Hi @ssalonen
Second half
2018-11-03 14:40:52.664 [TRACE] [rt.modbus.internal.ModbusManagerImpl] - Try 1 out of 3 [operation ID 906d497c-0d49-4db6-988c-7221d2341aaa]
2018-11-03 14:40:52.670 [TRACE] [rt.modbus.internal.ModbusManagerImpl] - Ensuring that enough time passes before retrying again. Sleeping if necessary [operation ID 906d497c-0d49-4db6-988c-7221d2341aaa]
2018-11-03 14:40:52.674 [TRACE] [rt.modbus.internal.ModbusManagerImpl] - Sleep ended, slept 0 [operation ID 906d497c-0d49-4db6-988c-7221d2341aaa]
2018-11-03 14:40:52.687 [TRACE] [rt.modbus.internal.ModbusManagerImpl] - Going execute transaction with request request (FC=READ_MULTIPLE_REGISTERS): 00 00 00 00 00 06 01 03 00 0a 00 0d [operation ID 906d497c-0d49-4db6-988c-7221d2341aaa]
2018-11-03 14:40:52.691 [TRACE] [wimpi.modbus.io.ModbusTCPTransaction] - Sending request with transaction ID 36234: net.wimpi.modbus.msg.ReadMultipleRegistersRequest@720cb9
2018-11-03 14:40:52.719 [TRACE] [wimpi.modbus.io.ModbusTCPTransaction] - Received response with transaction ID 36234
2018-11-03 14:40:52.723 [TRACE] [rt.modbus.internal.ModbusManagerImpl] - Response for read request (FC=3, transaction ID=36234): 8d 8a 00 00 00 1d 01 03 1a 00 01 00 01 00 d2 00 be 00 00 08 20 00 00 00 03 00 00 00 50 00 e9 00 50 01 0a [operation ID 906d497c-0d49-4db6-988c-7221d2341aaa]
2018-11-03 14:40:52.727 [TRACE] [ing.ModbusSlaveConnectionFactoryImpl] - Validating endpoint ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502] connection TCPMasterConnection@d9316c[socket=Socket[addr=/192.168.1.122,port=502,localport=49172]] -> true
2018-11-03 14:40:52.727 [TRACE] [modbus.internal.ModbusLibraryWrapper] - Calling read response callback org.openhab.binding.modbus.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@92278363 for request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@106f07f[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=10,length=13,maxTries=3]. Response was net.wimpi.modbus.msg.ReadMultipleRegistersResponse@83e17a
2018-11-03 14:40:52.730 [DEBUG] [handler.ModbusPollerThingHandlerImpl] - Thing modbus:poller:0578379b received registers RegisterArrayWrappingInputRegister(00 01 00 01 00 d2 00 be 00 00 08 20 00 00 00 03 00 00 00 50 00 e9 00 50 01 0a) for request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@106f07f[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=10,length=13,maxTries=3]
2018-11-03 14:40:52.731 [TRACE] [ing.ModbusSlaveConnectionFactoryImpl] - Passivating connection TCPMasterConnection@d9316c[socket=Socket[addr=/192.168.1.122,port=502,localport=49172]] for endpoint ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502]...
2018-11-03 14:40:52.740 [TRACE] [ing.ModbusSlaveConnectionFactoryImpl] - (passivate) Connection TCPMasterConnection@d9316c[socket=Socket[addr=/192.168.1.122,port=502,localport=49172]] (endpoint ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502]) age (904ms) is below the reconnectAfterMillis (120000ms) limit and connection time (1541252451835) is after the "disconnectBeforeConnectedMillis"=-1. Keep the connection open.
