As you can see in the picture below, I have no menu options for Add-ons, so I can’t add any binding, etc. Has any one else had this problem? If so, how do you fix it?
I am running the latest production release of 3.0.1
TIA,
James
TIA,
James
Did you try clearing your browser cache?
Interestingly the same report popped up in the german Facebook group today. I also adviced clearing browser cache. But there must be a reason why this appears now.
I do know Chrome browser caching can pe particularly troublesome.
Clearing the Browser Cache did not correct the problem. Any other guesses for a solution?
Could you open the developer tools of your browser and check if there are any errors displayed?
(For chrome you can do this by pressing F12. I would have to check for other browsers.)
Maybe it is showing some errors which will help finding the cause if this problem.
F12 works for Firefox too
I am apparent getting the following error
Try cleaning openhab cache. That solved it for someone else
Cleaning the cache did the trick
Thanks!!
