Hi again… since i was busy the last weeks i couldn’t make much progress.
i tried your suggestions:
modbus.cfg:
serial.slave1.connection=/dev/ttyAMA0:9600:8:none:1:rtu
serial.slave1.id=1
serial.slave1.type=input
serial.slave1.start=200
serial.slave1.length=4
serial.slave1.valuetype=int32
items:
Group Modbus
Number Raum_MB "Raumtemperatur raw" (Modbus) {modbus="slave1:0"}
Number Raum_MB_kr "Raumtermperatur" (Modbus)
Number Aussen_MB "Aussentemperatur raw" (Modbus) {modbus="slave1:1"}
i get no values but errors in openhab.log
2017-05-09 19:53:46.916 [ERROR] [t.wimpi.modbus.io.ModbusRTUTransport] - Last request: 01 04 00 c8 00 04 70 37
2017-05-09 19:53:46.917 [ERROR] [t.wimpi.modbus.io.ModbusRTUTransport] - failed to read: CRC Error in received frame: 0 bytes:
2017-05-09 19:53:46.919 [ERROR] [pi.modbus.io.ModbusSerialTransaction] - execute try 1/3 error: I/O exception - failed to read. Request: net.wimpi.modbus.msg.ReadInputRegistersRequest@10da78e (unit id 1 & transaction 1). Serial parameters: SerialParameters@d8e661[portName=/dev/ttyAMA0,baudRate=9600,flowControlIn=none,flowControlOut=none,databits=8,stopbits=1,parity=none,encoding=rtu,echo=false,receiveTimeoutMillis=1500]
2017-05-09 19:53:47.067 [ERROR] [t.wimpi.modbus.io.ModbusRTUTransport] - Last request: 01 04 00 c8 00 04 70 37
2017-05-09 19:53:47.072 [ERROR] [t.wimpi.modbus.io.ModbusRTUTransport] - failed to read: CRC Error in received frame: 0 bytes:
2017-05-09 19:53:47.073 [ERROR] [pi.modbus.io.ModbusSerialTransaction] - execute try 2/3 error: I/O exception - failed to read. Request: net.wimpi.modbus.msg.ReadInputRegistersRequest@10da78e (unit id 1 & transaction 1). Serial parameters: SerialParameters@d8e661[portName=/dev/ttyAMA0,baudRate=9600,flowControlIn=none,flowControlOut=none,databits=8,stopbits=1,parity=none,encoding=rtu,echo=false,receiveTimeoutMillis=1500]
2017-05-09 19:53:47.176 [ERROR] [t.wimpi.modbus.io.ModbusRTUTransport] - Last request: 01 04 00 c8 00 04 70 37
2017-05-09 19:53:47.177 [ERROR] [t.wimpi.modbus.io.ModbusRTUTransport] - failed to read: CRC Error in received frame: 0 bytes:
2017-05-09 19:53:47.178 [ERROR] [pi.modbus.io.ModbusSerialTransaction] - execute try 3/3 error: I/O exception - failed to read. Request: net.wimpi.modbus.msg.ReadInputRegistersRequest@10da78e (unit id 1 & transaction 1). Serial parameters: SerialParameters@d8e661[portName=/dev/ttyAMA0,baudRate=9600,flowControlIn=none,flowControlOut=none,databits=8,stopbits=1,parity=none,encoding=rtu,echo=false,receiveTimeoutMillis=1500]
2017-05-09 19:53:47.178 [ERROR] [pi.modbus.io.ModbusSerialTransaction] - execute reached max tries 3, throwing last error: I/O exception - failed to read. Request: net.wimpi.modbus.msg.ReadInputRegistersRequest@10da78e. Serial parameters: SerialParameters@d8e661[portName=/dev/ttyAMA0,baudRate=9600,flowControlIn=none,flowControlOut=none,databits=8,stopbits=1,parity=none,encoding=rtu,echo=false,receiveTimeoutMillis=1500]
2017-05-09 19:53:47.179 [ERROR] [.binding.modbus.internal.ModbusSlave] - ModbusSlave (slave1): Error getting modbus data for request net.wimpi.modbus.msg.ReadInputRegistersRequest@10da78e. Error: I/O exception - failed to read. Endpoint ModbusSerialSlaveEndpoint@1c6568[portName=/dev/ttyAMA0]. Connection: SerialConnection@319350[portName=/dev/ttyAMA0,port=/dev/ttyAMA0]
with 2 different slaves it works:
serial.slave1.id=1
serial.slave1.length=2
serial.slave2.connection=/dev/ttyAMA0:9600:8:none:1:rtu
serial.slave2.id=1
serial.slave2.type=input
serial.slave2.start=202
serial.slave2.length=2
serial.slave2.valuetype=int32
items:
Group Modbus
Number Aussen_MB "Aussentemperatur raw" (Modbus) {modbus="slave2:0"}
This is for reading items.
