GJW
(GJW)
November 26, 2021, 3:24pm
1
Hi all,
Can anybody help me out getting Sunspec Three Phase running?
I’m mainly doubting if settings are not correct:
Block Length I tried different values, but cant find what value it should be
Start address 40000 looks fine (with a poller I got some correct data)
Refresh? is it miliseconds or seconds?
UID: modbus:inverter-three-phase:d13e522b99:46dfccd10c
label: Three Phase Inverter
thingTypeUID: modbus:inverter-three-phase
configuration:
length: 50
refresh: 5000
maxTries: 3
address: 40000
bridgeUID: modbus:tcp:SE5000TCP
Many thanks!
Geert-Jan
ohash
(J.Kasmannshuber)
November 26, 2021, 5:02pm
2
you are not providing information about your things and items.
this is how it works in my implementation
Thing from UI:
UID: modbus:inverter-three-phase:slave:SE10K
label: SolarEdge SE-10K-RWS
configuration:
length: 61
refresh: 60
maxTries: 3
address: 40000
bridgeUID: modbus:tcp:slave
and the related items from an .items-file:
String PV_WR_Status "PV WR Status [%s]" <solarplant> (eq_PV_Anlage, gChartPV) ["Point"] {channel="modbus:inverter-three-phase:slave:SE10K:deviceInformation#status"}
Number:Temperature PV_WR_HeatsinkTemperature "PV WR Temperatur Kühlkörper [%.1f °C]" <temperature> (eq_PV_Anlage, gChartPV) {channel="modbus:inverter-three-phase:slave:SE10K:deviceInformation#heatsink-temperature"}
Number:Temperature PV_WR_CabinetTemperature "PV WR Temperatur Gehäuse [%.1f °C]" <temperature> (eq_PV_Anlage, gChartPV) {channel="modbus:inverter-three-phase:slave:SE10K:deviceInformation#cabinet-temperature"}
Number:Temperature PV_WR_TransformerTemperature "PV WR Temperatur Transformer [%.1f °C]" <temperature> (eq_PV_Anlage, gChartPV) {channel="modbus:inverter-three-phase:slave:SE10K:deviceInformation#transformer-temperature"}
Number:Temperature PV_WR_OtherTemperature "PV WR Temperatur Other [%.1f °C]" <temperature> (eq_PV_Anlage, gChartPV) {channel="modbus:inverter-three-phase:slave:SE10K:deviceInformation#other-temperature"}
Number:ElectricCurrent PV_WR_AC_Total "PV WR Strom [%.1f A]" <energy> (eq_PV_Anlage, gChartPV) ["Point"] {channel="modbus:inverter-three-phase:slave:SE10K:acGeneral#ac-total-current"}
Number:Power PV_WR_AC_Real_Power "PV WR AC Leistung Aktuell [%.0f W]" <solarplant> (eq_PV_Anlage, gChartPV) ["Point"] {channel="modbus:inverter-three-phase:slave:SE10K:acGeneral#ac-power"}
Number:Frequency PV_WR_AC_Frequency "PV WR AC Frequenz [%.2f Hz]" {channel="modbus:inverter-three-phase:slave:SE10K:acGeneral#ac-frequency"}
Number:Dimensionless PV_WR_AC_Powerfactor "PV WR AC Leistungsfaktor [%.2f]" {channel="modbus:inverter-three-phase:slave:SE10K:acGeneral#ac-power-factor"}
Number:Energy PV_WR_AC_PowerTotal "PV WR AC Leistung Gesamt [%.3f kWh]" (eq_PV_Anlage, gChartPV) ["Point"] {channel="modbus:inverter-three-phase:slave:SE10K:acGeneral#ac-lifetime-energy"}
Number:Energy PV_WR_AC_PowerTotal_delta "PV WR AC Leistung Gesamt delta [%.3f kWh]" (eq_PV_Anlage, gChartPV) ["Point"]
Number:Energy PV_WR_AC_PowerTotal_prev "PV WR AC Leistung Gesamt prev [%.3f kWh]" (gChartPV)
Number:Energy PV_WR_AC_PowerTotal_corr "PV WR AC Leistung Gesamt corr [%.3f kWh]" (gChartPV)
Number:ElectricCurrent PV_WR_DC_Current "PV WR DC Strom Aktuell [%.1f A]" <solarplant> (eq_PV_Anlage, gChartPV) ["Point"] {channel="modbus:inverter-three-phase:slave:SE10K:dcGeneral#dc-current"}
Number:ElectricPotential PV_WR_DC_Voltage "PV WR DC Voltage Aktuell [%.1f V]" <solarplant> (gChartPV) {channel="modbus:inverter-three-phase:slave:SE10K:dcGeneral#dc-voltage"}
Number:Power PV_WR_DC_Real_Power "PV WR DC Leistung Aktuell [%.0f W]" <solarplant> (eq_PV_Anlage, gChartPV) ["Point"] {channel="modbus:inverter-three-phase:slave:SE10K:dcGeneral#dc-power"}
maybe this helps a bit
regards
system
(system)
Closed
January 7, 2022, 9:03am
3
