This project seems cool. I just gave it a try and got null pointer exception because cryptoSerial
was not in the response. Perhaps my wifi devices are too old? I got them in 2016 and the model is: PAC-WHS01WF-E.
I’ve included the trace log for discovery in case you see anything. I’ve redacted any personal info.
14:01:46.380 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mitsubishikumocloud:account:f645cff6a5' changed from UNINITIALIZED (DISABLED) to INITIALIZING
14:01:46.381 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mitsubishikumocloud:account:f645cff6a5' changed from INITIALIZING to ONLINE
14:01:51.381 [DEBUG] [nal.MitsubishiKumoCloudAccountHandler] - updateData
14:01:51.382 [DEBUG] [nal.MitsubishiKumoCloudAccountHandler] - body: {"password":"***","appVersion":"2.2.0","username":"****"}
14:01:51.383 [DEBUG] [nal.MitsubishiKumoCloudAccountHandler] - request: HttpRequest[POST /login HTTP/1.1]@3563aa09
14:01:51.383 [TRACE] [nal.MitsubishiKumoCloudAccountHandler] - sendRequest: requesting https://geo-c.kumocloud.com/login
14:01:53.033 [TRACE] [nal.MitsubishiKumoCloudAccountHandler] - Response code 200
14:01:53.034 [TRACE] [nal.MitsubishiKumoCloudAccountHandler] - sendRequest: response [{"token":"***","username":"****","device":null,"emailIsVerified":true},{"lastUpdate":1466552482281},{"lastScheduleChange":0,"zoneTable":{},"children":[{"lastScheduleChange":0,"zoneTable":{"1508240242":{"serial":"***","lastUpdate":1720877390410,"label":"Base kumo","mac":"00:1d:c9:93:d2:9d","localAdapterStatus":"NORMAL","profileCodeFrames":["fc7b013010c9030020001407758c25a0be94bea0be09","fc7b013010cda0bea0bea0be18000000000000000045"],"optimalStart":false,"desiredConditionStack":[],"reportedCondition":{"more":{"operation_mode_text":"i-see Cool","fan_speed_text":"High","air_direction_text":"Auto","power_on":false},"_created":1720877390405,"status_display":{"filter":false,"defrost":false,"hot_adjust":false,"standby":false,"code":0},"unusual_figures":{"code":32768,"normal":true},"two_figures_code":{"normal":true,"text":"A0","code":0},"prohibit_local_remote_control":{"set_temp":false,"set_operation_mode":false,"set_power":false,"code":0},"set_temp":22,"operation_mode":11,"fan_speed":5,"room_temp":24.5,"air_direction":0,"power":0},"overrideSettings":{},"forceCloudUpdates":false,"address":"192.168.254.106","errorHandler":{"1":{"error2char":"A0","error4char":"8000","code":"8000","text":"8000"}},"rssi":{},"sendDesiredConditionsPending":false,"sendDesiredConditionsTime":"2024-05-29T21:10:46.082Z","equipmentControllerSettings":{},"hasElectricHeatingOption":false,"port":80,"systemChangeoverSettings":{"masterZone":{"minRuntime":20,"maxStandby":180,"activeMode":null,"durActive":null,"durInactive":null},"priority":1},"programEventSettings":{"1":null,"2":null,"3":null,"4":null,"5":null,"6":null,"7":null,"8":null,"9":null,"10":null,"11":null,"12":null,"13":null,"14":null,"15":null,"16":null,"17":null,"18":null,"19":null,"20":null,"21":null,"22":null,"23":null,"24":null,"25":null,"26":null,"27":null,"28":null},"$$hashKey":"object:345","eqcStageThreeBacksupChannels":{"1":0,"2":0,"3":0,"4":0},"eqcUpdatedLocally":{"1":false,"2":false,"3":false,"4":false},"ledDisabled":false,"mhk2Settings