I’ve set up these things:
Bridge modbus:tcp:raspbx_port_1 [ host="raspbx", port=501, id=41 ] {
Bridge poller smtr_boiler_act_pwr [ start=12, length=2, refresh=2000, type="input" ] {
Thing data smtr_boiler_act_pwr_val [ readStart="12", readValueType="float32" ]
Bridge modbus:tcp:raspbx_port_1 [ host="raspbx", port=501, id=40 ] {
Bridge poller smtr_aqs_act_pwr [ start=12, length=2, refresh=2000, type="input" ] {
Thing data smtr_aqs_act_pwr_val [ readStart="12", readValueType="float32" ]
And these items:
Number AQS_active_power "Potência AQS [%.1f]" (All) {channel="modbus:data:raspbx_port_1:smtr_aqs_act_pwr:smtr_aqs_act_pwr_val:number"}
Number Boiler_active_power "Potência Aquecimento [%.1f]" (All) {channel="modbus:data:raspbx_port_1:smtr_boiler_act_pwr:smtr_boiler_act_pwr_val:number"}
The issue is that both items are updated with the same value. Boiler_active_power
is correct, but AQS_active_power
is not.
These are the logs:
10:20:56.786 [DEBUG] [dbus.handler.ModbusPollerThingHandler] - Thing modbus:poller:raspbx_port_1:smtr_aqs_act_pwr received response PollResult(result=AsyncModbusReadResult(request = ModbusReadRequestBlueprint@187184c[slaveId=41,functionCode=READ_INPUT_REGISTERS,start=12,length=2,maxTries=3], registers = ModbusRegisterArrayImpl(41 11 99 9a)))
10:20:56.789 [DEBUG] [ternal.handler.ModbusDataThingHandler] - Thing modbus:data:raspbx_port_1:smtr_aqs_act_pwr:smtr_aqs_act_pwr_val channels updated: {modbus:data:raspbx_port_1:smtr_aqs_act_pwr:smtr_aqs_act_pwr_val:number=9.100000381469727}. readValueType=float32, readIndex=Optional[12], readSubIndex(or 0)=0, extractIndex=0 -> numeric value 9.100000381469727 and boolValue=true. Registers ModbusRegisterArrayImpl(41 11 99 9a) for request ModbusReadRequestBlueprint@187184c[slaveId=41,functionCode=READ_INPUT_REGISTERS,start=12,length=2,maxTries=3]
10:20:57.617 [DEBUG] [dbus.handler.ModbusPollerThingHandler] - Thing modbus:poller:raspbx_port_1:smtr_boiler_act_pwr received response PollResult(result=AsyncModbusReadResult(request = ModbusReadRequestBlueprint@191165e[slaveId=41,functionCode=READ_INPUT_REGISTERS,start=12,length=2,maxTries=3], registers = ModbusRegisterArrayImpl(41 11 99 9a)))
10:20:57.620 [DEBUG] [ternal.handler.ModbusDataThingHandler] - Thing modbus:data:raspbx_port_1:smtr_boiler_act_pwr:smtr_boiler_act_pwr_val channels updated: {modbus:data:raspbx_port_1:smtr_boiler_act_pwr:smtr_boiler_act_pwr_val:number=9.100000381469727}. readValueType=float32, readIndex=Optional[12], readSubIndex(or 0)=0, extractIndex=0 -> numeric value 9.100000381469727 and boolValue=true. Registers ModbusRegisterArrayImpl(41 11 99 9a) for request ModbusReadRequestBlueprint@191165e[slaveId=41,functionCode=READ_INPUT_REGISTERS,start=12,length=2,maxTries=3]
10:21:00.498 [DEBUG] [dbus.handler.ModbusPollerThingHandler] - Thing modbus:poller:raspbx_port_1:smtr_aqs_act_pwr received response PollResult(result=AsyncModbusReadResult(request = ModbusReadRequestBlueprint@187184c[slaveId=41,functionCode=READ_INPUT_REGISTERS,start=12,length=2,maxTries=3], registers = ModbusRegisterArrayImpl(41 13 33 33)))
10:21:00.503 [DEBUG] [ternal.handler.ModbusDataThingHandler] - Thing modbus:data:raspbx_port_1:smtr_aqs_act_pwr:smtr_aqs_act_pwr_val channels updated: {modbus:data:raspbx_port_1:smtr_aqs_act_pwr:smtr_aqs_act_pwr_val:number=9.199999809265137}. readValueType=float32, readIndex=Optional[12], readSubIndex(or 0)=0, extractIndex=0 -> numeric value 9.199999809265137 and boolValue=true. Registers ModbusRegisterArrayImpl(41 13 33 33) for request ModbusReadRequestBlueprint@187184c[slaveId=41,functionCode=READ_INPUT_REGISTERS,start=12,length=2,maxTries=3]
On the modbus server, I can only see requests to the device with id=41
, which matches the logs.
Is there any thing wrong in my config? I checked and re-checked, and I can’t find anything wrong.
Thanks.
