Ah, new to me, including devices over paperUI.
I always did this over the button on the GEN5 stick.
But seems itās not working perfect for this node.
At one moment, I got it 2 times (node 56 en node 57) after eachother, but not fully recognized.
My stick (secure mode) is set to all devices.
Any tip what I could try next?
The inclusion debug log of the keypad: openhab.log (254.5 KB)
Not sure if this issue is direcly linked with the ābad inclusionā. But when I played around with the parameters of the USB stick (fe low power, high powerā¦), sometimes my stick ādiedā. All my other nodes wonāt react anymore. A reboot solved the issue. I could find this in the logs:
2019-02-06 19:40:34.632 [ERROR] [lmessage.RequestNodeInfoMessageClass] - Request node info not placed on stack due to error.
2019-02-06 19:40:34.890 [ERROR] [lmessage.RequestNodeInfoMessageClass] - Request node info not placed on stack due to error.
2019-02-06 19:40:35.148 [ERROR] [lmessage.RequestNodeInfoMessageClass] - Request node info not placed on stack due to error.
2019-02-06 19:40:36.789 [ERROR] [lmessage.RequestNodeInfoMessageClass] - Request node info not placed on stack due to error.
Iām not 100% sure that this is the problem, but there is a timer that is going off, potentially before the inclusion is completed. I am a little sceptical that this is the problem since there is still 15 seconds for the protocol to complete, but maybe for some reason, this device is taking a long time.
I will look at doing an update to stop this and we can see if that helps.
Bought me a new USB Gen5 Stick (UGS3) for testing. And when I install the same version OH (2.5m) on a Linux Mint desktop, I can nicely add the keypad in secure mode. So it worksā¦ (in this situation).
But when I try to add the keypad on my āday-to-dayā server, I can only add this node in ānon-secureā mode?
Sometimes I had it found in the inbox, but couldnāt get it to initialiseā¦
2019-02-11 17:11:48.616 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:30038385:node69' to inbox.
2019-02-11 17:11:48.618 [home.event.InboxAddedEvent] - Discovery Result with UID 'zwave:device:30038385:node69' has been added.
2019-02-11 17:11:48.624 [arthome.event.BindingEvent] - org.openhab.binding.zwave.event.BindingEvent@46b2fa1
2019-02-11 17:11:50.855 [arthome.event.BindingEvent] - org.openhab.binding.zwave.event.BindingEvent@3bea9663
2019-02-11 17:11:52.885 [arthome.event.BindingEvent] - org.openhab.binding.zwave.event.BindingEvent@76bdab0a
2019-02-11 17:12:09.847 [me.event.InboxRemovedEvent] - Discovery Result with UID 'zwave:device:30038385:node69' has been removed.
2019-02-11 17:12:09.863 [hingStatusInfoChangedEvent] - 'zwave:device:30038385:node69' changed from UNINITIALIZED to INITIALIZING
2019-02-11 17:12:09.865 [hingStatusInfoChangedEvent] - 'zwave:device:30038385:node69' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2019-02-11 17:12:09.865 [hingStatusInfoChangedEvent] - 'zwave:device:30038385:node69' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
Maybe some details about this installation?
Itās a virtual Linux Ubuntu machine under proxmox (Hypervisor), and Iāve got 2 USB Gen5 sticks (=UGS1 & UGS2) in this setup. For testing, Iāve disabled the second stick (USG2), this way, I wouldnāt get a conflict with the stick (USG1) I need to sync.
On stick USG1, Iāve got now about 65 zwave nodes. About 20 are dummies/ghosts/ā¦ I really need to clean out once. on stick USG2, about 20 nodes, with about 5 dummies/ghostsā¦
Iāve also played with the different power levels settings, changed the network keyā¦ But nothing worked.
I would like to say that itās a problem with the virtualization. But since everything else works, except the secure mode, not sure where to lookā¦
ps not sure if I can add the keypad to my normal stick on the standalone machine, and move this later on towards the day-to-day server? If I just keep the network key on both servers the same?