":{"auto":{"owner":"","status":"","heatSetpoint":null,"coolSetpoint":null},"connected":{"thermostat":false,"thermostatBattery":"","outdoorAir":false,"outdoorAirBattery":"","indoorAir":false,"indoorAirBattery":""},"dr":{"override":false,"event":""},"hold":{"adapter":{"cancelMHK2":false,"endTime":0},"mhk2":{"cancelAdapter":false,"endTime":0}},"info":{"model":"","serial":"","firmware":""},"schedule":{"owner":"","enabled":""},"status":{"outdoorTemp":0,"outdoorHumid":null,"indoorHumid":null}},"prohibits":{"global":{"power":false,"mode":false,"setpoint":false},"local":{"power":false,"mode":false,"setpoint":false},"effective":{"power":false,"mode":false,"setpoint":false}},"prohibitsChanged":0,"holdChanged":0,"timezone":null,"acoilSettings":{"isAcoil":false,"inputs":{"humidistat":false,"ervSwitch":false,"floatSwitchWet":false},"outputs":{"w1":false,"w2":false,"y":false,"g":false,"erv":false,"humidifer":false,"heartbeat":false},"humidifier":{"targetPcr":0,"source":null,"enable":false},"erv":{"mode":"classic"},"ytoo":{"fan":false,"humidifier":false,"erv":false},"cbp":0,"oat":0,"bpcr":"off","ebp":false,"fDelay":0},"autoDrySettings":{"isAutoDry":true,"enable":false,"targetHumid":0,"overcool":0,"offset":0,"active":false,"lastUpdated":1720877389979,"hasUpdated":false},"kumoSensorSettings":{"uuid":0,"humidity":0},"_requestRescan":0,"_isRespondingLocally":null},"1510300063":{"serial":"***","lastUpdate":1720877390410,"label":"First Kumo","mac":"00:1d:c9:97:9b:af","localAdapterStatus":"NORMAL","profileCodeFrames":["fc7b013010c9030020001407758c25a0be94bea0be09","fc7b013010cda0bea0bea0be0000000000000000005d"],"$$hashKey":"object:352","optimalStart":false,"desiredConditionStack":[],"reportedCondition":{"more":{"operation_mode_text":"Cool","fan_speed_text":"Auto","air_direction_text":"Swing","power_on":true},"_created":1720877392055,"status_display":{"filter":false,"defrost":false,"hot_adjust":false,"standby":false,"code":0},"unusual_figures":{"code":32768,"normal":true},"two_figures_code":{"normal":true,"text":"A0","code":0},"prohibit_local_remote_control":{"set_temp":false,"set_operation_mode":false,"set_power":false,"code":0},"set_temp":23,"operation_mode":3,"fan_speed":0,"room_temp":23,"air_direction":7,"power":1},"overrideSettings":{},"forceCloudUpdates":false,"address":"192.168.254.120","errorHandler":{"1":{"error2char":"A0","error4char":"8000","code":"8000","text":"8000"}},"rssi":{"rssi":"-63","string":"Strong","image":"images/signal-strong-ondark-50x50.svg"},"sendDesiredConditionsPending":false,"sendDesiredConditionsTime":"2024-07-10T19:09:33.265Z","equipmentControllerSettings":{},"hasElectricHeatingOption":false,"port":80,"systemChangeoverSettings":{"masterZone":{"minRuntime":20,"maxStandby":180,"activeMode":null,"durActive":null,"durInactive":null},"priority":1},"programEventSettings":{"1":null,"2":null,"3":null,"4":null,"5":null,"6":null,"7":null,"8":null,"9":null,"10":null,"11":null,"12":null,"13":null,"14":null,"15":null,"16":null,"17":null,"18":null,"19":null,"20":null,"21":null,"22":null,"23":null,"24":null,"25":null,"26":null,"27":null,"28":null},"eqcStageThreeBacksupChannels":{"1":0,"2":0,"3":0,"4":0},"eqcUpdatedLocally":{"1":false,"2":false,"3":false,"4":false},"