fba1
(François Ballant)
November 8, 2022, 3:16pm
1
I received today new Z-Wave radiator Thermostat ( Coqon / AV2011/38) . ( Manufacturer : SMaBiT GmbH )
The radiator thermostat was intended to be similar as the Eurotronic Comet Z … as mentionned in the product catalog.
Anyway during the inclusion phase I got this error message …
2022-11-08 15:52:36.462 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 19: Device discovery could not resolve to a thingType! 0148:0001:0002::0.5
What can I do to move forward ? Can I do something to force mimic the Comet Z ?
Thanks a lot,
Fr,
IMG_20221108_0001.pdf (811.9 KB)
apella12
(Bob Eckhoff)
November 8, 2022, 3:47pm
2
Should be there . May need to wake again. What version of OH are you on?
fba1
(François Ballant)
November 8, 2022, 3:57pm
3
I already tried several times … no change … Using OH 3.3
Eurotronics Comet Z seems to have the id : 0148:0002:0001 whereas the new one I got is perhaps … 0148:0001:0002 … or is it only because of the end … ::0.5 ?
apella12
(Bob Eckhoff)
November 8, 2022, 4:15pm
4
My bad. Did not see that the numbers were reversed. The new pair will need to be added.
fba1
(François Ballant)
November 8, 2022, 4:26pm
5
Thanks … How can we do that ? Do I need to take some action to make it happen ?
apella12
(Bob Eckhoff)
November 8, 2022, 5:21pm
6
Normally this is a user-maintained DB (i.e. “we” is “you”). There is a blog on how to get read, and then open a ticket for write access. Since I expect a DB update any day now by the maintainer, I just went ahead and added the pair this time, so you will not have to wait too long. You will have to use a snapshot zwave .jar once the change is approved and merged, hopefully in a few days.
apella12
(Bob Eckhoff)
November 13, 2022, 5:45pm
7
The snapshot jar (#190 ) is now available with the new device TYPE:ID. May want to test.
fba1
(François Ballant)
November 14, 2022, 9:05am
8
I’ve seen that yesterday … Now I’ve to see how I have to first migrate from version 3.3 stable up to 4 snapshot … Will do that in the coming days … Thanks again !
fba1
(François Ballant)
November 17, 2022, 4:00pm
10
Thanks a lot …The device is now well recognized by Openhab but I’m continuing facing issues with the device that does not react as expected … it’s probably a too cheap device I would not recommend ( difficult to find the micro switch in the batteries box, init phase that does not finish, … ) . I’m going still have a trial this evening … if it does not succeed I’ll return the device towards Amazon …
fba1
(François Ballant)
November 18, 2022, 6:25pm
11
This is the .xml file generated after a successfull init …
Still have to test it a bit before being able to conclude …
/var/lib/openhab/zwave/network_ece992cc__node_20.xml
<node>
<homeId>0xece992cc</homeId>
<nodeId>20</nodeId>
<version>4</version>
<manufacturer>0x148</manufacturer>
<deviceId>0x2</deviceId>
<deviceType>0x1</deviceType>
<listening>false</listening>
<frequentlyListening>false</frequentlyListening>
<routing>true</routing>
<security>false</security>
<beaming>true</beaming>
<maxBaudRate>40000</maxBaudRate>
<sleepDelay>500</sleepDelay>
<nodeInformationFrame>
<commandClass>COMMAND_CLASS_BASIC</commandClass>
<commandClass>COMMAND_CLASS_SWITCH_MULTILEVEL</commandClass>
<commandClass>COMMAND_CLASS_SENSOR_MULTILEVEL</commandClass>
<commandClass>COMMAND_CLASS_THERMOSTAT_MODE</commandClass>
<commandClass>COMMAND_CLASS_THERMOSTAT_SETPOINT</commandClass>
<commandClass>COMMAND_CLASS_NODE_NAMING</commandClass>
