openHAB Modbus binding supports Modbus-TCP. It neither knows nor cares what medium you use to transport TCP.
I was primarily asking to run openhab with Wifi enabled on Raspberry pi instead of Ethernet.
So when I installed openhabian , one of the steps mentioned was to use ethernet . But post successful installation , can i run openhab using Wifi Access Point or etherent is required to run openhab on Rasberry Pi
Maybe this helps
Top tip; provide a little feedback when getting extended free advice, has any of it addressed your questions? Don’t be a black hole. Something as simple as “that worked” is really quite helpful for other people in the same situation as you, who might use search features to help themselves, and end up reading this post.
@Mohit_Sharma
And please use code fense. It´s almost impossible to read manual text configuration files (like thing file) wihtout code fense.
