I have opened a Github bug already for this but wanted to see if anyone else is having the issue. I can no longer control my thermostat via OH2, it worked fine under OH1. I have checked permissions and the rest of the transformation files are opening fine and working correctly for things like switches and dimmers.
Updated to the new transformation files and now receiving the following stack trace…
2016-10-07 23:49:00.927 [ERROR] [ab.binding.mios.internal.MiosBinding] - Error handling command
org.openhab.core.transform.TransformationException: An error occured while opening file.
at org.openhab.core.transform.TransformationHelper$TransformationServiceDelegate.transform(TransformationHelper.java:63)[196:org.openhab.core.compat1x:2.0.0.201610072017]
at org.openhab.binding.mios.internal.config.DeviceBindingConfig.transformCommand(DeviceBindingConfig.java:442)[195:org.openhab.binding.mios:1.9.0.201610070111]
at org.openhab.binding.mios.internal.MiosUnitConnector.callDevice(MiosUnitConnector.java:192)[195:org.openhab.binding.mios:1.9.0.201610070111]
at org.openhab.binding.mios.internal.MiosUnitConnector.invokeCommand(MiosUnitConnector.java:378)[195:org.openhab.binding.mios:1.9.0.201610070111]
at org.openhab.binding.mios.internal.MiosBinding.internalReceiveCommand(MiosBinding.java:271)[195:org.openhab.binding.mios:1.9.0.201610070111]
at org.openhab.core.binding.AbstractBinding.receiveCommand(AbstractBinding.java:97)[196:org.openhab.core.compat1x:2.0.0.201610072017]
at org.openhab.core.events.AbstractEventSubscriber.handleEvent(AbstractEventSubscriber.java:42)[196:org.openhab.core.compat1x:2.0.0.201610072017]
at org.apache.felix.eventadmin.impl.handler.EventHandlerProxy.sendEvent(EventHandlerProxy.java:415)[3:org.apache.karaf.services.eventadmin:4.0.4]
at org.apache.felix.eventadmin.impl.tasks.HandlerTask.run(HandlerTask.java:90)[3:org.apache.karaf.services.eventadmin:4.0.4]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_91]
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_91]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_91]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_91]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_91]