2018-11-03 14:40:52.746 [TRACE] [ing.ModbusSlaveConnectionFactoryImpl] - ...Passivated connection TCPMasterConnection@d9316c[socket=Socket[addr=/192.168.1.122,port=502,localport=49172]] for endpoint ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502]
2018-11-03 14:40:52.749 [TRACE] [rt.modbus.internal.ModbusManagerImpl] - returned connection to pool for endpoint ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502]
2018-11-03 14:40:52.752 [TRACE] [rt.modbus.internal.ModbusManagerImpl] - Connection was returned to the pool, ending operation [operation ID 906d497c-0d49-4db6-988c-7221d2341aaa]
2018-11-03 14:40:52.755 [DEBUG] [rt.modbus.internal.ModbusManagerImpl] - Execution of scheduled (60000ms) poll task BasicPollTaskImpl@5b40c0[request=ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@106f07f[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=10,length=13,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502],callback=org.openhab.binding.modbus.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@92278363] finished at 1541252452755. Was started at millis: 1541252452370 (=duration of 385 millis)
2018-11-03 14:40:52.796 [TRACE] [odbus.handler.ModbusDataThingHandler] - Channel modbus:data:e23bcc66:number will be updated to '23.3' (type DecimalType). Input data: number value 233 (value type 'int16' taken into account) and bool value true. Transformation: Transformation@754424[tranformation=JS(div10.js),transformationServiceName=JS,transformationServiceParam=div10.js]
2018-11-03 14:40:52.805 [DEBUG] [odbus.handler.ModbusDataThingHandler] - Thing modbus:data:e23bcc66 channels updated: {modbus:data:e23bcc66:number=23.3, modbus:data:e23bcc66:lastReadSuccess=2018-11-03T14:40:52.799+0100}. readValueType=int16, readIndex=Optional[20], readSubIndex(or 0)=0, extractIndex=10 -> numeric value 233 and boolValue=true. Registers RegisterArrayWrappingInputRegister(00 01 00 01 00 d2 00 be 00 00 08 20 00 00 00 03 00 00 00 50 00 e9 00 50 01 0a) for request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@106f07f[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=10,length=13,maxTries=3]
2018-11-03 14:40:52.807 [TRACE] [modbus.internal.ModbusLibraryWrapper] - Called read response callback org.openhab.binding.modbus.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@92278363 for request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@106f07f[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=10,length=13,maxTries=3]. Response was net.wimpi.modbus.msg.ReadMultipleRegistersResponse@83e17a
2018-11-03 14:40:52.989 [TRACE] [ing.ModbusSlaveConnectionFactoryImpl] - Waited 240ms (interTransactionDelayMillis 250ms) before giving returning connection TCPMasterConnection@d9316c[socket=Socket[addr=/192.168.1.122,port=502,localport=49172]] for endpoint ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502], to ensure delay between transactions.
2018-11-03 14:40:52.992 [TRACE] [rt.modbus.internal.ModbusManagerImpl] - borrowing connection (got Optional[TCPMasterConnection@d9316c[socket=Socket[addr=/192.168.1.122,port=502,localport=49172]]]) for endpoint ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502] took 332 ms
2018-11-03 14:40:52.994 [TRACE] [rt.modbus.internal.ModbusManagerImpl] - Executing task BasicPollTaskImpl@1cada4b[request=ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@10781ae[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=2,length=1,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502],callback=org.openhab.binding.modbus.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@bebc532a] (oneOff=false)! Connection received in 334 ms [operation ID 920fc504-a181-4082-8d74-6341e0fdeaf9]
