Recently added a Minoston MP21Z small pluggable outlet to my z-wave network. It seemed to include just fine, but does not switch from OpenHab. If I use the button on the side, the item will change state in openhab, but I if I change the item in OpenHab, it will not switch on the plug. I have z-wave devices further than its installed location, and the z-wave log viewer at opensmarthouse.org shows no timed out packets.
Running the most recent milestone openhab 3.1.0.M3, via openhabian on a pi4.
Below are the logs during inclusion if that is helpful. It is added as Node 33.
Thanks,
Prokhor
2021-04-24 22:45:39.875 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-04-24 22:45:39.875 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-04-24 22:45:40.135 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 10 0E 0A 71 05 07 FF 00 FF 07 02 00 00 89
2021-04-24 22:45:40.137 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=14, callback=16, payload=10 0E 0A 71 05 07 FF 00 FF 07 02 00 00
2021-04-24 22:45:40.138 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=14, callback=16, payload=10 0E 0A 71 05 07 FF 00 FF 07 02 00 00
2021-04-24 22:45:40.138 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2021-04-24 22:45:40.139 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 14: Application Command Request (ALIVE:DONE)
2021-04-24 22:45:40.139 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 14: resetResendCount initComplete=true isDead=false
2021-04-24 22:45:40.140 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 14: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2021-04-24 22:45:40.141 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 14: SECURITY not supported
2021-04-24 22:45:40.141 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 14: Received COMMAND_CLASS_ALARM V2 NOTIFICATION_REPORT
2021-04-24 22:45:40.142 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 14: ALARM report - 7 = 255
2021-04-24 22:45:40.142 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 14: Alarm Type = BURGLAR (7)
2021-04-24 22:45:40.143 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2021-04-24 22:45:40.143 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2021-04-24 22:45:40.144 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 14: Alarm converter processing ALARM
2021-04-24 22:45:40.144 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Updating channel state zwave:device:c3f88d21c6:node14:alarm_burglar to ON [OnOffType]
2021-04-24 22:45:40.145 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 14: Commands processed 1.
2021-04-24 22:45:40.146 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 14: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@676e23.
2021-04-24 22:45:40.146 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2021-04-24 22:45:40.147 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-04-24 22:45:40.147 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-04-24 22:45:40.268 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 10 0E 0A 71 05 07 FF 00 FF 07 02 00 00 89
2021-04-24 22:45:40.270 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=14, callback=16, payload=10 0E 0A 71 05 07 FF 00 FF 07 02 00 00
2021-04-24 22:45:40.271 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=14, callback=16, payload=10 0E 0A 71 05 07 FF 00 FF 07 02 00 00
2021-04-24 22:45:40.272 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2021-04-24 22:45:40.272 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 14: Application Command Request (ALIVE:DONE)
2021-04-24 22:45:40.273 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 14: resetResendCount initComplete=true isDead=false
2021-04-24 22:45:40.273 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 14: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2021-04-24 22:45:40.274 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 14: SECURITY not supported
2021-04-24 22:45:40.274 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 14: Received COMMAND_CLASS_ALARM V2 NOTIFICATION_REPORT
2021-04-24 22:45:40.275 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 14: ALARM report - 7 = 255
2021-04-24 22:45:40.275 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 14: Alarm Type = BURGLAR (7)
2021-04-24 22:45:40.276 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2021-04-24 22:45:40.276 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2021-04-24 22:45:40.277 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 14: Alarm converter processing ALARM
2021-04-24 22:45:40.278 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Updating channel state zwave:device:c3f88d21c6:node14:alarm_burglar to ON [OnOffType]
2021-04-24 22:45:40.278 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 14: Commands processed 1.
2021-04-24 22:45:40.279 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 14: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@103e908.
2021-04-24 22:45:40.279 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2021-04-24 22:45:40.280 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2021-04-24 22:45:40.280 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-04-24 22:45:40.281 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-04-24 22:45:49.536 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 4A 18 02 00 00 A8
2021-04-24 22:45:49.537 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=AddNodeToNetwork[74], type=Request[0], dest=2, callback=24, payload=18 02 00 00
2021-04-24 22:45:49.538 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=AddNodeToNetwork[74], type=Request[0], dest=2, callback=24, payload=18 02 00 00
2021-04-24 22:45:49.539 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2021-04-24 22:45:49.539 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 0
2021-04-24 22:45:49.540 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: null
2021-04-24 22:45:49.541 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=AddNodeToNetwork[74], type=Request[0], dest=2, callback=24, payload=18 02 00 00
2021-04-24 22:45:49.541 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Add Node: New node found.
