I recently helped to create a backup on an older openHABian install (raspi 3b+, openhabian1.6.x/buster, all updates installed - including openhabian-config [stable]patchday-20210119-1121(1c01b34)).
At the end of the process of mirroring the SD card, i got some messages:
2022-02-01_13:57:21_CET [openHABian] Checking for root privileges... OK
2022-02-01_13:57:22_CET [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2022-02-01_13:57:22_CET [openHABian] openHABian configuration tool version: [stable]patchday-20210119-1121(1c01b34)
2022-02-01_13:57:22_CET [openHABian] Checking for changes in origin branch stable... OK
2022-02-01_13:57:25_CET [openHABian] Switching to branch stable... OK
2022-02-01_13:57:33_CET [openHABian] Setting up automated SD mirroring and backup... OK
Failed to stop storage.mount: Unit storage.mount not loaded.
Checking that no-one is using this disk right now ... OK
Disk /dev/sda: 29,8 GiB, 32010928128 bytes, 62521344 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0xcadecd3d
Old situation:
Device Boot Start End Sectors Size Id Type
/dev/sda1 8192 532479 524288 256M c W95 FAT32 (LBA)
/dev/sda2 532480 62521343 61988864 29,6G 83 Linux
>>> Script header accepted.
>>> Created a new DOS disklabel with disk identifier 0x07a44229.
/dev/sda1: Created a new partition 1 of type 'W95 FAT32 (LBA)' and of size 41,8 MiB.
Partition #1 contains a vfat signature.
/dev/sda2: Created a new partition 2 of type 'Linux' and of size 29,2 GiB.
/dev/sda3: Created a new partition 3 of type 'Linux' and of size 589 MiB.
/dev/sda4: Done.
New situation:
/dev/sda1 8192 93802 85611 41,8M c W95 FAT32 (LBA)
/dev/sda2 98304 61315071 61216768 29,2G 83 Linux
/dev/sda3 61315072 62521343 1206272 589M 83 Linux
The partition table has been altered.
Calling ioctl() to re-read partition table.
Syncing disks.
Taking a raw partition copy, be prepared this may take long such as 20-30 minutes for a 16 GB SD card
umount: UngĂĽltige Option -- q
Usage:
umount [-hV]
umount -a [options]
umount [options] <source> | <directory>
Unmount filesystems.
Options:
-a, --all unmount all filesystems
-A, --all-targets unmount all mountpoints for the given device in the
current namespace
-c, --no-canonicalize don't canonicalize paths
-d, --detach-loop if mounted loop device, also free this loop device
--fake dry run; skip the umount(2) syscall
-f, --force force unmount (in case of an unreachable NFS system)
-i, --internal-only don't call the umount.<type> helpers
-n, --no-mtab don't write to /etc/mtab
-l, --lazy detach the filesystem now, clean up things later
-O, --test-opts <list> limit the set of filesystems (use with -a)
-R, --recursive recursively unmount a target with all its children
-r, --read-only in case unmounting fails, try to remount read-only
-t, --types <list> limit the set of filesystem types
-v, --verbose say what is being done
-h, --help display this help and exit
-V, --version output version information and exit
For more details see umount(8).
Usage:
umount [-hV]
umount -a [options]
Options:
current namespace
OK
OK
(Parts of) the SD Card is still mounted:
mount
/dev/sda3 on /storage type ext4 (rw,relatime)
Some investigation brought me to /opt/openhabian/funtions/backup.bash. Searching for “umount” gives some lines like
umount -q <something>
Looking up some manuals, i did not find an optional -q for umount. Even the man-pages for bullseye do not show -q.
I then took a look on github into the current code of backup.bash. It still uses “umount -q”.
The new SD-card is fine anyway.
As allways: this may be my fault. Maybe somebody want’s to check, what’s real.