ledDisabled":false,"mhk2Settings":{"auto":{"owner":"","status":"","heatSetpoint":null,"coolSetpoint":null},"connected":{"thermostat":false,"thermostatBattery":"","outdoorAir":false,"outdoorAirBattery":"","indoorAir":false,"indoorAirBattery":""},"dr":{"override":false,"event":""},"hold":{"adapter":{"cancelMHK2":false,"endTime":0},"mhk2":{"cancelAdapter":false,"endTime":0}},"info":{"model":"","serial":"","firmware":""},"schedule":{"owner":"","enabled":""},"status":{"outdoorTemp":0,"outdoorHumid":null,"indoorHumid":null}},"prohibits":{"global":{"power":false,"mode":false,"setpoint":false},"local":{"power":false,"mode":false,"setpoint":false},"effective":{"power":false,"mode":false,"setpoint":false}},"prohibitsChanged":0,"holdChanged":0,"timezone":null,"acoilSettings":{"isAcoil":false,"inputs":{"humidistat":false,"ervSwitch":false,"floatSwitchWet":false},"outputs":{"w1":false,"w2":false,"y":false,"g":false,"erv":false,"humidifer":false,"heartbeat":false},"humidifier":{"targetPcr":0,"source":null,"enable":false},"erv":{"mode":"classic"},"ytoo":{"fan":false,"humidifier":false,"erv":false},"cbp":0,"oat":0,"bpcr":"off","ebp":false,"fDelay":0},"autoDrySettings":{"isAutoDry":true,"enable":false,"targetHumid":0,"overcool":0,"offset":0,"active":false,"lastUpdated":1720877389980,"hasUpdated":false},"kumoSensorSettings":{"uuid":0,"humidity":0},"_requestRescan":0,"_isRespondingLocally":true},"1510300110":{"serial":"***","lastUpdate":1720877390410,"label":"2nd Kumo","mac":"00:1d:c9:97:92:86","localAdapterStatus":"NORMAL","profileCodeFrames":["fc7b013010c9030020001407750c05a0be94bea0bea9","fc7b013010cda0bea0bea0be0000000000000000005d"],"optimalStart":false,"desiredConditionStack":[],"reportedCondition":{"more":{"operation_mode_text":"Cool","fan_speed_text":"Auto","air_direction_text":"Position 2","power_on":true},"_created":1720877391225,"status_display":{"filter":false,"defrost":false,"hot_adjust":false,"standby":false,"code":0},"unusual_figures":{"code":32768,"normal":true},"two_figures_code":{"normal":true,"text":"A0","code":0},"prohibit_local_remote_control":{"set_temp":false,"set_operation_mode":false,"set_power":false,"code":0},"set_temp":22,"operation_mode":3,"fan_speed":0,"room_temp":22,"air_direction":2,"power":1},"overrideSettings":{},"forceCloudUpdates":false,"address":"192.168.254.52","errorHandler":{"1":{"error2char":"A0","error4char":"8000","code":"8000","text":"8000"}},"rssi":{"rssi":"-43","string":"Very strong","image":"images/signal-verystrong-ondark-50x50.svg"},"sendDesiredConditionsPending":false,"sendDesiredConditionsTime":"2024-07-07T23:03:37.062Z","equipmentControllerSettings":{},"hasElectricHeatingOption":false,"port":80,"systemChangeoverSettings":{"masterZone":{"minRuntime":20,"maxStandby":180,"activeMode":null,"durActive":null,"durInactive":null},"priority":1},"programEventSettings":{"1":null,"2":null,"3":null,"4":null,"5":null,"6":null,"7":null,"8":null,"9":null,"10":null,"11":null,"12":null,"13":null,"14":null,"15":null,"16":null,"17":null,"18":null,"19":null,"20":null,"21":null,"22":null,"23":null,"24":null,"25":null,"26":null,"27":null,"28":null},"$$hashKey":"object:344","eqcStageThreeBacksupChannels":{"1":0,"2":0,"3":0,"4":0},"eqcUpdatedLocally":