I am running Openhab 2.5.7 Just today I am getting the following error. any help would be appreciated.
2020-08-20 18:24:08.325 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type ‘mios’ of item ‘SystemZWaveStatusString’ could not be parsed correctly.
org.eclipse.smarthome.model.item.BindingConfigParseException: Config for item ‘SystemZWaveStatusString’ could not be parsed. Bad thing format ‘unit:homeVera, system:/ZWaveStatus,in:MAP(miosZWaveStatusIn.map)’
at org.openhab.core.binding.internal.BindingConfigReaderDelegate.processBindingConfiguration(BindingConfigReaderDelegate.java:55) ~[?:?]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:369) ~[?:?]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:338) ~[?:?]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.processBindingConfigsFromModel(GenericItemProvider.java:210) ~[?:?]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.modelChanged(GenericItemProvider.java:404) ~[?:?]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:311) ~[?:?]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:149) ~[?:?]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.checkFile(FolderObserver.java:247) ~[?:?]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.processWatchEvent(FolderObserver.java:310) ~[?:?]
at org.eclipse.smarthome.core.service.WatchQueueReader.lambda$3(WatchQueueReader.java:323) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_265]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_265]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_265]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:1.8.0_265]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_265]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_265]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_265]
Caused by: org.openhab.model.item.binding.BindingConfigParseException: Config for item ‘SystemZWaveStatusString’ could not be parsed. Bad thing format ‘unit:homeVera, system:/ZWaveStatus,in:MAP(miosZWaveStatusIn.map)’
at org.openhab.binding.mios.internal.MiosBindingProviderImpl.parseBindingConfig(MiosBindingProviderImpl.java:183) ~[?:?]
at org.openhab.binding.mios.internal.MiosBindingProviderImpl.processBindingConfiguration(MiosBindingProviderImpl.java:142) ~[?:?]
at org.openhab.core.binding.internal.BindingConfigReaderDelegate.processBindingConfiguration(BindingConfigReaderDelegate.java:53) ~[?:?]
… 16 more
