MobileEyeDoor+
I have a video intercom installed which works with MobileEyeDoor+. I would like to control the intercom via OpenHAB. Unfortunately, I have no idea what protocol the application uses. Does anyone know which binding would work with MobileEyeDoor+ devices?
Thank you
I could find nothing mentioning an API available for this device so you will need to do some research to see if I just missed it or reverse engineer the API. With any luck the HTTP binding would work but you will have to figure out the right API calls to make.