{"1":false,"2":false,"3":false,"4":false},"ledDisabled":false,"mhk2Settings":{"auto":{"owner":"","status":"","heatSetpoint":null,"coolSetpoint":null},"connected":{"thermostat":false,"thermostatBattery":"","outdoorAir":false,"outdoorAirBattery":"","indoorAir":false,"indoorAirBattery":""},"dr":{"override":false,"event":""},"hold":{"adapter":{"cancelMHK2":false,"endTime":0},"mhk2":{"cancelAdapter":false,"endTime":0}},"info":{"model":"","serial":"","firmware":""},"schedule":{"owner":"","enabled":""},"status":{"outdoorTemp":0,"outdoorHumid":null,"indoorHumid":null}},"prohibits":{"global":{"power":false,"mode":false,"setpoint":false},"local":{"power":false,"mode":false,"setpoint":false},"effective":{"power":false,"mode":false,"setpoint":false}},"prohibitsChanged":0,"holdChanged":0,"timezone":null,"acoilSettings":{"isAcoil":false,"inputs":{"humidistat":false,"ervSwitch":false,"floatSwitchWet":false},"outputs":{"w1":false,"w2":false,"y":false,"g":false,"erv":false,"humidifer":false,"heartbeat":false},"humidifier":{"targetPcr":0,"source":null,"enable":false},"erv":{"mode":"classic"},"ytoo":{"fan":false,"humidifier":false,"erv":false},"cbp":0,"oat":0,"bpcr":"off","ebp":false,"fDelay":0},"autoDrySettings":{"isAutoDry":true,"enable":false,"targetHumid":0,"overcool":0,"offset":0,"active":false,"lastUpdated":1720877389980,"hasUpdated":false},"kumoSensorSettings":{"uuid":0,"humidity":0},"_requestRescan":0,"_isRespondingLocally":true}},"children":[],"id":"1466552482281-800995590","lastUpdate":1590848005010,"label":"Home","version":868,"$$hashKey":"object:47","level":2,"v1.2+":1}],"id":"1477158635949-3315234884","lastUpdate":1720980112291,"label":"kumo cloud","version":12341,"level":1,"v1.2+":1},"no device token",{"userDetails":{"firstName":"James","lastName":"James","phone":"***","email":"****","IsPersonAccount":true},"siteDetails":[]}]
14:01:53.035 [DEBUG] [nal.MitsubishiKumoCloudAccountHandler] - Json: [{"token":"***","username":"****","device":null,"emailIsVerified":true},{"lastUpdate":1466552482281},{"lastScheduleChange":0,"zoneTable":{},"children":[{"lastScheduleChange":0,"zoneTable":{"1508240242":{"serial":"***","lastUpdate":1720877390410,"label":"Base kumo","mac":"00:1d:c9:93:d2:9d","localAdapterStatus":"NORMAL","profileCodeFrames":["fc7b013010c9030020001407758c25a0be94bea0be09","fc7b013010cda0bea0bea0be18000000000000000045"],"optimalStart":false,"desiredConditionStack":[],"reportedCondition":{"more":{"operation_mode_text":"i-see Cool","fan_speed_text":"High","air_direction_text":"Auto","power_on":false},"_created":1720877390405,"status_display":{"filter":false,"defrost":false,"hot_adjust":false,"standby":false,"code":0},"unusual_figures":{"code":32768,"normal":true},"two_figures_code":{"normal":true,"text":"A0","code":0},"prohibit_local_remote_control":{"set_temp":false,"set_operation_mode":false,"set_power":false,"code":0},"set_temp":22,"operation_mode":11,"fan_speed":5,"room_temp":24.5,"air_direction":0,"power":0},"overrideSettings":{},"forceCloudUpdates":false,"address":"192.168.254.106","errorHandler":{"1":{"error2char":"A0","error4char":"8000","code":"8000","text":"8000"}},"rssi":{},"sendDesiredConditionsPending":false,"sendDesiredConditionsTime":"2024-05-29T21:10