Mitsubishi Electric Kumo Cloud Binding (MHK2)
Hi-
Thanks for the fast reply! Glad to hear it’s working so far. I’ve got a wireless thermostat (an external thermostat is mandatory for ducted air handlers), and it’s got a humidity sensor, but the humidity doesn’t show up in the same place as the temperature, so it’s possible we need to look other places for yours. Also, it’s likely that there’s a temperature sensor in the unit itself (certainly for non-air-handler units. I’m sure we can get humidity working if you can give me a little more detail about what your setup looks like (assuming you /don’t/ have a wireless thermostat). If you set the logging of your binding to DEBUG or TRACE, you’ll get a bunch of output in the logs that shows the data from the unit. If you DM me with that (it’s potentially a lot of data), I might be able to figure out where to pull the info from.
log:set TRACE org.openhab.binding.mitsubishikumocloud
And yes, their software is pretty terrible. Send it a bad command, and it basically crashes and reboots, etc.
Thanks again for the feedback!
Bill