2021-04-24 22:45:49.542 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-04-24 22:45:49.542 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-04-24 22:45:49.796 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 4A 18 03 21 11 04 10 01 5E 25 85 8E 59 55 86 72 5A 73 70 9F 6C 7A CB
2021-04-24 22:45:49.797 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=AddNodeToNetwork[74], type=Request[0], dest=3, callback=24, payload=18 03 21 11 04 10 01 5E 25 85 8E 59 55 86 72 5A 73 70 9F 6C 7A
2021-04-24 22:45:49.798 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=AddNodeToNetwork[74], type=Request[0], dest=3, callback=24, payload=18 03 21 11 04 10 01 5E 25 85 8E 59 55 86 72 5A 73 70 9F 6C 7A
2021-04-24 22:45:49.799 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2021-04-24 22:45:49.799 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 0
2021-04-24 22:45:49.800 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: null
2021-04-24 22:45:49.801 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=AddNodeToNetwork[74], type=Request[0], dest=3, callback=24, payload=18 03 21 11 04 10 01 5E 25 85 8E 59 55 86 72 5A 73 70 9F 6C 7A
2021-04-24 22:45:49.801 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - NODE 33: Adding slave.
2021-04-24 22:45:49.802 [DEBUG] [al.protocol.ZWaveInclusionController] - Inclusion event: Current state IncludeStart, new event IncludeSlaveFound
2021-04-24 22:45:49.804 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 33: Including node.
2021-04-24 22:45:49.805 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-04-24 22:45:49.805 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-04-24 22:45:54.951 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 4A 18 05 21 00 8E
2021-04-24 22:45:54.953 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=AddNodeToNetwork[74], type=Request[0], dest=5, callback=24, payload=18 05 21 00
2021-04-24 22:45:54.954 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=AddNodeToNetwork[74], type=Request[0], dest=5, callback=24, payload=18 05 21 00
2021-04-24 22:45:54.955 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2021-04-24 22:45:54.955 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 0
2021-04-24 22:45:54.955 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: null
2021-04-24 22:45:54.956 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=AddNodeToNetwork[74], type=Request[0], dest=5, callback=24, payload=18 05 21 00
2021-04-24 22:45:54.957 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - NODE 33: Add Node: Protocol done.
2021-04-24 22:45:54.957 [DEBUG] [al.protocol.ZWaveInclusionController] - Inclusion event: Current state IncludeSlaveFound, new event IncludeProtocolDone
2021-04-24 22:45:54.958 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Ending INCLUSION mode.
2021-04-24 22:45:54.959 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added 5318 to queue - size 1
2021-04-24 22:45:54.959 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-04-24 22:45:54.960 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 05 00 4A 05 19 AC
2021-04-24 22:45:54.961 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 05 00 4A 05 19 AC
2021-04-24 22:45:54.962 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2021-04-24 22:45:54.962 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 5318: [WAIT_REQUEST] priority=Controller, requiresResponse=true, callback: 25
2021-04-24 22:45:54.963 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 33: Inclusion protocol completed.
2021-04-24 22:45:54.964 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Creating new instance of command class COMMAND_CLASS_NO_OPERATION
2021-04-24 22:45:54.964 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Command class COMMAND_CLASS_NO_OPERATION, endpoint 0 created
2021-04-24 22:45:54.965 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Version = 1, version set. Enabling extra functionality.
2021-04-24 22:45:54.965 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Adding command class COMMAND_CLASS_NO_OPERATION to the list of supported command classes.
2021-04-24 22:45:54.966 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Creating new instance of command class COMMAND_CLASS_BASIC
2021-04-24 22:45:54.966 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Command class COMMAND_CLASS_BASIC, endpoint 0 created
2021-04-24 22:45:54.967 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Adding command class COMMAND_CLASS_BASIC to the list of supported command classes.