:46.082Z","equipmentControllerSettings":{},"hasElectricHeatingOption":false,"port":80,"systemChangeoverSettings":{"masterZone":{"minRuntime":20,"maxStandby":180,"activeMode":null,"durActive":null,"durInactive":null},"priority":1},"programEventSettings":{"1":null,"2":null,"3":null,"4":null,"5":null,"6":null,"7":null,"8":null,"9":null,"10":null,"11":null,"12":null,"13":null,"14":null,"15":null,"16":null,"17":null,"18":null,"19":null,"20":null,"21":null,"22":null,"23":null,"24":null,"25":null,"26":null,"27":null,"28":null},"$$hashKey":"object:345","eqcStageThreeBacksupChannels":{"1":0,"2":0,"3":0,"4":0},"eqcUpdatedLocally":{"1":false,"2":false,"3":false,"4":false},"ledDisabled":false,"mhk2Settings":{"auto":{"owner":"","status":"","heatSetpoint":null,"coolSetpoint":null},"connected":{"thermostat":false,"thermostatBattery":"","outdoorAir":false,"outdoorAirBattery":"","indoorAir":false,"indoorAirBattery":""},"dr":{"override":false,"event":""},"hold":{"adapter":{"cancelMHK2":false,"endTime":0},"mhk2":{"cancelAdapter":false,"endTime":0}},"info":{"model":"","serial":"","firmware":""},"schedule":{"owner":"","enabled":""},"status":{"outdoorTemp":0,"outdoorHumid":null,"indoorHumid":null}},"prohibits":{"global":{"power":false,"mode":false,"setpoint":false},"local":{"power":false,"mode":false,"setpoint":false},"effective":{"power":false,"mode":false,"setpoint":false}},"prohibitsChanged":0,"holdChanged":0,"timezone":null,"acoilSettings":{"isAcoil":false,"inputs":{"humidistat":false,"ervSwitch":false,"floatSwitchWet":false},"outputs":{"w1":false,"w2":false,"y":false,"g":false,"erv":false,"humidifer":false,"heartbeat":false},"humidifier":{"targetPcr":0,"source":null,"enable":false},"erv":{"mode":"classic"},"ytoo":{"fan":false,"humidifier":false,"erv":false},"cbp":0,"oat":0,"bpcr":"off","ebp":false,"fDelay":0},"autoDrySettings":{"isAutoDry":true,"enable":false,"targetHumid":0,"overcool":0,"offset":0,"active":false,"lastUpdated":1720877389979,"hasUpdated":false},"kumoSensorSettings":{"uuid":0,"humidity":0},"_requestRescan":0,"_isRespondingLocally":null},"1510300063":{"serial":"***","lastUpdate":1720877390410,"label":"First Kumo","mac":"00:1d:c9:97:9b:af","localAdapterStatus":"NORMAL","profileCodeFrames":["fc7b013010c9030020001407758c25a0be94bea0be09","fc7b013010cda0bea0bea0be0000000000000000005d"],"$$hashKey":"object:352","optimalStart":false,"desiredConditionStack":[],"reportedCondition":{"more":{"operation_mode_text":"Cool","fan_speed_text":"Auto","air_direction_text":"Swing","power_on":true},"_created":1720877392055,"status_display":{"filter":false,"defrost":false,"hot_adjust":false,"standby":false,"code":0},"unusual_figures":{"code":32768,"normal":true},"two_figures_code":{"normal":true,"text":"A0","code":0},"prohibit_local_remote_control":{"set_temp":false,"set_operation_mode":false,"set_power":false,"code":0},"set_temp":23,"operation_mode":3,"fan_speed":0,"room_temp":23,"air_direction":7,"power":1},"overrideSettings":{},"forceCloudUpdates":false,"address":"192.168.254.120","errorHandler":{"1":{"error2char":"A0","error4char":"8000","code":"8000","text":"8000"}},"rssi":{"rssi":"-63","string":"Strong","image":"images/signal-strong-ondark-50x50.svg"},"sendDesiredConditionsPending