Three of us at work have installed OpenHAB are using it to control our LimitlessLED globes, amongst other things, and it’s great. We are all experiencing a similar problem with the Milight binding globes dimming when the brightness of another channel is changed however.
For example, if I increase the brightness of the globes on bridge 1, channel 1, the globes on bridge 1, channel 2 will more than likely dim.
Things we have noticed are:
It only happens if the channels are on the same bridge. Changing the brightness of a channel on bridge 1 will never effect channels on bridge 2.
It only appears to happen with the dual white globes and not the RBG globes.
It happens even if a channel isn’t configured in OpenHAB. For example, if only channel 1 is defined in OpenHAB, the globes on channel 2 will still dim when channel 1 is changed.
We have tried the following versions of Openhab.
1.81
1.83
2.0
We have tried Ubuntu, Debian and Windows 7.
We are all using Oracle’s Java. I am currently using 1.8.0_101.
Has anyone else experienced this issue or have any suggestions about what we could try?
At first we suspected a possible hardware issue, but this appears to have been ruled out now that three of us are having the same problem with multiple bridges and globes.
rule "Light_FrontDoor_Outside_Brightness_ON"
Item Light_FrontDoor_Outside received command ON
sendCommand(Light_FrontDoor_OustideB, 100)
rule "Light_FrontDoor_Outside_OFF"
Item Light_FrontDoor_Outside received command OFF
sendCommand(Light_FrontDoor_OustideB, 0)
The globes on bridge 2, channel 2 dimmed and then turned off entirely, as they should have.
The globes on bridge 2, channel 1 also dimmed though. Down to about 20%. I can’t see why this happened.
Please find the debug log attached.
18:15:02.484 [DEBUG] [o.i.r.i.resources.ItemResource:205 ] - Received HTTP POST request at 'items/Light_FrontDoor_Outside' with value 'OFF'.
18:15:02.491 [DEBUG] [m.r.internal.engine.RuleEngine:305 ] - Executing rule 'Light_FrontDoor_Outside_OFF'
18:15:02.608 [DEBUG] [.o.b.m.internal.MilightBinding:96 ] - milight: item is of type brightness
18:15:02.611 [DEBUG] [.o.b.m.internal.MilightBinding:111 ] - milight: command is of type PercentType
18:15:02.613 [DEBUG] [.o.b.m.internal.MilightBinding:192 ] - milight: sendPercent
18:15:02.616 [DEBUG] [.o.b.m.internal.MilightBinding:664 ] - milight: sendOff
18:15:02.623 [DEBUG] [.o.b.m.internal.MilightBinding:350 ] - milight: sendDecrease
18:15:02.626 [DEBUG] [.o.b.m.internal.MilightBinding:383 ] - milight: Bulb '2' getting decreased to '91'
18:15:02.629 [DEBUG] [.o.b.m.internal.MilightBinding:786 ] - milight: messageBytes to transform: '34:00:55'
18:15:02.635 [DEBUG] [.o.b.m.internal.MilightBinding:778 ] - Sent packet '34:00:55' to bridge 'bridge2' (192.168.8.13:8899)
18:15:02.737 [DEBUG] [.o.b.m.internal.MilightBinding:350 ] - milight: sendDecrease
18:15:02.740 [DEBUG] [.o.b.m.internal.MilightBinding:383 ] - milight: Bulb '2' getting decreased to '82'
18:15:02.741 [DEBUG] [.o.b.m.internal.MilightBinding:786 ] - milight: messageBytes to transform: '34:00:55'
18:15:02.744 [DEBUG] [.o.b.m.internal.MilightBinding:778 ] - Sent packet '34:00:55' to bridge 'bridge2' (192.168.8.13:8899)
18:15:02.847 [DEBUG] [.o.b.m.internal.MilightBinding:350 ] - milight: sendDecrease
18:15:02.849 [DEBUG] [.o.b.m.internal.MilightBinding:383 ] - milight: Bulb '2' getting decreased to '73'
18:15:02.852 [DEBUG] [.o.b.m.internal.MilightBinding:786 ] - milight: messageBytes to transform: '34:00:55'
18:15:02.856 [DEBUG] [.o.b.m.internal.MilightBinding:778 ] - Sent packet '34:00:55' to bridge 'bridge2' (192.168.8.13:8899)
18:15:02.927 [DEBUG] [o.o.i.r.i.b.GeneralBroadcaster:46 ] - broadcaster 'org.openhab.io.rest.internal.broadcaster.GeneralBroadcaster$1@54377' is empty
18:15:02.959 [DEBUG] [.o.b.m.internal.MilightBinding:350 ] - milight: sendDecrease
18:15:02.962 [DEBUG] [.o.b.m.internal.MilightBinding:383 ] - milight: Bulb '2' getting decreased to '64'
18:15:02.966 [DEBUG] [.o.b.m.internal.MilightBinding:786 ] - milight: messageBytes to transform: '34:00:55'
18:15:02.971 [DEBUG] [.o.b.m.internal.MilightBinding:778 ] - Sent packet '34:00:55' to bridge 'bridge2' (192.168.8.13:8899)
18:15:03.073 [DEBUG] [.o.b.m.internal.MilightBinding:350 ] - milight: sendDecrease
18:15:03.076 [DEBUG] [.o.b.m.internal.MilightBinding:383 ] - milight: Bulb '2' getting decreased to '55'
18:15:03.079 [DEBUG] [.o.b.m.internal.MilightBinding:786 ] - milight: messageBytes to transform: '34:00:55'
18:15:03.081 [DEBUG] [.r.i.resources.SitemapResource:146 ] - Received HTTP GET request at 'sitemaps/default/0000' for media type 'null'.