2021-04-24 22:45:54.967 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Creating new instance of command class COMMAND_CLASS_ZWAVEPLUS_INFO
2021-04-24 22:45:54.968 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Command class COMMAND_CLASS_ZWAVEPLUS_INFO, endpoint 0 created
2021-04-24 22:45:54.968 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 33: Inclusion is adding command class COMMAND_CLASS_ZWAVEPLUS_INFO.
2021-04-24 22:45:54.968 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Adding command class COMMAND_CLASS_ZWAVEPLUS_INFO to the list of supported command classes.
2021-04-24 22:45:54.969 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Creating new instance of command class COMMAND_CLASS_SWITCH_BINARY
2021-04-24 22:45:54.969 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Command class COMMAND_CLASS_SWITCH_BINARY, endpoint 0 created
2021-04-24 22:45:54.970 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 33: Inclusion is adding command class COMMAND_CLASS_SWITCH_BINARY.
2021-04-24 22:45:54.970 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Adding command class COMMAND_CLASS_SWITCH_BINARY to the list of supported command classes.
2021-04-24 22:45:54.970 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Creating new instance of command class COMMAND_CLASS_ASSOCIATION
2021-04-24 22:45:54.971 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Command class COMMAND_CLASS_ASSOCIATION, endpoint 0 created
2021-04-24 22:45:54.972 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 33: Inclusion is adding command class COMMAND_CLASS_ASSOCIATION.
2021-04-24 22:45:54.972 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Adding command class COMMAND_CLASS_ASSOCIATION to the list of supported command classes.
2021-04-24 22:45:54.972 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Creating new instance of command class COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION
2021-04-24 22:45:54.973 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Command class COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION, endpoint 0 created
2021-04-24 22:45:54.974 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 13 00 04 00 11 0D 60 0D 02 01 71 05 00 00 00 FF 07 00 00 16
2021-04-24 22:45:54.974 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 33: Inclusion is adding command class COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION.
2021-04-24 22:45:54.974 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Adding command class COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION to the list of supported command classes.
2021-04-24 22:45:54.975 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Creating new instance of command class COMMAND_CLASS_ASSOCIATION_GRP_INFO
2021-04-24 22:45:54.975 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=17, callback=0, payload=00 11 0D 60 0D 02 01 71 05 00 00 00 FF 07 00 00
2021-04-24 22:45:54.975 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Command class COMMAND_CLASS_ASSOCIATION_GRP_INFO, endpoint 0 created
2021-04-24 22:45:54.976 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 33: Inclusion is adding command class COMMAND_CLASS_ASSOCIATION_GRP_INFO.
2021-04-24 22:45:54.976 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 18
2021-04-24 22:45:54.976 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Adding command class COMMAND_CLASS_ASSOCIATION_GRP_INFO to the list of supported command classes.
2021-04-24 22:45:54.977 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 1<>127 : Message: class=null[0], type=CAN[4], dest=255, callback=0, payload=
2021-04-24 22:45:54.977 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Unsupported command class COMMAND_CLASS_TRANSPORT_SERVICE
2021-04-24 22:45:54.978 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Creating new instance of command class COMMAND_CLASS_VERSION
2021-04-24 22:45:54.979 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Command class COMMAND_CLASS_VERSION, endpoint 0 created
2021-04-24 22:45:54.980 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 33: Inclusion is adding command class COMMAND_CLASS_VERSION.
2021-04-24 22:45:54.980 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Adding command class COMMAND_CLASS_VERSION to the list of supported command classes.
2021-04-24 22:45:54.981 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Creating new instance of command class COMMAND_CLASS_MANUFACTURER_SPECIFIC
2021-04-24 22:45:54.981 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Command class COMMAND_CLASS_MANUFACTURER_SPECIFIC, endpoint 0 created
2021-04-24 22:45:54.982 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 33: Inclusion is adding command class COMMAND_CLASS_MANUFACTURER_SPECIFIC.
2021-04-24 22:45:54.982 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Adding command class COMMAND_CLASS_MANUFACTURER_SPECIFIC to the list of supported command classes.
2021-04-24 22:45:54.983 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Creating new instance of command class COMMAND_CLASS_DEVICE_RESET_LOCALLY
2021-04-24 22:45:54.983 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Command class COMMAND_CLASS_DEVICE_RESET_LOCALLY, endpoint 0 created
2021-04-24 22:45:54.983 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 33: Inclusion is adding command class COMMAND_CLASS_DEVICE_RESET_LOCALLY.
