however under MainUI>Setting>Persistance i cannot see any settings and persistence does not work (for example I do not see any graphed values from the UI)
What are the steps to activate rrd4j persistence and data graphs from Eclipse?
Thanks, but id does not work.
I added first just org.openhab.persistence.rrd4j as suggested. Then added also org.openhab.core.model.persistence.ide to “Run Requirements” just in case.
All these modules appear to be ACTIVE if I ask lb to Felix Gogo:
but if I go under MainUI>Setting>Persistance I cannot find any settings.
Actually ALL setting under System Services are empty (Regional, Network, etc.).
In anything else that need to be activated?
mmm… strange:
if I checkout openhab-addons/main, openhab-distro/launch-rrd4j-app then launch app.bndrun it takes long to start, CPU 100%, then gives this error:
____________________________
Welcome to Apache Felix Gogo
g! 17:38:04.557 [INFO ] [org.openhab.ui.internal.UIService ] - Started UI on port 8080
Exception in thread "pool-1-thread-1" java.lang.OutOfMemoryError: Java heap space
at java.base/java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.addConditionWaiter(AbstractQueuedSynchronizer.java:1896)
at java.base/java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2114)
at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:1182)
at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:899)
at java.base/java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1054)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1114)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.base/java.lang.Thread.run(Thread.java:834)
however the rrd4j Persistance is there (I can see the Persistence rrd4j config from MainUI).
After: I stop, add astro or another binding the usual way (pom.xml + app.bndrun + Resolve) it takes very long to Resolve with CPU 100%, then if I run Debug OSGi again, Persistence is not there anymore.
