarten OFF")
sendCommand(LIGHT_WINTERGARTEN_COLOR, new HSBType (new DecimalType(0),new PercentType(0),new PercentType(0)))
rule "light tv on"
Item LIGHT_TV received command ON
logInfo("LIGHT", "Turn TV ON")
sendCommand(LIGHT_TV_COLOR, new HSBType (new DecimalType(0),new PercentType(0),new PercentType(100)))
rule "light tv off"
Item LIGHT_TV received command OFF
logInfo("LIGHT", "Turn TV OFF")
sendCommand(LIGHT_TV_COLOR, new HSBType (new DecimalType(0),new PercentType(0),new PercentType(0)))
rule "LIGHT_COUCH_ON"
Item LIGHT_COUCH received command ON
logInfo("LIGHT", "Turn Couch ON")
sendCommand(LIGHT_COUCH_COLOR, new HSBType (new DecimalType(0),new PercentType(0),new PercentType(100)))
rule "LIGHT_COUCH_OFF"
Item LIGHT_COUCH received command OFF
logInfo("LIGHT", "Turn Couch OFF")
sendCommand(LIGHT_COUCH_COLOR, new HSBType (new DecimalType(0),new PercentType(0),new PercentType(0)))
rule "LIGHT_FLUR_ON"
Item LIGHT_FLUR received command ON
logInfo("LIGHT", "Turn Flur ON")
sendCommand(LIGHT_FLUR_COLOR, new HSBType (new DecimalType(0),new PercentType(0),new PercentType(100)))
rule "LIGHT_FLUR_OFF"
Item LIGHT_FLUR received command OFF
logInfo("LIGHT", "Turn Flur OFF")
sendCommand(LIGHT_FLUR_COLOR, new HSBType (new DecimalType(0),new PercentType(0),new PercentType(0)))
Any idea why the bulbs react so unreliably?