2021-04-24 22:45:54.984 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Adding command class COMMAND_CLASS_DEVICE_RESET_LOCALLY to the list of supported command classes.
2021-04-24 22:45:54.984 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Creating new instance of command class COMMAND_CLASS_POWERLEVEL
2021-04-24 22:45:54.984 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Command class COMMAND_CLASS_POWERLEVEL, endpoint 0 created
2021-04-24 22:45:54.985 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 33: Inclusion is adding command class COMMAND_CLASS_POWERLEVEL.
2021-04-24 22:45:54.985 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Adding command class COMMAND_CLASS_POWERLEVEL to the list of supported command classes.
2021-04-24 22:45:54.985 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Creating new instance of command class COMMAND_CLASS_CONFIGURATION
2021-04-24 22:45:54.985 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Command class COMMAND_CLASS_CONFIGURATION, endpoint 0 created
2021-04-24 22:45:54.986 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 33: Inclusion is adding command class COMMAND_CLASS_CONFIGURATION.
2021-04-24 22:45:54.986 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Adding command class COMMAND_CLASS_CONFIGURATION to the list of supported command classes.
2021-04-24 22:45:54.986 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Creating new instance of command class COMMAND_CLASS_SECURITY
2021-04-24 22:45:54.987 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Command class COMMAND_CLASS_SECURITY, endpoint 0 created
2021-04-24 22:45:54.987 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 33: Inclusion is adding command class COMMAND_CLASS_SECURITY_2.
2021-04-24 22:45:54.987 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Adding command class COMMAND_CLASS_SECURITY to the list of supported command classes.
2021-04-24 22:45:54.988 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Unsupported command class COMMAND_CLASS_SUPERVISION
2021-04-24 22:45:54.988 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Creating new instance of command class COMMAND_CLASS_FIRMWARE_UPDATE_MD
2021-04-24 22:45:54.988 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Command class COMMAND_CLASS_FIRMWARE_UPDATE_MD, endpoint 0 created
2021-04-24 22:45:54.988 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 33: Inclusion is adding command class COMMAND_CLASS_FIRMWARE_UPDATE_MD.
2021-04-24 22:45:54.989 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Adding command class COMMAND_CLASS_FIRMWARE_UPDATE_MD to the list of supported command classes.
2021-04-24 22:45:54.989 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 33: ZWaveController include node
2021-04-24 22:45:54.989 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 33: Starting initialisation from INCLUSION_START
2021-04-24 22:45:54.990 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 33: Node advancer: Node just included (1120304)
2021-04-24 22:45:54.990 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (1): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=17, callback=0, payload=00 11 0D 60 0D 02 01 71 05 00 00 00 FF 07 00 00
2021-04-24 22:45:54.991 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 5318: [WAIT_REQUEST] priority=Controller, requiresResponse=true, callback: 25
2021-04-24 22:45:54.991 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 17: Application Command Request (ALIVE:DONE)
2021-04-24 22:45:54.992 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 17: resetResendCount initComplete=true isDead=false
2021-04-24 22:45:54.992 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 17: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2021-04-24 22:45:54.993 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 17: Incoming command class COMMAND_CLASS_ALARM, endpoint 2
2021-04-24 22:45:54.993 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 33: Node advancer - advancing to IDENTIFY_NODE
2021-04-24 22:45:54.993 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 17: SECURITY not supported
2021-04-24 22:45:54.993 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 33: Node advancer: Initialisation starting from inclusion
2021-04-24 22:45:54.993 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 17: Received COMMAND_CLASS_ALARM V4 NOTIFICATION_REPORT
2021-04-24 22:45:54.993 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: sendTransaction org.openhab.binding.zwave.internal.protocol.ZWaveSerialPayload@185bf58
2021-04-24 22:45:54.994 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 17: NOTIFICATION report - 0 = 0, event=0, status=255, plen=0
2021-04-24 22:45:54.994 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 17: Alarm Type = BURGLAR (0)
2021-04-24 22:45:54.994 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 17: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2021-04-24 22:45:54.995 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 17: Got a value event from Z-Wave network, endpoint=2, command class=COMMAND_CLASS_ALARM, value=255
2021-04-24 22:45:54.995 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added 5319 to queue - size 1
2021-04-24 22:45:54.995 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 17: Alarm converter processing NOTIFICATION
2021-04-24 22:45:54.996 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 17: Alarm converter NOTIFICATION event is 0, type OnOffType
2021-04-24 22:45:54.996 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 17: Updating channel state zwave:device:c3f88d21c6:node17:alarm_motion2 to OFF [OnOffType]
2021-04-24 22:45:54.997 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-04-24 22:45:54.997 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 17: Commands processed 1.
