What is the max value that modbus works with? I am using PoKeys 55 and the external bus values are 2071 - 2079. The config checks out:
2016-05-21 11:10:21 DEBUG o.o.b.m.i.ModbusActivator[:30]- Modbus binding has been started.
2016-05-21 11:10:21 DEBUG o.o.b.m.internal.ModbusBinding[:290]- modbusSlave 'basement' instanciated
2016-05-21 11:10:21 DEBUG o.o.b.m.internal.ModbusBinding[:290]- modbusSlave 'first' instanciated
2016-05-21 11:10:21 DEBUG o.o.b.m.internal.ModbusBinding[:290]- modbusSlave 'second' instanciated
2016-05-21 11:10:21 DEBUG o.o.b.m.internal.ModbusBinding[:290]- modbusSlave 'shed' instanciated
2016-05-21 11:10:21 DEBUG o.o.b.m.internal.ModbusBinding[:290]- modbusSlave 'water' instanciated
2016-05-21 11:10:21 DEBUG o.o.b.m.internal.ModbusBinding[:352]- config looked good, proceeding with slave-connections
Tho I am seeing errors:
java.net.SocketTimeoutException: Read timed out
at java.net.SocketInputStream.socketRead0(Native Method)
at java.net.SocketInputStream.socketRead(SocketInputStream.java:116)
at java.net.SocketInputStream.read(SocketInputStream.java:170)
at java.net.SocketInputStream.read(SocketInputStream.java:141)
at java.io.BufferedInputStream.fill(BufferedInputStream.java:246)
at java.io.BufferedInputStream.read1(BufferedInputStream.java:286)
at java.io.BufferedInputStream.read(BufferedInputStream.java:345)
at java.io.DataInputStream.read(DataInputStream.java:149)
at net.wimpi.modbus.io.ModbusTCPTransport.readResponse(ModbusTCPTransport.java:187)
at net.wimpi.modbus.io.ModbusTCPTransaction.execute(ModbusTCPTransaction.java:198)
at org.openhab.binding.modbus.internal.ModbusSlave.getModbusData(ModbusSlave.java:340)
at org.openhab.binding.modbus.internal.ModbusSlave.update(ModbusSlave.java:282)
at org.openhab.binding.modbus.internal.ModbusBinding.execute(ModbusBinding.java:233)
at org.openhab.core.binding.AbstractActiveBinding$BindingActiveService.execute(AbstractActiveBinding.java:156)
at org.openhab.core.service.AbstractActiveService$RefreshThread.run(AbstractActiveService.java:173)
However if I change openhab.conf modbus:tcp.basement.length=2079 to say 55 it works fine on the first 55 pins.