2018-11-03 14:40:52.996 [TRACE] [rt.modbus.internal.ModbusManagerImpl] - Operation with task BasicPollTaskImpl@1cada4b[request=ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@10781ae[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=2,length=1,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502],callback=org.openhab.binding.modbus.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@bebc532a]. Got a connection successfully [operation ID 920fc504-a181-4082-8d74-6341e0fdeaf9]
2018-11-03 14:40:52.998 [TRACE] [rt.modbus.internal.ModbusManagerImpl] - Try 1 out of 3 [operation ID 920fc504-a181-4082-8d74-6341e0fdeaf9]
2018-11-03 14:40:53.000 [TRACE] [rt.modbus.internal.ModbusManagerImpl] - Ensuring that enough time passes before retrying again. Sleeping if necessary [operation ID 920fc504-a181-4082-8d74-6341e0fdeaf9]
2018-11-03 14:40:53.001 [TRACE] [rt.modbus.internal.ModbusManagerImpl] - Sleep ended, slept 0 [operation ID 920fc504-a181-4082-8d74-6341e0fdeaf9]
2018-11-03 14:40:53.003 [TRACE] [rt.modbus.internal.ModbusManagerImpl] - Going execute transaction with request request (FC=READ_MULTIPLE_REGISTERS): 00 00 00 00 00 06 01 03 00 02 00 01 [operation ID 920fc504-a181-4082-8d74-6341e0fdeaf9]
2018-11-03 14:40:53.005 [TRACE] [wimpi.modbus.io.ModbusTCPTransaction] - Sending request with transaction ID 36235: net.wimpi.modbus.msg.ReadMultipleRegistersRequest@306f88
2018-11-03 14:40:53.008 [TRACE] [wimpi.modbus.io.ModbusTCPTransaction] - Received response with transaction ID 36235
2018-11-03 14:40:53.010 [TRACE] [rt.modbus.internal.ModbusManagerImpl] - Response for read request (FC=3, transaction ID=36235): 8d 8b 00 00 00 05 01 03 02 00 68 [operation ID 920fc504-a181-4082-8d74-6341e0fdeaf9]
2018-11-03 14:40:53.012 [TRACE] [modbus.internal.ModbusLibraryWrapper] - Calling read response callback org.openhab.binding.modbus.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@bebc532a for request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@10781ae[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=2,length=1,maxTries=3]. Response was net.wimpi.modbus.msg.ReadMultipleRegistersResponse@64a27d
2018-11-03 14:40:53.012 [TRACE] [ing.ModbusSlaveConnectionFactoryImpl] - Validating endpoint ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502] connection TCPMasterConnection@d9316c[socket=Socket[addr=/192.168.1.122,port=502,localport=49172]] -> true
2018-11-03 14:40:53.014 [TRACE] [ing.ModbusSlaveConnectionFactoryImpl] - Passivating connection TCPMasterConnection@d9316c[socket=Socket[addr=/192.168.1.122,port=502,localport=49172]] for endpoint ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502]...
2018-11-03 14:40:53.015 [DEBUG] [handler.ModbusPollerThingHandlerImpl] - Thing modbus:poller:b3d11690 received registers RegisterArrayWrappingInputRegister(00 68) for request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@10781ae[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=2,length=1,maxTries=3]
2018-11-03 14:40:53.017 [TRACE] [ing.ModbusSlaveConnectionFactoryImpl] - (passivate) Connection TCPMasterConnection@d9316c[socket=Socket[addr=/192.168.1.122,port=502,localport=49172]] (endpoint ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502]) age (1181ms) is below the reconnectAfterMillis (120000ms) limit and connection time (1541252451835) is after the "disconnectBeforeConnectedMillis"=-1. Keep the connection open.