2021-04-24 22:45:54.997 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 17: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@d7f80b.
2021-04-24 22:45:54.998 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2021-04-24 22:45:54.999 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=CAN[4], dest=255, callback=0, payload=
2021-04-24 22:45:55.000 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 5318: [WAIT_REQUEST] priority=Controller, requiresResponse=true, callback: 25
2021-04-24 22:45:55.000 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Holdoff Timer started...
2021-04-24 22:45:55.001 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 5318: Resetting transaction
2021-04-24 22:45:55.001 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: notifyTransactionResponse TID:5318 WAIT_REQUEST
2021-04-24 22:45:55.002 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added 5318 to queue - size 2
2021-04-24 22:45:55.003 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff true.
2021-04-24 22:45:55.003 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-04-24 22:45:55.004 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff true.
2021-04-24 22:45:55.251 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-04-24 22:45:55.258 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 05 00 4A 05 19 AC
2021-04-24 22:45:55.259 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 05 00 4A 05 19 AC
2021-04-24 22:45:55.260 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2021-04-24 22:45:55.261 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2021-04-24 22:45:55.261 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 5318: [WAIT_REQUEST] priority=Controller, requiresResponse=true, callback: 25
2021-04-24 22:45:55.261 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2021-04-24 22:45:55.262 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2021-04-24 22:45:55.263 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 5318: [WAIT_REQUEST] priority=Controller, requiresResponse=true, callback: 25
2021-04-24 22:45:55.263 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2021-04-24 22:45:55.264 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-04-24 22:45:55.264 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-04-24 22:45:55.420 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 4A 19 06 21 00 8C
2021-04-24 22:45:55.421 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=AddNodeToNetwork[74], type=Request[0], dest=6, callback=25, payload=19 06 21 00
2021-04-24 22:45:55.422 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=AddNodeToNetwork[74], type=Request[0], dest=6, callback=25, payload=19 06 21 00
2021-04-24 22:45:55.423 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 5318: [WAIT_REQUEST] priority=Controller, requiresResponse=true, callback: 25
2021-04-24 22:45:55.424 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2021-04-24 22:45:55.424 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 5318: [WAIT_REQUEST] priority=Controller, requiresResponse=true, callback: 25
2021-04-24 22:45:55.424 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 5318: (Callback 25)
2021-04-24 22:45:55.425 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2021-04-24 22:45:55.425 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 5318: callback 25
2021-04-24 22:45:55.426 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=AddNodeToNetwork[74], type=Request[0], dest=6, callback=25, payload=19 06 21 00
2021-04-24 22:45:55.427 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Add Node: Done.
2021-04-24 22:45:55.427 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 33: Device discovered
2021-04-24 22:45:55.430 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:c3f88d21c6:node33' to inbox.
2021-04-24 22:45:55.431 [DEBUG] [al.protocol.ZWaveInclusionController] - Inclusion event: Current state IncludeProtocolDone, new event IncludeDone
2021-04-24 22:45:55.431 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Ending INCLUSION mode.
