I have just installed Openhabian on a new PI3, works fine and I have been able to bind Hue, Sonos and Network stuff. I d also have a Vera Controller, and therefore what to use the MIOS binding. I can Install it, but I can’t find it under “Configuration/Things” and there not configure it. I have tried to google for some documentation/guidelines – can someone point me in the right direction? – I’m using PaperUI
This is a OH1 binding so it needs to be configured through text files. Things do not exist for this binding and it cannot be configured through paperui.
See the OH1 Wiki.
Thanks I have the WiKi, it ask me to change openhab.cfg file, but dont tell where this is, I can’t find in on my RPI3 with Openhabian, It might have changed in OH2?
I think it should be in /etc/openhab2/services
first make it with sudo touch openhab.cfg if it does not exist and then copy the MIOS related lines in it
Does not work for me, I have restarted with a completely new image, followed the wiki, but MIOS does hot show up in the PaperUI. I have been editing files, downloaded transformations – ensured that bindings for MIOS are installed . In addons.cfg file mios is labeled mios1, I therefore copied mios.cfg to mios1.cfg in the /etc/openhab2/services folder (and changed group and owner permissions), but that does not change anything. I have entered the IP address of my mios of cause and removed the “#”
For ensuring that my installation is working, I have installed SONOS binding, and that works as expected.
Any idea of what to try now?
mios binding wont install in openhab2. below is output from log
14:52:09.103 [ERROR] [org.eclipse.smarthome.io.rest.sse ] - FrameworkEvent ERROR - org.eclipse.smarthome.io.rest.sse
org.osgi.framework.BundleException: Exception in org.eclipse.smarthome.io.rest.sse.internal.SseActivator.start() of bundle org.eclipse.smarthome.io.rest.sse.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:792)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:721)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:941)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:318)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.Module.doStart(Module.java:571)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.Module.start(Module.java:439)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:454)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer.applyDelta(ModuleContainer.java:717)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer.resolveAndApply(ModuleContainer.java:491)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer.resolve(ModuleContainer.java:437)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer.refresh(ModuleContainer.java:955)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerWiring.dispatchEvent(ModuleContainer.java:1336)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerWiring.dispatchEvent(ModuleContainer.java:1)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
Caused by: java.lang.LinkageError: ClassCastException: attempting to castbundleresource://22.fwk24205760/javax/ws/rs/ext/RuntimeDelegate.class to bundleresource://22.fwk24205760/javax/ws/rs/ext/RuntimeDelegate.class
at javax.ws.rs.ext.RuntimeDelegate.findDelegate(RuntimeDelegate.java:146)
at javax.ws.rs.ext.RuntimeDelegate.getInstance(RuntimeDelegate.java:120)
at javax.ws.rs.core.MediaType.valueOf(MediaType.java:179)
at org.glassfish.jersey.media.sse.SseFeature.(SseFeature.java:62)
at org.eclipse.smarthome.io.rest.sse.internal.SseActivator.start(SseActivator.java:44)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:771)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at java.security.AccessController.doPrivileged(Native Method)[:1.8.0_121]
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:764)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
… 14 more
14:52:09.400 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
14:52:09.723 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
14:52:10.685 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-binding-mios1’: Error restarting bundles
