example.things
Bridge modbus:tcp:10_10_5_143 [ host="10.10.5.143", port=10502, id=2, timeBetweenTransactionsMillis=500] {
Bridge poller suwak [ start=14, length=1, refresh=1000, type="holding"] {
Thing data hr14_dimmer [ readStart="14", readValueType="uint16", writeStart="14", writeValueType="uint16", writeType="holding"]
example.items
Dimmer Suwak_HR_14 "Suwak HR 14 [%d]"{channel="modbus:data:10_10_5_143:suwak:hr14_dimmer:number", autoupdate="true" }
example.sitemaps
sitemap home label="aaaaaaa" {
Frame label="bbbbbbb" {
slider item=Suwak_HR_14
When slider mooving i set value (0-100). How to write this value to HR14?
How to write this value multiplied 655?
slider 0 -> write 0
slider 10 -> write 6550
slider 100 write 65500
Maybe there is another method like textbox, spinner (Microsoft Visual) to write integer
- Platform information:
- Hardware: iMX8/4GB/8GBemmc
- OS: debian
- Java OpenJDK Runtime Environment (Zulu Embedded 8.25.0.76-linux-aarch32hf)
- openHAB version: 2.5.1