18:15:03.084 [DEBUG] [.o.b.m.internal.MilightBinding:778 ] - Sent packet '34:00:55' to bridge 'bridge2' (192.168.8.13:8899)
18:15:03.142 [DEBUG] [.r.i.resources.SitemapResource:146 ] - Received HTTP GET request at 'sitemaps/default/0000' for media type 'null'.
18:15:03.193 [DEBUG] [.o.b.m.internal.MilightBinding:350 ] - milight: sendDecrease
18:15:03.196 [DEBUG] [.o.b.m.internal.MilightBinding:383 ] - milight: Bulb '2' getting decreased to '45'
18:15:03.199 [DEBUG] [.o.b.m.internal.MilightBinding:786 ] - milight: messageBytes to transform: '34:00:55'
18:15:03.203 [DEBUG] [.o.b.m.internal.MilightBinding:778 ] - Sent packet '34:00:55' to bridge 'bridge2' (192.168.8.13:8899)
18:15:03.305 [DEBUG] [.o.b.m.internal.MilightBinding:350 ] - milight: sendDecrease
18:15:03.308 [DEBUG] [.o.b.m.internal.MilightBinding:383 ] - milight: Bulb '2' getting decreased to '36'
18:15:03.310 [DEBUG] [.o.b.m.internal.MilightBinding:786 ] - milight: messageBytes to transform: '34:00:55'
18:15:03.314 [DEBUG] [.o.b.m.internal.MilightBinding:778 ] - Sent packet '34:00:55' to bridge 'bridge2' (192.168.8.13:8899)
18:15:03.416 [DEBUG] [.o.b.m.internal.MilightBinding:350 ] - milight: sendDecrease
18:15:03.418 [DEBUG] [.o.b.m.internal.MilightBinding:383 ] - milight: Bulb '2' getting decreased to '27'
18:15:03.420 [DEBUG] [.o.b.m.internal.MilightBinding:786 ] - milight: messageBytes to transform: '34:00:55'
18:15:03.424 [DEBUG] [.o.b.m.internal.MilightBinding:778 ] - Sent packet '34:00:55' to bridge 'bridge2' (192.168.8.13:8899)
18:15:03.525 [DEBUG] [.o.b.m.internal.MilightBinding:350 ] - milight: sendDecrease
18:15:03.528 [DEBUG] [.o.b.m.internal.MilightBinding:383 ] - milight: Bulb '2' getting decreased to '18'
18:15:03.531 [DEBUG] [.o.b.m.internal.MilightBinding:786 ] - milight: messageBytes to transform: '34:00:55'
18:15:03.535 [DEBUG] [.o.b.m.internal.MilightBinding:778 ] - Sent packet '34:00:55' to bridge 'bridge2' (192.168.8.13:8899)
18:15:03.637 [DEBUG] [.o.b.m.internal.MilightBinding:350 ] - milight: sendDecrease
18:15:03.639 [DEBUG] [.o.b.m.internal.MilightBinding:383 ] - milight: Bulb '2' getting decreased to '9'
18:15:03.640 [DEBUG] [.o.b.m.internal.MilightBinding:786 ] - milight: messageBytes to transform: '34:00:55'
18:15:03.643 [DEBUG] [.o.b.m.internal.MilightBinding:778 ] - Sent packet '34:00:55' to bridge 'bridge2' (192.168.8.13:8899)
18:15:03.746 [DEBUG] [.o.b.m.internal.MilightBinding:786 ] - milight: messageBytes to transform: '33:00:55'
18:15:03.748 [DEBUG] [.o.b.m.internal.MilightBinding:778 ] - Sent packet '33:00:55' to bridge 'bridge2' (192.168.8.13:8899)
i guess I found the Problem, but can fix it earliest after 9/26 as I am on holiday.
Just to proof, this only happens when sending a decrease command, right?