<commandClass>COMMAND_CLASS_BATTERY</commandClass>
<commandClass>COMMAND_CLASS_WAKE_UP</commandClass>
<commandClass>COMMAND_CLASS_MANUFACTURER_SPECIFIC</commandClass>
<commandClass>COMMAND_CLASS_VERSION</commandClass>
</nodeInformationFrame>
<associationGroups class="concurrent-hash-map"/>
<endpoints class="concurrent-hash-map">
<entry>
<int>0</int>
<endPoint>
<deviceClass>
<basicDeviceClass>BASIC_TYPE_ROUTING_SLAVE</basicDeviceClass>
<genericDeviceClass>GENERIC_TYPE_THERMOSTAT</genericDeviceClass>
<specificDeviceClass>SPECIFIC_TYPE_THERMOSTAT_GENERAL_V2</specificDeviceClass>
</deviceClass>
<endpointId>0</endpointId>
<secureCommandClasses/>
<supportedCommandClasses class="concurrent-hash-map">
<entry>
<commandClass>COMMAND_CLASS_NO_OPERATION</commandClass>
<COMMAND__CLASS__NO__OPERATION>
<version>1</version>
<instances>1</instances>
<control>false</control>
<versionSupported>1</versionSupported>
</COMMAND__CLASS__NO__OPERATION>
</entry>
<entry>
<COMMAND__CLASS__BASIC>
<isGetSupported>true</isGetSupported>
</COMMAND__CLASS__BASIC>
</entry>
<entry>
<multiLevelSwitchCommandClass>
<version>3</version>
<versionSupported>3</versionSupported>
<switchTypePrimary>CLOSE_OPEN</switchTypePrimary>
<switchTypeSecondary>UNDEFINED</switchTypeSecondary>
</multiLevelSwitchCommandClass>
</entry>
<entry>
<COMMAND__CLASS__SENSOR__MULTILEVEL>
<versionSupported>4</versionSupported>
<sensors>
<entry>
<multilevelSensorType>TEMPERATURE</multilevelSensorType>
<multilevelSensor>
<sensorType>TEMPERATURE</sensorType>
<initialised>true</initialised>
</multilevelSensor>
</entry>
</sensors>
</COMMAND__CLASS__SENSOR__MULTILEVEL>
</entry>
<entry>
<COMMAND__CLASS__THERMOSTAT__MODE>
<modeTypes>
<modeType>OFF</modeType>
<modeType>HEAT</modeType>
<modeType>HEAT_ECON</modeType>
<modeType>MANUAL</modeType>
</modeTypes>
</COMMAND__CLASS__THERMOSTAT__MODE>
</entry>
<entry>
<COMMAND__CLASS__THERMOSTAT__SETPOINT>
<setpoints>
<entry>
<setpointType>HEATING</setpointType>
<setpoint>
<initCount>0</initCount>
<outer-class reference="../../../.."/>
</setpoint>
</entry>
<entry>
<setpointType>FURNACE</setpointType>
<setpoint>
<initialised>false</initialised>
<initCount>1</initCount>
</setpoint>
</entry>
</setpoints>
</COMMAND__CLASS__THERMOSTAT__SETPOINT>
</entry>
<entry>
<COMMAND__CLASS__MANUFACTURER__SPECIFIC>
<initSerialNumber>false</initSerialNumber>
<deviceManufacturer>328</deviceManufacturer>
<deviceType>1</deviceType>
<deviceId>2</deviceId>
</COMMAND__CLASS__MANUFACTURER__SPECIFIC>
</entry>
<entry>
<COMMAND__CLASS__NODE__NAMING>
<name></name>
<location></location>
</COMMAND__CLASS__NODE__NAMING>
</entry>
<entry>
<COMMAND__CLASS__BATTERY>
<batteryLevel>100</batteryLevel>
<batteryLow>false</batteryLow>
</COMMAND__CLASS__BATTERY>
</entry>
<entry>
<COMMAND__CLASS__WAKE__UP>
<version>2</version>
<versionSupported>2</versionSupported>
<targetNodeId>1</targetNodeId>
<interval>604620</interval>
<minInterval>240</minInterval>
<maxInterval>15728400</maxInterval>
<defaultInterval>604672</defaultInterval>
<intervalStep>240</intervalStep>
</COMMAND__CLASS__WAKE__UP>
</entry>
<entry>
<COMMAND__CLASS__VERSION>
<libraryType>LIB_SLAVE_ENHANCED</libraryType>
<protocolVersion>3.67</protocolVersion>
<applicationVersion>0.5</applicationVersion>
</COMMAND__CLASS__VERSION>
</entry>
</supportedCommandClasses>
</endPoint>
</entry>
</endpoints>
<nodeNeighbors/>
<lastReceived>2022-11-16 12:51:21.741 UTC</lastReceived>
system
(system)
Closed
December 30, 2022, 10:26am
12