":false,"sendDesiredConditionsTime":"2024-07-10T19:09:33.265Z","equipmentControllerSettings":{},"hasElectricHeatingOption":false,"port":80,"systemChangeoverSettings":{"masterZone":{"minRuntime":20,"maxStandby":180,"activeMode":null,"durActive":null,"durInactive":null},"priority":1},"programEventSettings":{"1":null,"2":null,"3":null,"4":null,"5":null,"6":null,"7":null,"8":null,"9":null,"10":null,"11":null,"12":null,"13":null,"14":null,"15":null,"16":null,"17":null,"18":null,"19":null,"20":null,"21":null,"22":null,"23":null,"24":null,"25":null,"26":null,"27":null,"28":null},"eqcStageThreeBacksupChannels":{"1":0,"2":0,"3":0,"4":0},"eqcUpdatedLocally":{"1":false,"2":false,"3":false,"4":false},"ledDisabled":false,"mhk2Settings":{"auto":{"owner":"","status":"","heatSetpoint":null,"coolSetpoint":null},"connected":{"thermostat":false,"thermostatBattery":"","outdoorAir":false,"outdoorAirBattery":"","indoorAir":false,"indoorAirBattery":""},"dr":{"override":false,"event":""},"hold":{"adapter":{"cancelMHK2":false,"endTime":0},"mhk2":{"cancelAdapter":false,"endTime":0}},"info":{"model":"","serial":"","firmware":""},"schedule":{"owner":"","enabled":""},"status":{"outdoorTemp":0,"outdoorHumid":null,"indoorHumid":null}},"prohibits":{"global":{"power":false,"mode":false,"setpoint":false},"local":{"power":false,"mode":false,"setpoint":false},"effective":{"power":false,"mode":false,"setpoint":false}},"prohibitsChanged":0,"holdChanged":0,"timezone":null,"acoilSettings":{"isAcoil":false,"inputs":{"humidistat":false,"ervSwitch":false,"floatSwitchWet":false},"outputs":{"w1":false,"w2":false,"y":false,"g":false,"erv":false,"humidifer":false,"heartbeat":false},"humidifier":{"targetPcr":0,"source":null,"enable":false},"erv":{"mode":"classic"},"ytoo":{"fan":false,"humidifier":false,"erv":false},"cbp":0,"oat":0,"bpcr":"off","ebp":false,"fDelay":0},"autoDrySettings":{"isAutoDry":true,"enable":false,"targetHumid":0,"overcool":0,"offset":0,"active":false,"lastUpdated":1720877389980,"hasUpdated":false},"kumoSensorSettings":{"uuid":0,"humidity":0},"_requestRescan":0,"_isRespondingLocally":true},"1510300110":{"serial":"***","lastUpdate":1720877390410,"label":"2nd Kumo","mac":"00:1d:c9:97:92:86","localAdapterStatus":"NORMAL","profileCodeFrames":["fc7b013010c9030020001407750c05a0be94bea0bea9","fc7b013010cda0bea0bea0be0000000000000000005d"],"optimalStart":false,"desiredConditionStack":[],"reportedCondition":{"more":{"operation_mode_text":"Cool","fan_speed_text":"Auto","air_direction_text":"Position 2","power_on":true},"_created":1720877391225,"status_display":{"filter":false,"defrost":false,"hot_adjust":false,"standby":false,"code":0},"unusual_figures":{"code":32768,"normal":true},"two_figures_code":{"normal":true,"text":"A0","code":0},"prohibit_local_remote_control":{"set_temp":false,"set_operation_mode":false,"set_power":false,"code":0},"set_temp":22,"operation_mode":3,"fan_speed":0,"room_temp":22,"air_direction":2,"power":1},"overrideSettings":{},"forceCloudUpdates":false,"address":"192.168.254.52","errorHandler":{"1":{"error2char":"A0","error4char":"8000","code":"8000","text":"8000"}},"rssi":{"rssi":"-43","string":"Very