I am new to openhab so any help is greatly appreciated. I’m trying to get the mios binding to work in openhab 1.8.0. I was following the tutorial under the mios binding page. I am using a vera edge controller. I named the controller “house”.
I copied the mios binding file into the addons folder. I also put all of the mios map files in the transform folder.
in my config file I put:
mios:house.host=192.168.2.22
I used the item generator to generate a list of items. Here is one of the item codes it generated:
String KitchenLightDeviceStatus “Kitchen Light Device Status [MAP(miosDeviceStatusUI.map):%s]” (GDevices) {mios=“unit:house,device:25/status”}
when I look at the mios log I get this:
2016-02-22 21:54:22.916 [DEBUG] [.b.mios.internal.MiosActivator] - MiOS binding has been started
2016-02-22 21:54:22.929 [DEBUG] [.o.b.mios.internal.MiosBinding] - MiosBinding activate()
2016-02-22 21:54:22.974 [TRACE] [.o.b.mios.internal.MiosBinding] - MiosBinding updated()
2016-02-22 21:54:22.975 [DEBUG] [.o.b.mios.internal.MiosBinding] - updated: Created Unit 'house’
2016-02-22 21:54:22.976 [DEBUG] [.o.b.mios.internal.MiosBinding] - registerAllWatches: start
To test and see if everything was working in my sitemap I put this:
Text item=KitchenLightDeviceStatus
I get this in the runtime:
2016-02-22 22:06:30.782 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘miosDeviceStatusUI.map’.
Which I’m guessing is because it’s not actually connected to my veraedge. Any idea’s on what I did wrong in my setup?