2021-04-24 22:45:55.433 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added 5320 to queue - size 2
2021-04-24 22:45:55.433 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-04-24 22:45:55.434 [DEBUG] [al.protocol.ZWaveInclusionController] - ZWave controller end exclusion
2021-04-24 22:45:55.434 [DEBUG] [ve.internal.protocol.ZWaveController] - ZWaveController include done
2021-04-24 22:45:55.435 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 5318: Advanced to DONE
2021-04-24 22:45:55.435 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Response processed after 174ms
2021-04-24 22:45:55.436 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: TID 5318: Transaction completed
2021-04-24 22:45:55.436 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: notifyTransactionResponse TID:5318 DONE
2021-04-24 22:45:55.437 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-04-24 22:45:55.438 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-04-24 22:45:55.438 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 00 41 21 9B
2021-04-24 22:45:55.439 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 04 00 41 21 9B
2021-04-24 22:45:55.440 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2021-04-24 22:45:55.441 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 5319: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2021-04-24 22:45:55.441 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2021-04-24 22:45:55.442 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2021-04-24 22:45:55.442 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2021-04-24 22:45:55.443 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 5319: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2021-04-24 22:45:55.443 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 01 41 D3 9C 01 04 10 01 ED
2021-04-24 22:45:55.443 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2021-04-24 22:45:55.444 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-04-24 22:45:55.444 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-04-24 22:45:55.444 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=IdentifyNode[65], type=Response[1], dest=255, callback=0, payload=D3 9C 01 04 10 01
2021-04-24 22:45:55.444 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=IdentifyNode[65], type=Response[1], dest=255, callback=0, payload=D3 9C 01 04 10 01
2021-04-24 22:45:55.445 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 5319: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2021-04-24 22:45:55.445 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2021-04-24 22:45:55.445 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 5319: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2021-04-24 22:45:55.446 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=IdentifyNode[65], type=Response[1], dest=255, callback=0, payload=D3 9C 01 04 10 01
2021-04-24 22:45:55.446 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 33: ProtocolInfo
2021-04-24 22:45:55.447 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 33: Listening = true
2021-04-24 22:45:55.447 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 33: Routing = true
2021-04-24 22:45:55.447 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 33: Beaming = true
2021-04-24 22:45:55.448 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 33: Version = 4
2021-04-24 22:45:55.448 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 33: FLIRS = false
2021-04-24 22:45:55.448 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 33: Security = false
2021-04-24 22:45:55.448 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 33: Max Baud = 40000
2021-04-24 22:45:55.448 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 33: Basic = BASIC_TYPE_ROUTING_SLAVE
2021-04-24 22:45:55.449 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 33: Generic = GENERIC_TYPE_SWITCH_BINARY
2021-04-24 22:45:55.449 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 33: Specific = SPECIFIC_TYPE_POWER_SWITCH_BINARY
2021-04-24 22:45:55.449 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Creating new instance of command class COMMAND_CLASS_NO_OPERATION
2021-04-24 22:45:55.449 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Command class COMMAND_CLASS_NO_OPERATION, endpoint 0 created
2021-04-24 22:45:55.450 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Version = 1, version set. Enabling extra functionality.
2021-04-24 22:45:55.450 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Adding command class COMMAND_CLASS_NO_OPERATION to the list of supported command classes.
2021-04-24 22:45:55.450 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Creating new instance of command class COMMAND_CLASS_BASIC
2021-04-24 22:45:55.451 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Command class COMMAND_CLASS_BASIC, endpoint 0 created
2021-04-24 22:45:55.451 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Adding command class COMMAND_CLASS_BASIC to the list of supported command classes.
2021-04-24 22:45:55.451 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 5319: Transaction COMPLETED
2021-04-24 22:45:55.451 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Response processed after 10ms
2021-04-24 22:45:55.452 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: TID 5319: Transaction completed
2021-04-24 22:45:55.452 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: notifyTransactionResponse TID:5319 DONE
2021-04-24 22:45:55.452 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-04-24 22:45:55.453 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 5319: Transaction event listener: DONE: DONE ->
2021-04-24 22:45:55.453 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-04-24 22:45:55.453 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 05 00 4A 05 00 B5
2021-04-24 22:45:55.454 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 05 00 4A 05 00 B5
2021-04-24 22:45:55.455 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2021-04-24 22:45:55.455 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 5320: [WAIT_REQUEST] priority=Controller, requiresResponse=true, callback: 0
2021-04-24 22:45:55.455 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2021-04-24 22:45:55.456 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2021-04-24 22:45:55.456 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 33: Node Init response (0) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@17dd428
2021-04-24 22:45:55.456 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 33: Node Init transaction completed with response COMPLETE
2021-04-24 22:45:55.456 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2021-04-24 22:45:55.457 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 5320: [WAIT_REQUEST] priority=Controller, requiresResponse=true, callback: 0
2021-04-24 22:45:55.457 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2021-04-24 22:45:55.457 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
(obviously extends for about 3000 lines or so, but guessing this is as much as I can add to a post)
