Well that explains alot… I also have one of these, a raspberry pi 3b and a couple of ESP32 boards lying around… what route should I try next in your minds?
You could use the TCP232-304 - if you can come up with a means to drive it as a virtual/remote serial port.
On a Windows host for example, you’d install the USR supplied VCOM software that allows the TCP232-304 to appear as a COM port.
openHAB binding would then use the COM port with Modbus-RTU as though it were an onboard port.
I have no idea how you do that in *nix.
I’d advise getting a gateway with Modbus support, like the TCP232-410. I use these and they work a treat.
The USB RS485 adaptor will work, but of course you’ll need to run a cable - use Cat5 up to a kilometre long.
Could you provide you configuration and modbus binding and also items and sitemap?
For my HF221 (Modbus RTU to WiFi), I have the following configuration for Modbus TCP and WAN configuration. I.e. static IP and port 8234.
My Modbus bridge is created in PaperUI, pointing to the static IP / port 8234 of the adapter:
My Modbus Poller things and Modbus Data things are also created in PaperUI based on Modbus addresses for my Villavent VSR 500. Then I have linked Items using Visual Studio Code. An example of a Poller thing and Data thing is shown below:
I do not use Sitemap, only HabPanel, where setup is created in graphical view.
Superb, but you did write code in items?
My Modbus items:
Number ActiveUserMode "Active User Mode [MAP(activeusermode.map):%s]" {channel="modbus:data:userMode:number"}
Number ChangeUserMode "Change User Mode" {channel="modbus:data:changeUserMode:number"}
Number SupplyFanWrite "SAF Fan Control [MAP(airflowsupply.map):%s]" {channel="modbus:data:safControlRPM:number", autoupdate="false"}
Number ExhaustFanWrite "EAF Fan Control [MAP(airflowexhaust.map):%s]" {channel="modbus:data:eafControlRPM:number", autoupdate="false"}
Number SupplyFanRead "SAF Fan Speed (read) [%s RPM]" <fan> {channel="modbus:data:safRPM:number"}
Number ExhaustFanRead "EAF Fan Speed (read) [%s RPM]" <fan> {channel="modbus:data:eafRPM:number"}
Number TemperatureSetpoint "Temperature Setpoint [%.1f °C]" {channel="modbus:data:temperatureSetpoint:number", autoupdate="false"}
Number OutdoorTemperature "Outdoor Temperature [%.1f °C]" {channel="modbus:data:outdoorTemperature:number"}
Number SupplyAirTemperature "Supply Temperature [%.1f °C]" {channel="modbus:data:supplyairTemperature:number"}
Number OverHeatTemperature "Over Heat Temperature [%.1f °C]" {channel="modbus:data:overheatTemperature:number"}
Number RelativeHumidity "Relative Humidity [%s %%]" <humidity> {channel="modbus:data:relativeHumidity:number"}
Number ExhaustAirTemperature "Exhaust Temperature [%.1f °C]" {channel="modbus:data:exhaustairTemperature:number"}
Switch HeaterDigitalState "Heater State [%s]" <switch> {channel="modbus:data:exchangerDigitalState:number"}
Number HeaterAnalogueState "Heater State" {channel="modbus:data:exchangerAnalogueState:number", autoupdate="false"}
Switch ExchangerDigitalState "Exchanger State [%s]" <switch> {channel="modbus:data:heaterDigitalState:switch"}
Number ExchangerAnalogueState "Exchanger State" {channel="modbus:data:heaterAnalogueState:number", autoupdate="false"}
Switch PressureGuardSwitch "Pressureguard State [%s]" <switch> {channel="modbus:data:pressureSwitch:switch"}
Anyone up for making a Systemair Internet Access Module (IAM) binding?
Or is there another way of using the IAM module to openhab (via cloud or direct to IAM)
Systemair IAM enables two setup options: Either as internet access module, enabling use of the Systemair app, alternatively as Modbus TCP, enabling use of the Modbus binding / openHAB. You can not achieve both using only IAM (as I am aware of).
For me, having the Villavent SAVE VSR 500 ventilation system I have the IAM module set up with internet access, enabling use of the app. I have also purchased a cheap Modbus RTU to wifi converter: HF2211, which I use against the Modbus binding (see “mini-guide” how to set up Modbus using converter: Link). This setup is working perfect for me, enabling both options, and the Modbus binding is working flawlessly retrieving updates/enabling sending commands to my ventilation system using OH - Based on Modbus register as provided by Systemair: Link
Hello, i bougt The HF221
I did not connect any ground, since all i could find was connections A-A and B-B
But struggeling with an error
Error with read: org.openhab.io.transport.modbus.internal.ModbusSlaveIOExceptionImpl: Modbus IO Error with cause=ModbusIOException, EOF=false, message='I/O exception
Same connection as me then.
And you have managed to connect your HF221 to your wifi network? And have configured your HF221 as described under Post 144? I have also set up the following under “Serial Port Settings”:
For me, after having configured the HF221, installing the Modbus binding from PaperUI, my Modbus bridge was created using PaperUI and connected instantly.
Yes thank you foryour reply, it is first time with modbus configuration. I till get this IO error, i maybe seem to be missing simething (the first tcp slave is online but the rest i cant figure out…
Is there anything I need to do on the HMI screen?
Teamwiever?
Norsk by the way
YES! i got it working, changed baudrate in hmi and set to id 2, also powercycled the systemair system.
After changing the settings.
I’m looking into getting a IAM module for my VSR300 with CD control panel does that work or do I have to have the SAVE-touch control panel as well?
Also are you able to update the Systemair firmware without their IAM or Z-wave gateway?
Edit: Apparently the IAM module doesn’t work on the older units that comes with the CD control panel.
Hi, anyone knows whether it is possible to read builtin RH sensor values from the VTR300B? Mine is an older one with a CD panel, RH values are displayed through “analog input 6”, however I cannot find a modbus register that returns this information.
