Hi
I’m successfully using the milight binding with led bulbs and I’d like to add a milight floodlight but I’m not sure if it would work with the binding
Has anybody tried that?
Carlos
Hi
Carlos
They will work with this different binding as the opensource hub emulates the remotes, so any Milight that uses the remotes can work with this setup.
The LED strip controllers and other lights also work.
Thanks that is very useful
