Hey!
I have a SolarEdge S10K-RWB48 at home, connected to the network via modbus over tcp.
When I manually poll the fields 40188 and 40189:
…I get 203 and 105, so that’s what I typed in the config of my thing.
As a start address I first chose 40121, because the meter model block starts there, but it seems the thing asks for the inverter model block start, as only that gets me some correct values (e.g. AC frequency, which then is 50.0Hz).
Now if I go to channels, i get a “Total Real Power Value” of 0W. (with both 40121 and 40069 as start)
If I directly poll the modbus at 40206, I get -3281, which is correct.
What can I do here? Am I doing anything wrong?
Sunspec: https://www.solaredge.com/sites/default/files/sunspec-implementation-technical-note.pdf
thing config:
UID: modbus:meter-wye-phase:997978a137:e950040a4f
label: Three Phase Meter, Wye-Connected
thingTypeUID: modbus:meter-wye-phase
configuration:
length: 105
refresh: 5
maxTries: 3
address: 40069
bridgeUID: modbus:tcp:997978a137
channels:
- id: acGeneral#ac-total-current
channelTypeUID: modbus:ac-total-current-type
label: AC Total Current Value
configuration: {}
- id: acGeneral#ac-average-voltage-to-n
channelTypeUID: modbus:ac-average-voltage-to-n-type
label: Average Line To Neutral AC Voltage
configuration: {}
- id: acGeneral#ac-average-voltage-to-next
channelTypeUID: modbus:ac-average-voltage-to-next-type
label: Average Line To Line AC Voltage
configuration: {}
- id: acGeneral#ac-frequency
channelTypeUID: modbus:ac-frequency-type
label: AC Frequency Value
configuration: {}
- id: acGeneral#ac-total-real-power
channelTypeUID: modbus:ac-total-real-power-type
label: Total Real Power Value
configuration: {}
