Hope you can help, cant seem to see a similar issue as most can’t see the image.
I’m using a Frame (have tried image too) and can get my MPJG feed showing. However it doesn’t scale so has scroll bars each side, I’d like it to autosize to the frame/image.
The output is coming from Blue Iris which does the convert into MJPG feed so I haven’t added as an item or using any different bindings (don’t think I should?)
