I just installed openHABian and the network binding.
I just went through the documentation of the network binding at
and wondering about some mismatches.
Just for reference, the example thing definition of the documentation looks this this: network:pingdevice:one_device [ hostname="192.168.0.64" ]
but I need to use “device” to get it working on my machine: network:device:one_device [ hostname="192.168.0.64" ]
Also for the channels there seems to be an issue.
The docu reports about
online
lastseen
latency
but I can see only
online
time
Am I using an outdated version of the binding?
How may I figure out?
I was on the stable branch and just moved to the latest and greatest 2.2
Now the binding behaves as documented.
Nevertheless, I looking for full examples for manual thing configurations,
especially for iPhones.
My device is detected only if it is actively in use.
When the device is locked it appears directly as offline.
I tried different setings.
This is my current one:
network:device:192_168_0_test [hostname=“192.168.0.101”, uses_ios_wakeup=1, uses_arp_pings=1, refresh_interval=5000]
Which OS dependencies are there?
Somewhere I read about libpcap.
Apple iOS devices are usually in a deep sleep mode and do not respond to ARP pings under all conditions, but to Bonjour service discovery messages (UDP port 5353). Therefore first a Bonjour message is send, before the ARP presence detection is performed. The binding automatically figures out if the target device is an iOS device. You can check if the binding has correctly recognised your device by having a look at the uses_ios_wakeup property of your thing.
thanks for the hint. I have seen this. But it does not work for me.
My iPhone isn’t detected properly and it is not listed as iOS device.
So I would like to define the thing, item and sitemap entry manually,
not using the autodiscovery.
For me it isn’t clear which parameter have to be set to force described behavior.
Furthermore, which log entry are generated to check proper function.
This is my thing definition: network:device:192_168_0_test [hostname="192.168.0.101", uses_ios_wakeup=1, uses_arp_pings=1, refresh_interval=5000]
How does it need to look like for an iOS device?
Do I have to configure testing on port 5353 manually?
Is there someone who manage to get it running on an RPI3 with openhabian?
I have the devices showing up in my OpenHab app as expected. I’m not expecting very precise results, so I’m ok with wat I see. Here is my “thing” config.
Strange thing is, the values show in the log files as well as the Basic-UI, but not on my IOS app.
I also am getting these errors in the log file.
2017-12-04 07:48:09.492 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update ‘ON’ for item ‘Thing1’ to handler for channel ‘network:device:Thing1:online’, because no thing with the UID ‘network:device:Thing1’ could be found.
2017-12-04 07:48:09.501 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update ‘19.232616’ for item ‘Thing1ResponseTime’ to handler for channel ‘network:pingdevice:Thing1:latency’, because no thing with the UID ‘network:pingdevice:Thing1’ could be found.
2017-12-04 07:48:09.504 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update ‘19.232616’ for item ‘Thing1ResponseTime’ to handler for channel ‘network:device:Thing1:time’, because no thing with the UID ‘network:device:Thing1’ could be found.
2017-12-04 07:48:09.592 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update ‘ON’ for item ‘Thing2’ to handler for channel ‘network:device:Thing2:online’, because no thing with the UID ‘network:device:Thing2’ could be found.
2017-12-04 07:48:09.598 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update ‘17.244766’ for item ‘Thing2ResponseTime’ to handler for channel ‘network:pingdevice:Thing2:latency’, because no thing with the UID ‘network:pingdevice:Thing2’ could be found.
Sorry that is a bit ambiguous . I mean to say the devices show “on” and “off” as expected in my iOS Openhab app, but last seen and pingtime does not have any values.
