I need to know if it is possible to read a coil in a slave and write another one in another slave in the same switch?
I explain my problem, my API (wago 750-841) have mirror address for read and write.
ex : 4196 is for write the coil and 8192 is the mirror for read this one.
With modbus binding i can read contiguous coils but my api is addressed by 4192 difference.
How can I resolve this issue?
(sorry for my english i’am french and school is not english focuses here )
Thx for your reply,
I see that you have basement, basement_ponet, so how did you configure your Switch item to read basement and to write basement_ponet?
It is for light, if I use 2 items the command switch will be always OFF even if the light is ON.
So to switch OFF the light I need to switch ON the item, it is not really visual.
Do you think that the devollopper of the binding can add this functionnality?