2018-11-03 14:40:53.019 [TRACE] [ing.ModbusSlaveConnectionFactoryImpl] - ...Passivated connection TCPMasterConnection@d9316c[socket=Socket[addr=/192.168.1.122,port=502,localport=49172]] for endpoint ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502]
2018-11-03 14:40:53.021 [TRACE] [rt.modbus.internal.ModbusManagerImpl] - returned connection to pool for endpoint ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502]
2018-11-03 14:40:53.023 [TRACE] [rt.modbus.internal.ModbusManagerImpl] - Connection was returned to the pool, ending operation [operation ID 920fc504-a181-4082-8d74-6341e0fdeaf9]
2018-11-03 14:40:53.026 [DEBUG] [rt.modbus.internal.ModbusManagerImpl] - Execution of scheduled (60000ms) poll task BasicPollTaskImpl@1cada4b[request=ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@10781ae[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=2,length=1,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502],callback=org.openhab.binding.modbus.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@bebc532a] finished at 1541252453025. Was started at millis: 1541252452647 (=duration of 378 millis)
2018-11-03 14:40:53.072 [TRACE] [odbus.handler.ModbusDataThingHandler] - Channel modbus:data:29bec5c5:number will be updated to '10.4' (type DecimalType). Input data: number value 104 (value type 'int16' taken into account) and bool value true. Transformation: Transformation@991be[tranformation=JS(div10.js),transformationServiceName=JS,transformationServiceParam=div10.js]
2018-11-03 14:40:53.081 [DEBUG] [odbus.handler.ModbusDataThingHandler] - Thing modbus:data:29bec5c5 channels updated: {modbus:data:29bec5c5:number=10.4, modbus:data:29bec5c5:lastReadSuccess=2018-11-03T14:40:53.075+0100}. readValueType=int16, readIndex=Optional[2], readSubIndex(or 0)=0, extractIndex=0 -> numeric value 104 and boolValue=true. Registers RegisterArrayWrappingInputRegister(00 68) for request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@10781ae[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=2,length=1,maxTries=3]
2018-11-03 14:40:53.083 [TRACE] [modbus.internal.ModbusLibraryWrapper] - Called read response callback org.openhab.binding.modbus.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@bebc532a for request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@10781ae[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=2,length=1,maxTries=3]. Response was net.wimpi.modbus.msg.ReadMultipleRegistersResponse@64a27d
2018-11-03 14:40:57.464 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - <POLL MONITOR>
2018-11-03 14:40:57.467 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - POLL MONITOR: scheduled poll task. FC: READ_MULTIPLE_REGISTERS, start 50, length 13, done: false, canceled: false, delay: 54960. Full task BasicPollTaskImpl@179c1b7[request=ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@18bdaa9[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=50,length=13,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502],callback=org.openhab.binding.modbus.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@c430e140]
2018-11-03 14:40:57.471 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - POLL MONITOR: scheduled poll task. FC: READ_MULTIPLE_REGISTERS, start 75, length 7, done: false, canceled: false, delay: 54661. Full task BasicPollTaskImpl@1925010[request=ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@1cb38e8[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=75,length=7,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502],callback=org.openhab.binding.modbus.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@58335add]
2018-11-03 14:40:57.475 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - POLL MONITOR: scheduled poll task. FC: READ_MULTIPLE_REGISTERS, start 10, length 13, done: false, canceled: false, delay: 55284. Full task BasicPollTaskImpl@5b40c0[request=ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@106f07f[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=10,length=13,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502],callback=org.openhab.binding.modbus.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@92278363]
2018-11-03 14:40:57.478 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - POLL MONITOR: scheduled poll task. FC: READ_MULTIPLE_REGISTERS, start 2, length 1, done: false, canceled: false, delay: 55549. Full task BasicPollTaskImpl@1cada4b[request=ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@10781ae[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=2,length=1,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502],callback=org.openhab.binding.modbus.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@bebc532a]
2018-11-03 14:40:57.481 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - POLL MONITOR: callbackThreadPool queue size: 0, remaining space 2147483647. Active threads 0
2018-11-03 14:40:57.484 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - </POLL MONITOR>
2018-11-03 14:41:07.487 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - <POLL MONITOR>
2018-11-03 14:41:07.496 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - POLL MONITOR: scheduled poll task. FC: READ_MULTIPLE_REGISTERS, start 50, length 13, done: false, canceled: false, delay: 44930. Full task BasicPollTaskImpl@179c1b7[request=ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@18bdaa9[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=50,length=13,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502],callback=org.openhab.binding.modbus.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@c430e140]