strong","image":"images/signal-verystrong-ondark-50x50.svg"},"sendDesiredConditionsPending":false,"sendDesiredConditionsTime":"2024-07-07T23:03:37.062Z","equipmentControllerSettings":{},"hasElectricHeatingOption":false,"port":80,"systemChangeoverSettings":{"masterZone":{"minRuntime":20,"maxStandby":180,"activeMode":null,"durActive":null,"durInactive":null},"priority":1},"programEventSettings":{"1":null,"2":null,"3":null,"4":null,"5":null,"6":null,"7":null,"8":null,"9":null,"10":null,"11":null,"12":null,"13":null,"14":null,"15":null,"16":null,"17":null,"18":null,"19":null,"20":null,"21":null,"22":null,"23":null,"24":null,"25":null,"26":null,"27":null,"28":null},"$$hashKey":"object:344","eqcStageThreeBacksupChannels":{"1":0,"2":0,"3":0,"4":0},"eqcUpdatedLocally":{"1":false,"2":false,"3":false,"4":false},"ledDisabled":false,"mhk2Settings":{"auto":{"owner":"","status":"","heatSetpoint":null,"coolSetpoint":null},"connected":{"thermostat":false,"thermostatBattery":"","outdoorAir":false,"outdoorAirBattery":"","indoorAir":false,"indoorAirBattery":""},"dr":{"override":false,"event":""},"hold":{"adapter":{"cancelMHK2":false,"endTime":0},"mhk2":{"cancelAdapter":false,"endTime":0}},"info":{"model":"","serial":"","firmware":""},"schedule":{"owner":"","enabled":""},"status":{"outdoorTemp":0,"outdoorHumid":null,"indoorHumid":null}},"prohibits":{"global":{"power":false,"mode":false,"setpoint":false},"local":{"power":false,"mode":false,"setpoint":false},"effective":{"power":false,"mode":false,"setpoint":false}},"prohibitsChanged":0,"holdChanged":0,"timezone":null,"acoilSettings":{"isAcoil":false,"inputs":{"humidistat":false,"ervSwitch":false,"floatSwitchWet":false},"outputs":{"w1":false,"w2":false,"y":false,"g":false,"erv":false,"humidifer":false,"heartbeat":false},"humidifier":{"targetPcr":0,"source":null,"enable":false},"erv":{"mode":"classic"},"ytoo":{"fan":false,"humidifier":false,"erv":false},"cbp":0,"oat":0,"bpcr":"off","ebp":false,"fDelay":0},"autoDrySettings":{"isAutoDry":true,"enable":false,"targetHumid":0,"overcool":0,"offset":0,"active":false,"lastUpdated":1720877389980,"hasUpdated":false},"kumoSensorSettings":{"uuid":0,"humidity":0},"_requestRescan":0,"_isRespondingLocally":true}},"children":[],"id":"1466552482281-800995590","lastUpdate":1590848005010,"label":"Home","version":868,"$$hashKey":"object:47","level":2,"v1.2+":1}],"id":"1477158635949-3315234884","lastUpdate":1720980112291,"label":"kumo cloud","version":12341,"level":1,"v1.2+":1},"no device token",{"userDetails":{"firstName":"James","lastName":"James","phone":"****","email":"****","IsPersonAccount":true},"siteDetails":[]}]
14:01:53.037 [DEBUG] [nal.MitsubishiKumoCloudAccountHandler] - Serial: *** => {serial=***, lastUpdate=1.72087739041E12, label=Base kumo, mac=***, localAdapterStatus=NORMAL, profileCodeFrames=[fc7b013010c9030020001407758c25a0be94bea0be09, fc7b013010cda0bea0bea0be18000000000000000045], optimalStart=false, desiredConditionStack=[], reportedCondition={more={operation_mode_text=i-see