I’m new to openHAB, but so far have got a Wemo switch and some MQTT based sensors working fine. I’m having real problems getting anything to work with my Milight RGB strips though.
I’m running OpenHAB2-snapshot (as of 29 August 2016)
In the paperUI the milight bridge and color group are showing online:
Milight Bridge ACCF2353D3CE ONLINE
Milight Bridge
milight:bridge:ACCF2353D3CE
Color group 1 ONLINE
RGB Led
milight:rgbLed:ACCF2353D3CE:7
In my items file I have:
Color RGBLight {channel=“milight:rgbLed:ACCF2353D3CE:7:ledcolor”}
and in the sitemap::
Colorpicker item=RGBLight icon=“slider”
The log shows the following when I select a colour in the basic UI:
16:35:02.149 [INFO ] [smarthome.event.ItemCommandEvent ] - Item ‘Light_Party’ received command 114,72,50
16:35:02.206 [INFO ] [marthome.event.ItemStateChangedEvent] - Light_Party changed from NULL to 114,72,50
16:35:03.578 [INFO ] [smarthome.event.ItemCommandEvent ] - Item ‘Light_Party’ received command 114,72,85
16:35:03.607 [INFO ] [marthome.event.ItemStateChangedEvent] - Light_Party changed from 114,72,50 to 114,72,85
Are you sure you are using the most recent binding and not an older one? I use milight too (bulbs though, no strip) and I don’t remember having to edit a milight.cfg file.
My configuration for two channels of RGBW bulbs is as follows:
Hello. Have you found a solution to your problem?
I also have a MiLight iBox2 and a MiLight FUT038. In Openhab2 everything is online. Unfortunately, my stripes do not happen at all.