2018-11-03 14:41:07.500 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - POLL MONITOR: scheduled poll task. FC: READ_MULTIPLE_REGISTERS, start 75, length 7, done: false, canceled: false, delay: 44632. Full task BasicPollTaskImpl@1925010[request=ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@1cb38e8[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=75,length=7,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502],callback=org.openhab.binding.modbus.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@58335add]
2018-11-03 14:41:07.503 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - POLL MONITOR: scheduled poll task. FC: READ_MULTIPLE_REGISTERS, start 10, length 13, done: false, canceled: false, delay: 45256. Full task BasicPollTaskImpl@5b40c0[request=ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@106f07f[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=10,length=13,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502],callback=org.openhab.binding.modbus.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@92278363]
2018-11-03 14:41:07.507 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - POLL MONITOR: scheduled poll task. FC: READ_MULTIPLE_REGISTERS, start 2, length 1, done: false, canceled: false, delay: 45521. Full task BasicPollTaskImpl@1cada4b[request=ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@10781ae[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=2,length=1,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502],callback=org.openhab.binding.modbus.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@bebc532a]
2018-11-03 14:41:07.509 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - POLL MONITOR: callbackThreadPool queue size: 0, remaining space 2147483647. Active threads 0
2018-11-03 14:41:07.512 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - </POLL MONITOR>
2018-11-03 14:41:17.514 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - <POLL MONITOR>
2018-11-03 14:41:17.518 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - POLL MONITOR: scheduled poll task. FC: READ_MULTIPLE_REGISTERS, start 50, length 13, done: false, canceled: false, delay: 34909. Full task BasicPollTaskImpl@179c1b7[request=ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@18bdaa9[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=50,length=13,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502],callback=org.openhab.binding.modbus.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@c430e140]
2018-11-03 14:41:17.522 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - POLL MONITOR: scheduled poll task. FC: READ_MULTIPLE_REGISTERS, start 75, length 7, done: false, canceled: false, delay: 34610. Full task BasicPollTaskImpl@1925010[request=ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@1cb38e8[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=75,length=7,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502],callback=org.openhab.binding.modbus.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@58335add]
2018-11-03 14:41:17.525 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - POLL MONITOR: scheduled poll task. FC: READ_MULTIPLE_REGISTERS, start 10, length 13, done: false, canceled: false, delay: 35234. Full task BasicPollTaskImpl@5b40c0[request=ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@106f07f[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=10,length=13,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502],callback=org.openhab.binding.modbus.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@92278363]
2018-11-03 14:41:17.529 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - POLL MONITOR: scheduled poll task. FC: READ_MULTIPLE_REGISTERS, start 2, length 1, done: false, canceled: false, delay: 35499. Full task BasicPollTaskImpl@1cada4b[request=ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@10781ae[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=2,length=1,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502],callback=org.openhab.binding.modbus.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@bebc532a]
2018-11-03 14:41:17.531 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - POLL MONITOR: callbackThreadPool queue size: 0, remaining space 2147483647. Active threads 0
2018-11-03 14:41:17.534 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - </POLL MONITOR>
2018-11-03 14:41:27.537 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - <POLL MONITOR>
2018-11-03 14:41:27.540 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - POLL MONITOR: scheduled poll task. FC: READ_MULTIPLE_REGISTERS, start 50, length 13, done: false, canceled: false, delay: 24887. Full task BasicPollTaskImpl@179c1b7[request=ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@18bdaa9[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=50,length=13,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502],callback=org.openhab.binding.modbus.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@c430e140]
2018-11-03 14:41:27.544 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - POLL MONITOR: scheduled poll task. FC: READ_MULTIPLE_REGISTERS, start 75, length 7, done: false, canceled: false, delay: 24588. Full task BasicPollTaskImpl@1925010[request=ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@1cb38e8[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=75,length=7,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502],callback=org.openhab.binding.modbus.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@58335add]
2018-11-03 14:41:27.547 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - POLL MONITOR: scheduled poll task. FC: READ_MULTIPLE_REGISTERS, start 10, length 13, done: false, canceled: false, delay: 25212. Full task BasicPollTaskImpl@5b40c0[request=ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@106f07f[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=10,length=13,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502],callback=org.openhab.binding.modbus.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@92278363]