Cool, fan_speed_text=High, air_direction_text=Auto, power_on=false}, _created=1.720877390405E12, status_display={filter=false, defrost=false, hot_adjust=false, standby=false, code=0.0}, unusual_figures={code=32768.0, normal=true}, two_figures_code={normal=true, text=A0, code=0.0}, prohibit_local_remote_control={set_temp=false, set_operation_mode=false, set_power=false, code=0.0}, set_temp=22.0, operation_mode=11.0, fan_speed=5.0, room_temp=24.5, air_direction=0.0, power=0.0}, overrideSettings={}, forceCloudUpdates=false, address=***, errorHandler={1={error2char=A0, error4char=8000, code=8000, text=8000}}, rssi={}, sendDesiredConditionsPending=false, sendDesiredConditionsTime=2024-05-29T21:10:46.082Z, equipmentControllerSettings={}, hasElectricHeatingOption=false, port=80.0, systemChangeoverSettings={masterZone={minRuntime=20.0, maxStandby=180.0, activeMode=null, durActive=null, durInactive=null}, priority=1.0}, programEventSettings={1=null, 2=null, 3=null, 4=null, 5=null, 6=null, 7=null, 8=null, 9=null, 10=null, 11=null, 12=null, 13=null, 14=null, 15=null, 16=null, 17=null, 18=null, 19=null, 20=null, 21=null, 22=null, 23=null, 24=null, 25=null, 26=null, 27=null, 28=null}, $$hashKey=object:345, eqcStageThreeBacksupChannels={1=0.0, 2=0.0, 3=0.0, 4=0.0}, eqcUpdatedLocally={1=false, 2=false, 3=false, 4=false}, ledDisabled=false, mhk2Settings={auto={owner=, status=, heatSetpoint=null, coolSetpoint=null}, connected={thermostat=false, thermostatBattery=, outdoorAir=false, outdoorAirBattery=, indoorAir=false, indoorAirBattery=}, dr={override=false, event=}, hold={adapter={cancelMHK2=false, endTime=0.0}, mhk2={cancelAdapter=false, endTime=0.0}}, info={model=, serial=, firmware=}, schedule={owner=, enabled=}, status={outdoorTemp=0.0, outdoorHumid=null, indoorHumid=null}}, prohibits={global={power=false, mode=false, setpoint=false}, local={power=false, mode=false, setpoint=false}, effective={power=false, mode=false, setpoint=false}}, prohibitsChanged=0.0, holdChanged=0.0, timezone=null, acoilSettings={isAcoil=false, inputs={humidistat=false, ervSwitch=false, floatSwitchWet=false}, outputs={w1=false, w2=false, y=false, g=false, erv=false, humidifer=false, heartbeat=false}, humidifier={targetPcr=0.0, source=null, enable=false}, erv={mode=classic}, ytoo={fan=false, humidifier=false, erv=false}, cbp=0.0, oat=0.0, bpcr=off, ebp=false, fDelay=0.0}, autoDrySettings={isAutoDry=true, enable=false, targetHumid=0.0, overcool=0.0, offset=0.0, active=false, lastUpdated=1.720877389979E12, hasUpdated=false}, kumoSensorSettings={uuid=0.0, humidity=0.0}, _requestRescan=0.0, _isRespondingLocally=null}
14:01:53.038 [TRACE] [l.MitsubishiKumoCloudDiscoveryService] - Got discovered device.
14:01:53.038 [DEBUG] [l.MitsubishiKumoCloudDiscoveryService] - reported Profile: null
14:01:53.038 [WARN ] [ommon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
java.lang.NullPointerException: The validated object is null
at java.util.Objects.requireNonNull(Objects.java:336) ~[?:?]
at org.apache.commons.lang3.Validate.notNull(Validate.java:1037) ~[?:?]
at org.apache.commons.lang3.Validate.notNull(Validate.java:1019) ~[?:?]
at org.openhab.binding.mitsubishikumocloud.internal.MitsubishiKumoCloudDiscoveryService.unitDiscovered(MitsubishiKumoCloudDiscoveryService.java:67) ~[?:?]
at org.openhab.binding.mitsubishikumocloud.internal.MitsubishiKumoCloudAccountHandler.updateData(MitsubishiKumoCloudAccountHandler.java:223) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) ~[?:?]
