Nooo … it’s case of looking over what you have, thinking about what you’re doing and why, and fine tuning by adjustment.
Example; are you persisting on every update or every change? Why? (There might be good reasons for some, but not others)
If you are persisting everything you’ve almost certainly not yet thought it through.
“But it’s a Modbus problem!” - well Modbus is an industrial scale protocol that will happily stress all the other parts of the system that you’ve linked it’s data too.
I believe the whole system is stressed. Its an Rpi3A running way above its capabilities. Fine tuning modbus may help a little. But I still believe his system is highly stressed.
Next thing may be, that its running on a bad (slow and old) SD card. That would be the top argument
More than you might expect. This is about adjusting the water tap to control the flow into the leaky bucket. There’s nothing wrong with the tap, but it is capable of making the bucket brim over. By default, the tap is turned fully on.
It works from our rpi3B burn image and the rpi3a has tons of cpu resources etc available but seems like there is a disconnect eventually causing a crash?
If this is true … any plans for OH to do img for the rpi3A range … it has better small form factor, lower cost and similar cpu spec to rpi3b range.
I really wonder how many have thoughts about the Rpi3A. As mentioned, I didn´t even know it was exsisting. But it would be interesting to know, howcome it crashes and Rpi3B doesnt.
Okay, I doubt that has anything to do with 2.4 → 2.5
Did you address update rates, persistence, etc? I am convinced most issues like this are about pouring data into an openHAB design not optimized for this kind of business, resulting in i/o bottlenecks on sluggish hardware. Persistence, logging, Grafana, all queuing and competing for same resources.
Of course it shouldn’t crash, but at least one of these moving parts (including the OS and Java) can be expected to have bugs under stress.
I’m reminded I owe a blurb about Modbus-TCP tweaking, separate business but closely related. I started, but must finish that
I have added some “TCP tuning” info to the Modbus Performance tutorial thread referenced earlier.
This will likely make little difference at the oipenHAB end, but every little helps.