2018-11-03 14:41:27.551 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - POLL MONITOR: scheduled poll task. FC: READ_MULTIPLE_REGISTERS, start 2, length 1, done: false, canceled: false, delay: 25477. Full task BasicPollTaskImpl@1cada4b[request=ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@10781ae[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=2,length=1,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502],callback=org.openhab.binding.modbus.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@bebc532a]
2018-11-03 14:41:27.553 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - POLL MONITOR: callbackThreadPool queue size: 0, remaining space 2147483647. Active threads 0
2018-11-03 14:41:27.556 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - </POLL MONITOR>
2018-11-03 14:41:37.559 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - <POLL MONITOR>
2018-11-03 14:41:37.563 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - POLL MONITOR: scheduled poll task. FC: READ_MULTIPLE_REGISTERS, start 50, length 13, done: false, canceled: false, delay: 14864. Full task BasicPollTaskImpl@179c1b7[request=ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@18bdaa9[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=50,length=13,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502],callback=org.openhab.binding.modbus.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@c430e140]
2018-11-03 14:41:37.566 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - POLL MONITOR: scheduled poll task. FC: READ_MULTIPLE_REGISTERS, start 75, length 7, done: false, canceled: false, delay: 14566. Full task BasicPollTaskImpl@1925010[request=ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@1cb38e8[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=75,length=7,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502],callback=org.openhab.binding.modbus.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@58335add]
2018-11-03 14:41:37.570 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - POLL MONITOR: scheduled poll task. FC: READ_MULTIPLE_REGISTERS, start 10, length 13, done: false, canceled: false, delay: 15189. Full task BasicPollTaskImpl@5b40c0[request=ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@106f07f[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=10,length=13,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502],callback=org.openhab.binding.modbus.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@92278363]
2018-11-03 14:41:37.573 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - POLL MONITOR: scheduled poll task. FC: READ_MULTIPLE_REGISTERS, start 2, length 1, done: false, canceled: false, delay: 15454. Full task BasicPollTaskImpl@1cada4b[request=ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@10781ae[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=2,length=1,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502],callback=org.openhab.binding.modbus.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@bebc532a]
2018-11-03 14:41:37.576 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - POLL MONITOR: callbackThreadPool queue size: 0, remaining space 2147483647. Active threads 0
2018-11-03 14:41:37.578 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - </POLL MONITOR>
2018-11-03 14:41:47.581 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - <POLL MONITOR>
2018-11-03 14:41:47.584 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - POLL MONITOR: scheduled poll task. FC: READ_MULTIPLE_REGISTERS, start 50, length 13, done: false, canceled: false, delay: 4843. Full task BasicPollTaskImpl@179c1b7[request=ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@18bdaa9[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=50,length=13,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502],callback=org.openhab.binding.modbus.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@c430e140]
2018-11-03 14:41:47.588 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - POLL MONITOR: scheduled poll task. FC: READ_MULTIPLE_REGISTERS, start 75, length 7, done: false, canceled: false, delay: 4544. Full task BasicPollTaskImpl@1925010[request=ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@1cb38e8[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=75,length=7,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502],callback=org.openhab.binding.modbus.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@58335add]
2018-11-03 14:41:47.591 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - POLL MONITOR: scheduled poll task. FC: READ_MULTIPLE_REGISTERS, start 10, length 13, done: false, canceled: false, delay: 5168. Full task BasicPollTaskImpl@5b40c0[request=ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@106f07f[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=10,length=13,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502],callback=org.openhab.binding.modbus.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@92278363]
2018-11-03 14:41:47.595 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - POLL MONITOR: scheduled poll task. FC: READ_MULTIPLE_REGISTERS, start 2, length 1, done: false, canceled: false, delay: 5433. Full task BasicPollTaskImpl@1cada4b[request=ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@10781ae[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=2,length=1,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@bda4ab[address=192.168.1.122,port=502],callback=org.openhab.binding.modbus.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@bebc532a]
2018-11-03 14:41:47.597 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - POLL MONITOR: callbackThreadPool queue size: 0, remaining space 2147483647. Active threads 0
2018-11-03 14:41:47.600 [TRACE] [ternal.ModbusManagerImpl.PollMonitor] - </POLL MONITOR>
